Focus Motor Calibration
1 reply to this topic
#1 CarlGreen
CarlGreen
Posted 21 February 2020 - 06:03 AM
Hi Everyone
Hope this is the right forum for this.
I have a Celestron Focus Motor.
I have gone through the calibration process (I am using CWPI).
This might be a silly question, but do I have to calibrate it every time I use it? Only each time I open CWPI and go to focus motor, it has the calibrate option?
Carl
#2 pyrasanth
pyrasanth
Posted 21 February 2020 - 08:25 AM
On most systems calibration is a one time operation unless something changed which you manually did. That button should be able to be ignored until you need to re-calibrate as the settings should get saved after your successful (or not) calibration. Are you sure you have saved the calibration settings after I presume the wizard completed?
Edited by pyrasanth, 21 February 2020 - 08:27 AM.
