PS Elements 11 Add-on?
3 replies to this topic
#1 dallen24
dallen24
Posted 18 February 2020 - 11:49 PM
Hi.  Just did a time-lapse.  Took about 400, 15 second images with my wide field lens for my Canon 450D.  I see a water spot.  In my PS Elements 11, I get the healing brush out and remove the spot.  Now I have to heal the same spot 400 times!  Question.  Is there a script add-on for my PS Elements 11 to record my spot removal and have it repeated on all images?  Any advice is appreciated.
#2 SilverLitz
SilverLitz
  • Loc: Louisville, KY
Posted 19 February 2020 - 08:27 AM
I do not think you want to edit in PsE prior to stacking, as PsE only works in 8-bit mode.  Regular Ps works in 16-bit mode for everything and 32-bit for crop and Levels.  You need all the bit-depth for the extreme stretching required for AP.
#3 dallen24
dallen24
Posted 19 February 2020 - 08:43 AM
This is time-lapsing, not stacking.  With 400 images, I end up with about 12 seconds of video.
#4 Blackbelt76
Blackbelt76
Posted 19 February 2020 - 09:48 AM
Hmmm?
Can you merge the 400 layers then heal?
