Mount for Skywatcher 130 PDS
3 replies to this topic
#1 patricko2
patricko2
Posted 21 February 2020 - 06:47 PM
As a newbie I'd appreciate advice on a suitable mount for my Skywatcher 130 PDS
www.opticalvision.co.uk/astronomical_telescopes-sky-watcher-dual-speed_parabolic_telescopes/explorer-130pds_ota.html
I'm mainly interested in visually observing; not planning AP at present. I'm presently using some 7x50 binoculars and will add the 130 to observe in more detail. My garden is really terrible for observing with lots of overhanging trees and bad light pollution. So I'm in need of a grab and go solution to take to a darker location.
After doing some research the Skywatcher AZ4 or AZ5 seem good and I can put it on a sturdy photography tripod I already own. However, I wondered if an equatorial mount (EQ5?) might be better to keep the object within view?
Any advice much appreciated.
#2 vtornado
vtornado
  • Loc: Northern Illinois
Posted 22 February 2020 - 12:44 PM
Hello and welcome to the forum.
I assume you live in the UK based upon the link.
I have the Skywatcher heritage 130, which I assume is about the same length and weight as your
scope.
This scope mounts well on a explore scientific TW1, or vixen porta mount.
I'm sure it will mount well on the AZ4 (which is available in the states) and the AZ5
which is not.  I have heard good things about the AZ4, but do not own one.
The AZ5 will be heavier, but it has slow motion controls which is good for tracking at high power.
I have the CG4 which in your parlance is the EQ5.  This scope will work well on this mount  too.
If you set up and move your scope through a large arc of sky, the eyepiece will be pointed in
a weird direction which will require you to twist the scope in the rings.  An EQ mount is
even heavier due to the counter weight.
The EQ might be better for public viewing because you could motorize it and the object would
stay centered in the eyepiece.
If you are viewing by yourself, or with one other person, In my opinion a mount with slow motion controls is plenty adequate to track at high power with this scope.
  • izar187 and patricko2 like this
#3 SeattleScott
SeattleScott
Posted 22 February 2020 - 01:29 PM
I have the AZ4. Nice mount but probably a little overkill for a 5” newt. A twilight I or Porta II will be lighter and have slo mo.
  • patricko2 likes this
#4 Hesiod
Hesiod
Posted 22 February 2020 - 01:58 PM
Manual alt/az are nice for the little Newt (I have used mine sometimes with a Porta mount).
If want an autotracking, manual mount may look also to the eq3, which is smaller and lighter than the eq5 but still up to the job (for visual).
Take note that the same mount can be "turned" into an alt/az with little effort
  • mrsjeff and patricko2 like this
