The need for IR/UV cut filters with reflectors.
10 replies to this topic
#1 mattproulx86
mattproulx86
Posted 23 February 2020 - 03:01 PM
I have a ZWO ASI294MC camera which does not have a built in IR/UV filter. I see a lot of people recommending using the ZWO IR/UV block filter with refractors to reduce star bloating. My question is, is this a problem with reflectors? Currently I use a Celestron UHC/LPR and Optolong L-Enhance, I would like to try imaging galaxies without any filters if possible. I should mention that I have bortle 4 skies.
Edited by mattproulx86, 23 February 2020 - 03:07 PM.
#2 DrGomer
DrGomer
Posted 23 February 2020 - 03:19 PM
All reflective coatings we use in the visible will reflect a significant amount of UV and IR, so I'd say, yes, you still need it.   UV/IR filters shouldn't impact imaging at all in a negative way unless they are scratched or have junk on them.
#3 sg6
sg6
  • Loc: Norfolk, UK.
Posted 23 February 2020 - 03:20 PM
The Optolong appears to only pass Hb+OIII the Ha and blocks wavelengths below 470nm (UV) and above 700nm (IR).
So the Optolong acts as a UV/IR block.
The filter has no data for below 470 and above 700 so the presumption is that nothing is passed. Which may be a little questionable. But the filter curves they give say nothing less the 470nm (UV) and nothing greaterr the 700nm (IR).
  • Ewing9999 likes this
#4 TOMDEY
TOMDEY
  • Loc: Springwater, NY
Posted 23 February 2020 - 03:39 PM
All-reflective telescopes are free of chromatic aberrtions... so will not cause stars to bloat.    Tom
  • psandelle, bortle2 and mattproulx86 like this
#5 DSOs4Me
DSOs4Me
  • Loc: New Jersey
Posted 23 February 2020 - 03:54 PM
If you have light pollution around you would want to use one. For me it's the Baader UV/IR cut.
#6 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 23 February 2020 - 04:04 PM
True...unless you use a coma corrector (a refractive set of elements), in which case...not so much :)
  • bobzeq25 likes this
#7 nic35
nic35
Posted 23 February 2020 - 04:05 PM
+1 on what TOMDEY says,  Plus, galaxies are strong IR emitters, IIRC.  So you don't want to filter out the IR range - you are throwing away photons..  Bortle 4 skies shouldn't cause light pollution problems.  If you feel a need for a light pollution one, then try the Astronomik CLS non-ccd.  It passes more of the IR than does the "regular" CLS.
john
  • psandelle likes this
#8 TOMDEY
TOMDEY
Posted 23 February 2020 - 04:27 PM
john
Yes! I also use a Night Vision Eyepiece that is sensitive into the Near Infrared... and galaxies are quite spectacular using that... can actually see the NIR!    Tom
#9 evan9162
evan9162
  • Loc: ID
Posted 23 February 2020 - 05:02 PM
Actually, they will.  For a given aperture, the spot size of the airy disk of a star is larger in IR than it is in visible light.  The resolving power of an optic is dependent on the wavelength of light as well as the aperture size.
#10 TOMDEY
TOMDEY
Posted 23 February 2020 - 06:45 PM
Meh... of course... but that's not chromatic aberration; it's the Heisenberg uncertainty principle. Say, here's a brain-teaser puzzle that I submitted to our lens design class back in the 1970s >>>
Design a telescope whose Airy Disc is wavelength-invariant.
Hint: The solutions are deceptively simple, but have some subtle nuances! I'll present a couple later, if there is any interest (and if no one comes up with any aforehand).
Bonus puzzle: Design a white rainbow.  Tom
#11 KLWalsh
KLWalsh
  • Loc: North Georgia, USA
Posted 23 February 2020 - 11:22 PM
Diffraction is a property of waves, not necessarily Heisenberg Uncertainty. Macroscopic waves (water waves) also exhibit diffraction.
While it’s true that IR energy will have a larger diffraction pattern than visible light, that also means the energy is spread over a larger area. Thus the intensity at a given spot would be lower, all else being equal.
The intense blue usually seen around the Class B stars in photos of the Pleiades is due to the smaller diffraction pattern for blue wavelengths.
