What could I be doing wrong with phd
5 replies to this topic
#1 Suresh
Suresh
  • Loc: South India
Posted 21 February 2020 - 01:35 AM
Hello friends ,
It’s been a long time since I’ve posted here . Ive been into AP for a long time . Recently I started using Samyang 135 mm lens with qhy183 M( 3asp) and for guiding I use hour lodestar with guidescope( 9 asp ) . Mount is AP Mach 1 which has a PE of 1 arc second . I guide with phd (native settings of aggression 100/ hysterisis 10 . I’m polar aligned with 1 arc min . I calibrate and then run guiding assistant for 5 minutes and accept settings . Star is chosen via auto select . My balance is slightly east heavy ( not required as it’s spring loaded ). I usually start imaging an hour before crossing meridian using the flip .my problem is I get pin point stars till it just crosses meridian , but as the stars set towards the west I’m noticing an east west drift . I’ve also tried without guding and the drift is not seen . You may ask me why am I guiding in the first place . My doubt is if phd is taking control or overdoing it . I know I must send the logs , but just looking for advice from seniors. My seeing is about 1.5-2 arc seconds .is the difference in asp between the guiding scope of 3:1 causing this ? Thanks
Edited by Suresh, 21 February 2020 - 02:21 AM.
#2 jerahian
jerahian
  • Loc: Maine
Posted 21 February 2020 - 01:55 AM
 Side-to-side flexure with your guide scope?
#3 Suresh
Suresh
  • Loc: South India
Posted 21 February 2020 - 02:11 AM
Nearly impossible as the whole setup is rigid
#4 ButterFly
ButterFly
Posted 21 February 2020 - 04:12 AM
What are the minimum motion settings?  It's sounding like oscillations as you chase seeing.
#5 Suresh
Suresh
  • Loc: South India
Posted 21 February 2020 - 04:50 AM
It’s 0.10 but as per the guiding assistant on a day to day basis so some variation will be there
#6 Madratter
Madratter
Posted 21 February 2020 - 08:43 AM
You may not believe flexure, but it is differential flexure, almost for sure. Blink through a series of subs where you are seeing the problem and report what you are seeing.
