Custom park position CEM60
6 replies to this topic
#1 Astrola72
Astrola72
  • Loc: Maryland, USA
Posted 24 February 2020 - 12:35 PM
I made the rookie mistake of building my little telescope shed without allowing for growth. My new ES127 just barely fits in the closed-up shed, but it requires a custom parking position, quite off from the 4 preset parking positions and not close to zero position. I can't seem to make it work. It's not critical - I have to manually close up anyway so I can always manually move the mount to the desired position. It would just be more convenient if it parked where I want it to.
Joe
#2 Madratter
Madratter
Posted 24 February 2020 - 01:46 PM
Joe, I'm pretty sure you don't use Voyager, but in Voyager you could add a command to the DragScript to send your telescope to a specific alt-az location. (Among other very handy uses that is good for getting SkyFlats as well).
In fact you could use the unlicensed version of Voyager (which has no expiration and has a 1 hour use limitation), to do this and only this if you so chose.
#3 Biggen
Biggen
  • Loc: PCB, FL
Posted 24 February 2020 - 02:57 PM
Joe
How are you using the mount?  With the handset or Commander program?
If its like my IEQ 30Pro you should be able to set a custom parking position in Commander.  Does it give you the choice to use "current" as the new parking position?
Edited by Biggen, 24 February 2020 - 02:58 PM.
#4 Jii
Jii
  • Loc: Pirkkala, Finland
Posted 24 February 2020 - 03:12 PM
I tried customer parking position from Commander with my CEM60 few weeks back when I was trying to figure out good place for flatlight in my shed. Custom position worked OK for me, as far as it was not under horizon (which was what I was after, bummer...).
#5 Astrola72
Astrola72
Posted 24 February 2020 - 03:50 PM
Thanks for getting back to me guys.
Yep. That's my problem. I need a position below the horizon. It seems to take it, but when I park the scope it goes to my previous park position.
I'm using the HC to set the park position, but when imaging (SGP) I use Commander. Right now I'm just using the HC to try to get the park position I want. It does give me the option of "current position" but it doesn't seem to work - when I park (using HC) it goes to a previously-stored position. I think the problem has to do with altitude limit. I've got to figure that out.
Joe
Edited by Astrola72, 24 February 2020 - 03:51 PM.
#6 Astrola72
Astrola72
Posted 24 February 2020 - 04:25 PM
Well, it wasn't Altitude limit. I set that to -89 and overrode the dire warnings, but still no go. That's using park=current position. I can't figure out how to get a negative Alt in the custom park position. No big deal - I've marked the spots on my mount and I'll just move the mount to the parking position manually. It won't technically be parked but that really doesn't matter for now.
Joe
  • Jii likes this
#7 Jii
Jii
Posted 24 February 2020 - 04:38 PM
Joe
rgsalinger had same behavior with his CEM120, must be a common limitation for iOptron:
https://www.cloudyni...s-in/?p=9925822
In my case I don't luckily have to park the scope permanently under horizon, it just would have been convenient option for taking flats. I think that as a workaround I will move to scope to correct Alt-Az position via APT, turn tracking off, take flats and then park it properly. I haven't tried this yet, but in principle it should work. You could check if similar operation would be possible via SGP.
