Balance a very light refractor in declination?
7 replies to this topic
#1 Blueox4
Blueox4
  • Loc: Upstate New York
Posted 28 February 2020 - 01:29 PM
Here’s a pic of my FL70-S on a Vixen SXD2. It’s extremely light and even with the finder scope and bracket off though on in the photo, is still focuser end heavy. I can’t move it up anymore in the saddle even if the rings were closer together because the focuser knobs hit the saddle. I was thinking of adding a single ring close to the dew shield to get the weight needed to balance in declination. Is there a better alternative?
#2 Hesiod
Hesiod
Posted 28 February 2020 - 01:38 PM
A longer dovetail bar.
With the FL55 the provided dovetail bars extends almost 15cm behind the focuser's knobs
  • Dynan likes this
#3 WadeH237
WadeH237
  • Loc: Snohomish, WA
Posted 28 February 2020 - 01:53 PM
If it's that light, do you even need to worry about a slight imbalance?  It looks like you are set up for visual, so I suspect that everything would work find just as it sits.
  • SkipW likes this
#4 Blueox4
Blueox4
Posted 28 February 2020 - 01:57 PM
With a eyepiece added it’s more than a slight imbalance. It is light enough where this mount would overcome it I’m sure but I would rather try and balance it a bit better. Also, a longer dovetail still results in the focuser knobs hitting the saddle at the same point unless I elevate the rings with a spacer or new dovetail that is higher.
#5 Jim R
Jim R
Posted 28 February 2020 - 02:26 PM
I like your idea of putting a ring near the dew shield.
#6 SkipW
SkipW
  • Loc: Oklahoma, USA
Posted 28 February 2020 - 02:30 PM
Does it balance if you remove the finder? If that helps, replace it with something lighter.
You realistically have three choices:
  1. Reduce weight at the tail end.
  2. Add weight at the objective end.
  3. Live with it.
#7 rlillard
rlillard
  • Loc: Tucson, AZ USA
Posted 28 February 2020 - 02:44 PM
I feel your pain.  I am less than a year into the hobby and my biggest frustration by a wide margin has been the what should be a simple act of bolting things together.  To be in this hobby you need to own a machine shop and a hardware store.
I offer two solutions. I've used both.  See pix.
1) a second dovetail plate and saddle
2) Riser blocks.
Ray
Fixed images.
Edited by rlillard, 28 February 2020 - 03:16 PM.
  • eros312 and Blueox4 like this
#8 Tom3
Tom3
  • Loc: Scottsdale, AZ
Posted 28 February 2020 - 06:44 PM
I used this for a similar problem:"Amazon.com : Bullet Weights SCL14 1-Pound Roll Solid Core Lead Wire Fishing Line, 1/4-Inch : Lead Core And Wire Fishing Line : S"
  • Blueox4 likes this
