WiFi at home but What about in the field?
15 replies to this topic
#1 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 18 February 2020 - 10:13 PM
I can remotely operate my Nexstar 6SE at home because I can use my WiFi from the house to control my telescope via an HP laptop Dummy terminal. What do I do when I am out in the field away from my home  WiFi?
Is there an alternative to controlling the scope and camera on my mini computer out in the middle of nowhere?
I know I can operate my telescope via Skyportal and CPWI, but what about my camera? At home, I connect my camera to the mini computer and run SharpCap remotely. Out in the field, if I have no local WiFi, what can I use to connect to the mini computer with my dummy terminal?
#2 bdyer22
bdyer22
Posted 18 February 2020 - 10:27 PM
some options:
  1. Take a wifi hotspot out in the field with the same networking settings as your home network.
  2. Plug your laptop into the scope and cut the mini pc out of the mix
  3. get a second wifi adapter for your laptop.  Connect one to the skyportal and create a P2P (ad hoc) network to the mini pc on the other
Hope that helps. :)
  • Starman27 and Stargazer3236 like this
#3 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 18 February 2020 - 10:31 PM
some options:
I have both the onboard Dual Band WiFi on the mini computer and a USB 3.0 WiFi antenna as well. I have WiFi 1 and WiFi 2.
How do I create a P2P network?
#4 bdyer22
bdyer22
Posted 18 February 2020 - 11:05 PM
It's been a long time since I've set one up.  I just googled it. :)
I'm assuming both are running 1 win 10...
https://social.techn...itpronetworking
#5 Dynan
Dynan
  • Loc: NOLA
Posted 19 February 2020 - 12:30 AM
I believe Windows 10 no longer uses Homegroup. Those links are outdated.
#6 deepanshu29
deepanshu29
Posted 19 February 2020 - 12:55 AM
I have a micro USB powered WiFi router mounted next to my Intel NUC. Mini PC (via ethernet cable) and iPad (over WiFi) connects to this router and then I can remote in to Mini PC.
This is the model I have !
Edited by deepanshu29, 19 February 2020 - 01:48 PM.
#7 cmooney91
cmooney91
  • Loc: Massachusetts
Posted 19 February 2020 - 07:34 AM
I use a small mini router on the telescope computer to generate it's own WiFi network (no internet).
I use a GL.iNet Gl-AR300M with external antennas. This one is is nice because:
  • It takes its power from one of the mini PC's USB plugs
  • One of the external antennas can be swapped for a high gain antenna,  significantly increasing the range.
  • it has a wired Ethernet connector. There's no sense wasting WiFi bandwidth on a PC that is 6 inches away from the router.
  • It is tiny
For even more range I use a USB WiFi dongle with an external antenna plugged into the remote terminal PC/laptop/tablet. I replace its antenna with another high gain antenna. This way the long range communication happens through a pair of high gain antennas, instead of relying on the anemic internal antenna in most PC devices.
It looks something like this.
I use it like this regardless of whether I am at home or in the field, it boots up with the computer and it is very reliable.
Having a universal system like this also adds ease of mind. There is no reconfiguration needed to adapt to a use case or environment, so there is nothing to forget or no mistakes to be made that could spoil a night.
Edited by cmooney91, 19 February 2020 - 09:40 AM.
  • Rickster and roelb like this
#8 Clouzot
Clouzot
  • Loc: South of France
Posted 19 February 2020 - 07:48 AM
Same here, a nano WiFi router powered by the scope-side computer. Ad-hoc networks can be hard to setup and Win10 doesn’t make it easy (on the contrary)
#9 astrohamp
astrohamp
Posted 19 February 2020 - 01:04 PM
I also am using a GL.iNet GL-AR750S-Ext Gigabit Travel AC Router (Slate) but in router mode.
Switching the WAN port to LAN means I can plug the mount and NUC in via Ethernet and access them wireless or through a third Ethernet cable.  Windows Remote Desktop will operate either way.
The GL.iNet Gl-AR300M cmooney91 is using is the better option since it can be run with a high gain directional antenna for potentially improved wifi reach.
#10 cmooney91
cmooney91
Posted 19 February 2020 - 01:43 PM
The AR300M should also consume less than half the power since it is only 2.4GHz 300Mbps, it has no second 5.8GHz radio. This is nice for running off of a battery in the field, when every Watt counts.
