.70mm Replacement objective
7 replies to this topic
#1 BobW55
BobW55
  • Loc: Melvin, Michigan (Sanilac County)
Posted 22 February 2020 - 10:21 PM
So I have one of these Astromania 70mm guide scopes.
Nice scope till I dropped it.
Anyone know if it is possible to order a replacement objective?
It is only cracked along the edge, still works, but gives a bunch of refraction spikes on really bright stars.
#2 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 23 February 2020 - 10:55 AM
I don't know of any way to order just an objective for it.
You might try gently removing the objective, and using a black sharpie to blacken the crack...or even make a small aperture mask out of plastic for the front, that covers the crack.  No more diffraction spikes, and it will work fine.
#3 BobW55
BobW55
Posted 23 February 2020 - 01:32 PM
Didn't think about just masking it off.... will give that a go.  thanks
#4 BobW55
BobW55
Posted 23 February 2020 - 01:41 PM
Here is what it looks like.
#5 Redbetter
Redbetter
  • Loc: Central Valley, CA
Posted 23 February 2020 - 05:01 PM
Probably the same optics as in the Celestron 70mm Travel Scope.  Both are 400mm so I would expect an objective swap to be easy.  These go on sale cheaply at times.  You can find used ones on Ebay for less.
  • Jon Isaacs likes this
#6 BobW55
BobW55
Posted 23 February 2020 - 10:15 PM
Contacted Astromania Optics,
They are willing to sell a new Objective lens assembly for $45.   Cheaper than buying a new scope.
I masked off the damaged area for now.
  • OldManSky likes this
#7 mattyfatz
mattyfatz
  • Loc: Boise Idaho
Posted 24 February 2020 - 09:03 AM
There are a few options. You need to find the FL. You're also going to need a spanner wrench for the retaining ring:
surplus shed
  CN classifieds under ATM
#8 BobW55
BobW55
Posted 24 February 2020 - 10:18 AM
I just went and ordered direct from the vendor.
https://astromaniaop...cope-p0399.html
Thanks for all the replies
