fixing plastic newton focuser base broke off
28 replies to this topic
#1 greenglass
greenglass
  • Loc: Hamilton. Ontario, Canada
Posted 22 February 2020 - 01:08 PM
any ideas to put a base on this?
#2 DLuders
DLuders
  • Loc: Spokane, WA
Posted 22 February 2020 - 01:22 PM
You could incrementally create a new base by using JB Weld epoxy.  Build up several layers, a day at a time, to conform to the curved telescope tube.  The color of JB Weld is close to what you have too!  smile.gif
#3 wrnchhead
wrnchhead
  • Loc: NE Kansas
Posted 22 February 2020 - 01:29 PM
Not sure what the other side of the base looks like, but if it isn’t a critical collectors item, Surplus Shed and other sources could replace your whole focuser for $25 probably unless you wanted to upgrade.
  • Jon Isaacs and theropod like this
#4 wrnchhead
wrnchhead
  • Loc: NE Kansas
Posted 22 February 2020 - 01:32 PM
I would pay good money to see someone actually do this. I guess anything is possible with $50 worth of JB Weld!
  • Jon Isaacs and tim53 like this
#5 Benach
Benach
Posted 22 February 2020 - 01:46 PM
RSXRSXJORT0jBHFce9D5JucpPCwdh0HjtZaxuD1t
  • JoeVanGeaux, andycknight, kevint1 and 4 others like this
#6 N3p
N3p
Posted 22 February 2020 - 02:01 PM
hahahahah :p
  • lonn likes this
#7 Zwick
Zwick
  • Loc: Austin, TX
Posted 22 February 2020 - 05:48 PM
Have a friend with 3d printing capabilities? Shouldn't be too hard to model a copy of the broken original and print it. Actually depending on your location, Libraries or commercial operations may be able to do the print. You would just have to take careful measurements of the broken part and do the Computer Aided Design work (or find someone who could). Several decent free CAD programs are available.
#8 Ken Watts
Ken Watts
  • Loc: Sun City, Az
Posted 22 February 2020 - 06:14 PM
I shortened a newtonian plastic focuser and determined it was ABS. I used ABS cement (solvent)and had perfect joints.  Worth a try.
#9 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 22 February 2020 - 06:55 PM
Just pick up one from another unused scope.  It will be must easier in the long run.
What size tube is it for?  Maybe someone has something you can use in their parts boxes.
Edited by Garyth64, 22 February 2020 - 06:57 PM.
  • Jon Isaacs, Pinbout and airbleeder like this
#10 Pinbout
Pinbout
Posted 22 February 2020 - 08:04 PM
that is beyond fixing or the cost for a new $15 used focuser.
  • Jon Isaacs likes this
#11 Sully606
Sully606
  • Loc: Chicago, USA
Posted 22 February 2020 - 08:20 PM
https://telescope-wa...h-125-metal-top
Will this work?
#12 Pinbout
Pinbout
Posted 22 February 2020 - 08:24 PM
if he cut off the base and squared his off, he could probably glue it to his old focuser... lol.gif foreheadslap.gif
  • airbleeder, Garyth64 and Sully606 like this
#13 Jon Isaacs
Posted 22 February 2020 - 09:42 PM
Knowing more about the scope, more about the focuser would be helpful.  I am seeing Orbitor in the first image and 76mm as the aperture and X00mm for the focal length, maybe it's a 76 mm Newtonian with a 700mm focal length, that's pretty common.  Is the focuser 1.25 inch or 0.965 inch?
Plastic focusers are generally inexpensive, replacing it would be the best way to go if it were affordable and a focuser could be found.
Otherwise, it might be possible to glue the focuser back together, depending on the material.
#14 greenglass
greenglass
Posted 22 February 2020 - 09:54 PM
the tube is 4.75 '' diameter.
i like the JB weld bond idea but not cheap.
how about 3 angle irons screwed to the draw tube?
#15 Jon Isaacs
Posted 22 February 2020 - 10:22 PM
If the JB Weld is compatible with the focuser material, just glue it back together and be done with it.
JB weld is just epoxy so there may be other material specific adhesives that are a better fit.
#16 iwannabswiss
iwannabswiss
  • Loc: Somewhere in Space
Posted 22 February 2020 - 11:50 PM
Find someone with a 3D printer.
#17 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 23 February 2020 - 08:14 AM
Can we get a photo of the name plate on the focuser?
Do you have the other section?  You didn't say.
Edited by Garyth64, 23 February 2020 - 08:15 AM.
  • Jon Isaacs and airbleeder like this
#18 dogbiscuit
dogbiscuit
Posted 23 February 2020 - 11:03 AM
I have successfully "welded" broken ABS parts using a soldering iron and 3d printer ABS filament or waste material from ABS printed parts for filler material.
Fit the pieces together and clamp them.  Tack a several places around to hold alignment then go around with more penetration to get good depth of the weld. Build up a little on the surface and sand to pretty it up.
  • tim53 likes this
#19 Pinbout
Pinbout
Posted 23 February 2020 - 11:25 AM
Thermo forming - yes
Thermo setting - no
#20 greenglass
greenglass
Posted 23 February 2020 - 04:33 PM
here's the label of the beast.  the plastic looks like bakelite.  the 3/4 inch secondary had a steel clip which rusted and stained that part of the mirror. i replaced it with a copper one.
Edited by greenglass, 23 February 2020 - 04:34 PM.
#21 greenglass
greenglass
Posted 23 February 2020 - 04:41 PM
missing most of the flange , i have 5 pieces of it. so gluing it together wont help.
#22 wrnchhead
wrnchhead
  • Loc: NE Kansas
Posted 23 February 2020 - 05:04 PM
https://www.surpluss...tem/L14818.html
Really reminds me of this focuser. Unfortunately, out of stock. I don’t know how handy you are or how much money you want to spend on that scope because I also see it listed at Goodwill for $20 in Texas but you might consider replacing the whole scope at this point.
#23 steveastrouk
steveastrouk
  • Loc: State College, Pa.
Posted 24 February 2020 - 09:43 AM
https://www.surpluss...item/L3630.html
#24 ww321q
ww321q
  • Loc: Winton Ca.
Posted 24 February 2020 - 10:52 AM
If you want to fix it and not replace it you could maybe start with a piece of 4" abs pipe cut out to the right size. then glue the two pieces together. Or
Edited by ww321q, 24 February 2020 - 11:01 AM.
#25 ww321q
ww321q
  • Loc: Winton Ca.
Posted 24 February 2020 - 11:36 AM
That looks like the same one on my Bushnell