The 2.4GHz signal attenuates much less than 5.8GHz, so it penetrates  walls, floors, and trees  much better, leading to a longer effective range. The high gain antennas compound the effect.
300Mbps should be more than enough for 4k  remote desktop.  A Netflix movie quality 4K@30Hz stream only takes  about 25Mbps. Windows RDP should be a lot less demanding than that since it only sends screen elements that have changed/updated instead of the full fame 30 times a second.
If you are having issues with 2.4GHz signal congestion in an urban environment, the external antennas can be switched out for a pair of "circular polarized antennas", which should reject most of the other signals.
The extra Ethernet port on the AR750 looks really handy. Is it possible to disable the 5.8GHz radio if not in use?
  • nic35 likes this
#11 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 19 February 2020 - 01:45 PM
Well, for the life of me, I could not figure out how to configure for a wireless P2P connection between laptop and mini computer without a LAN. I did, however, figure out how to connect via Ethernet CAT6 cable instead. I have a 50 foot Ethernet cable that I connected between my laptop and mini computer, which will enable me to sit in my SUV with the laptop and run the telescope outside via Ethernet cable from the mini computer to the laptop. That will save me from the biting cold on those clear dark winter nights when I want to image, but don't want to sit outside next to my telescope with the camera wired to my laptop.
  • bdyer22 likes this
#12 Noah4x4
Noah4x4
  • Loc: Colchester UK
Posted 19 February 2020 - 01:58 PM
A constructive thought from my experience of outdoor sports broadcasting where some cameras (typically 24v) might be remote from mains electricity power so we couldn't simply plug in mains electricty adapters. This situation is not dissimilar where a laptop demands 19 volts.
I would often use a 12v 18ah GEL mobility scooter battery connected to a 12v/240v 300 watt DC/AC inverter (12v/110v in the USA). That option allowed me to embrace regular power 'bricks' (for 19v laptop) as I had my own (equivalent) mains electricity supply in the field. You can get higher wattage inverters. Mobile home owners often do something similar to run Tv's.
This route not only permitted me to embrace full mains voltage devices (240v in UK), it also allowed me to embrace Power over Ethernet (POE) devices. I simply plugged in a 24v POE converter for (POE)  camera and 18v converter for (POE) point to point wireless. POE is great as data and power flow down a single cable. This is hence a neat way of distributing different voltages to various devices from a single compact power source.
Frankly, I am a tad surprised that POE has never featured in the astronomy camera market as one less cable would be great. But these thoughts about alternative power options at remote locations might inspire the innovators out there.....
#13 astrohamp
astrohamp
Posted 19 February 2020 - 02:38 PM
Both wireless radios on the GL.iNet GL-AR750S-Ext and be switched on/off independently.
  • cmooney91 likes this
#14 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 19 February 2020 - 06:49 PM
There are security cameras that use POE to power them. Unfortunately virtually nobody uses security cameras as a basis for astronomy cameras anymore. Until the astronomy camera manufacturers move away from USB to Ethernet (either wired or WiFi) POE doesn't make any sense since it seems to be simpler and cheaper to use a separate 12v DC power connection (because of it's widespread availability at the telescope).
  • roelb likes this
#15 Noah4x4
Noah4x4
Posted 20 February 2020 - 03:00 AM
Agreed Mark. Just surprised thst nobody has explored this given a single Ethernet cable will handle both data and power and is faster and much more reliable than USB.
For my outdoor sports video (Internet) broadcasts I use a £265 Sunba PTZ, H265, 1080p Internet Protocol POE 20x zoom CCTV camera and it offers TV quality. I have never considered aiming it skyward to see what I can capture. I might explore. Might be OK for (say) Lunar! But if my Atik Horizon was POE......
#16 mclewis1
mclewis1
    Thread Killer
Posted 20 February 2020 - 10:13 AM
Noah, Oh I totally agree. It sure would be very nice to have choice of true astronomy oriented cameras with a native Ethernet connection that also supports POE. One simple, flexible, long, and cheap Cat5/6 cable between a PC and the camera ... so no need for distance extenders, second power cables, etc.
As long as the drivers also exist for generic ASCOM, and INDI connections as well as specific drivers for SharpCap, ZWO software (assuming ZWO hardware), and a few other EAA/image capture apps.
And if those drivers existed then a WiFi version of the cameras would be a nice option too.
