The Cleanstoration of a Mizar SP-68R (68/1000mm)
28 replies to this topic
#26 Kasmos
Kasmos
  • Loc: So Cal
Posted 24 March 2020 - 01:26 PM
What a great quarantine project! Looks great!
Most of the work was done before the lock down but do have a little more to do, not to mention a few other scopes in need of work.
#27 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 24 March 2020 - 02:29 PM
Chris, although some hardware differences your resto is going nicely and I'm keenly following along. I also notice your legs have some blocking between the the hub and the tray that would make it a little more rigid. I might have to look for some mahogany.
My Mizar SP + wood tripod versus Mizar AR + ShortPod:
The wood tripod has the braces above the tray, and is almost as robust as that 1960s Eagle surveyor tripod that I now use with my VersaGo.
What I need:  At least 2 more genuine gray Mizar counterweights.
Chris, you are a Maniac (in the best way!):  The only tripod hardware I've ever polished were the chrome bolts to my 452 with the raised Goto symbols.
Edited by Bomber Bob, 24 March 2020 - 02:32 PM.
  • walter a and Kasmos like this
#28 Kasmos
Kasmos
  • Loc: So Cal
Posted 24 March 2020 - 04:39 PM
The Slow Motion Knobs & Cables
Before and After photos
Like most of the scopes hardware the Knobs and Cables were looking a bit sad.
First they recieved a generally wiping down and cleaning with Simple Green.
The chrome sections and screws were polished, first using Nevr-Dull, then Blue Magic.
#0000 steel wool was used while the Nevr-Dull was wet and a small brass brush was used on the screws.
Stuff with small nooks and cranies are usually treated back and forth with Nevr-Dull, Blue Magic,
a brass brush, steel wool, sometimes a stainless brush, or a toothbrush. In other words whatever works.
Then the plastic elements were treated with Mothers LVR Vinyl Leather and Rubber Cleaner Conditioner.
There was a somewhat hardened greenish film of oxidation on the couplers,
and I wasn't very confident that the bottom rusty screw would be salvageable.
Some patina is left in the form of small freckles on the couplers,
but overall I'm very happy how the chrome came back to life.
I was especially surprised how well both Allen Screws came out.
The knobs came out nicely too.
  • astro140, Bomber Bob, walter a and 2 others like this
#29 walter a
walter a
  • Loc: Prawda Manitoba Canada
Posted 25 March 2020 - 08:13 AM
Walter,
My scope's tripod lower inner legs have holes drilled for different height settings. Is your's the same or do they slide for height adjustments?
Also, I noticed yours has a solid slow motion control shaft. Mine has the flexible cable type. That's probably something I'd like to change.
Correct they slide for adjustment and as for the slo-mos I swap them between the mizar and carton mounts as they share the larger shaft size.
  • astro140, Bomber Bob and Kasmos like this
