Solar Discs & Features | HA, CaK, Gband | Feb 23rd 2020
13 replies to this topic
#1 MalVeauX
MalVeauX
  • Loc: Florida
Posted 23 February 2020 - 02:37 PM
Heya,
Woke up to a blue sky so figured I'd see what our sleepy start was doing. Not much going on. A filament, a prominence, nothing grand. So I did some full discs in HA, CaK & Gband to show the upper & lower chromosphere and photosphere. Seeing allowed a brief look at the chromosphere at a finer scale before the clouds rolled in.
Colored:
B&W:
Seeing Data (poor!):
Equipment:
120mm F10 Masked Frac (CR150HD)
ED80 Frac
Solarmax 60 II Etalon (HA)
Lunt B1200 CaK (CaK)
Edmund Optics 430nm + Baader 10 stop ND filter in 2" Skybender with 2" Baader Blue CCD-IR Block Filter (Gband)
ASI183MM for full discs
ASI290MM for partials
Very best,
  • Doug Culbertson, johncandy, Jaimo! and 10 others like this
#2 rigel123
rigel123
  • Loc: SW Ohio
Posted 23 February 2020 - 02:46 PM
Great Shots!
  • MalVeauX likes this
#3 TerryWood
TerryWood
  • Loc: USA
Posted 23 February 2020 - 04:28 PM
Really nice images! There was some interesting areas on the surface today, which I seemed to be able to to view easier with my eyeball using various tunings. Marty, does the Lunt CAK filter simply plug in place of the scopes diagonal without the additional need of a front mounted etalon or ERF? I haven't delved into that world, but it would be interesting if I could simply put it in my Coronado scope (pre-Meade version) and unscrew the front mounted etalons. V/R Terry
#4 MalVeauX
MalVeauX
  • Loc: Florida
Posted 23 February 2020 - 05:11 PM
Hey Terry,
Yessir, the Lunt CaK module has its own ERF system before its filters, up to a general rule of thumb of 100mm aperture (per Lunt). So for smaller scopes, its just a diagonal and filter that plugs in. Nothing else needed. Plop in the camera. For my larger apertures (120mm to 150mm), I do put a Baader 2" Blue CCD-IR block filter in front of it, to serve as a D-ERF that removes all the visible spectrum except blue and near UV, greatly reducing thermal load so prolong the filter's life. For my small ED80, I do not bother, the Lunt CaK filter again handles the heat up to 100mm aperture without anything extra.
Here's my ED80 with the Solarmax 60 II etalon & blocking filter,  Lunt CaK module in the back and the Skybender with the Edmund Optics 430nm filter. Plug and play to jump between different narrowband options. My ED80 has become a tri-band modular system (hence the 3 disc imaging approach). And the IMX183 sensor let's me do full disc shots with room to spare at that image scale with the 600mm focal length nicely.
Very best,
Edited by MalVeauX, 23 February 2020 - 05:31 PM.
  • TerryWood and Terra Nova like this
#5 highfnum
highfnum
  • Loc: NE USA
Posted 23 February 2020 - 06:08 PM
wow lots of detail
#6 PhotonJohn
PhotonJohn
  • Loc: Viera Florida
Posted 23 February 2020 - 08:19 PM
Absolutely Splendiferous Marty, you are truly the MAN ! As usual, thanks for the wealth of information in your posts.
#7 sunnyday
sunnyday
  • Loc: Ottawa,Canada
Posted 23 February 2020 - 08:35 PM
I am sure you have been asked to do this 100 times, but what is the net advantage of having reflective paper on your telescope?
sorry if i'm 101.
btw nice pics like always.
#8 MalVeauX
MalVeauX
  • Loc: Florida
Posted 23 February 2020 - 08:51 PM
sorry if i'm 101.
I use reflectix material to act as heat barriers for local seeing conditions, to prevent heat from pluming from the pier, mount, yet.
Very best,
  • sunnyday likes this
#9 twjs
twjs
  • Loc: NWNJ
Posted 24 February 2020 - 07:55 PM
Hey Marty if we buy you a plane ticket would you do a workshop at NEAF this year?grin.gif
#10 MalVeauX
MalVeauX
  • Loc: Florida
Posted 24 February 2020 - 09:02 PM
I've never been to an organized even for this stuff actually; would be nice to do that sometime and bump elbows.
Very best,
#11 Tyson M
Tyson M
  • Loc: Canada
Posted 24 February 2020 - 09:44 PM
bow.gif  Well caught and processed.
#12 TerryWood
TerryWood
  • Loc: USA
Posted 25 February 2020 - 10:40 AM
Thanks for the detailed CaK information! Exactly what I needed to know. I appreciate it! V/R Terry
#13 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 26 February 2020 - 06:57 AM
"Here's my ED80 with the Solarmax 60 II etalon & blocking filter,"
Hi Marty,
Is that the double stack etalon or the primary "Rich View tuned" one?  Nice images as always!
#14 mikerepp
mikerepp
  • Loc: Harwood Heights, Illinois, dark site Manistique, Michigan in UP
Posted 26 February 2020 - 09:41 AM
Awesome stuff Marty!  Great images!
