Truly Awful Star Test Of Coulter 17.5" In Truss Dob
68 replies to this topic
#26 Bob4BVM
Bob4BVM
  • Loc: W. Oregon
Posted 11 March 2020 - 03:27 PM
Tom,
For your mirror support pads, I would not use the nylon acorn nuts unless the back has been ground flat, because a point support like that would tend to settle between the bumps that are on the back of standard unground pyrex back of most Coulter mirrors.  Better to have a wider surface that the bumps can sit on...
Trick is how to locate the flat support points on the triangles in the exact PLOP-calc'd locations. . .
For my new cells on my BT project, I am using these little plastic drawer-glide pads. Not sure what the plastic is, but I can say that it is quite hard and extremely slick against the bumpy bac of my Coulter primaries.  The cool thing is that they have a small pin/brad out the back of the pad, so you can exactly locate   them on your triangles by drilling small holes in the triangle corners at your PLOP locations.
I have a bunch of these pads, would be happy to send a set down to you. If you want to try them, drop me a PM.
CS
Bob
Edited by Bob4BVM, 11 March 2020 - 03:30 PM.
#27 Steve Dodds
Steve Dodds
    Owner - Nova Optical
  • Loc: Utah
Posted 11 March 2020 - 03:53 PM
I use 1" furniture glides, adhesive backed, pack of 6 about $3
  • Don H, Pinbout, sopticals and 1 other like this
#28 Pinbout
Pinbout
Posted 11 March 2020 - 07:26 PM
Who said anything bout acorn nuts?
  • Augustus likes this
#29 Bob4BVM
Bob4BVM
  • Loc: W. Oregon
Posted 11 March 2020 - 10:51 PM
no one.
When I read cap screws my mind saw acorn nuts.
My bad, sorry !
  • Pinbout likes this
#30 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 14 March 2020 - 11:54 AM
Dennis at DobStuff is sending me the silicone and small plastic dots he has used successfully for years. Not sure why it didn't work back when this scope was made, perhaps too large of dabs or an odd batch of silicone.
I'll report back when I get the job done and can get the scope back out under the stars.
#31 Bob4BVM
Bob4BVM
  • Loc: W. Oregon
Posted 14 March 2020 - 02:50 PM
Something that escapes me is how one would locate any type of stick-on pads at the exact PLOP locations. We go to great lengths to get an ideal mirror-support schematic from PLOP, good to several decimal places, then work hard to build a cell to those tolerances. All that seems lost if we do not exactly locate the COE of the pads at their exact positions on the triangles. To my thinking that is nearly impossible short of having drilled PLOP-location holes to receive pinned pads, nylon screw-heads, or similar item with some sort of shank to center pads in said holes.
What is the method to locate stick-on pads ? Do you draw an outline of the pad on the triangle, centered on the PLOP point, or what ?
CS
Bob
Edited by Bob4BVM, 14 March 2020 - 02:52 PM.
  • Greg Campbell likes this
#32 Pinbout
Pinbout
Posted 14 March 2020 - 04:22 PM
I layout everything in AutoCAD
I don’t see your problem.
  • dave brock likes this
#33 Bob4BVM
Bob4BVM
  • Loc: W. Oregon
Posted 14 March 2020 - 07:56 PM
 I get that
Guess I didn't make myself very clear.
PLOP does the same thing, as far as providing a dimensioned layout of the support points
My question is about how you go about the physical assembly, ie the mechanical location of the pads
Does autocad assemble the physical parts for you,  ?
  • Retsub likes this
#34 ccaissie
ccaissie
  • Loc: Whitefield, Maine
Posted 15 March 2020 - 07:41 AM
 I get that
I'm sure the tolerances for locating the actual support points could be determined, but whatever it is, I'm sure it's within the tolerances available to a careful craftsman and hand tools....+/- 1/16" ?
  • Pinbout and Matthew Paul like this
#35 Bob4BVM
Bob4BVM
  • Loc: W. Oregon
Posted 15 March 2020 - 02:24 PM
I am terrible at expressing my ideas. My issue is that with a pinless (stick on) pad, you are covering up the center mark on the triangle, so are somewhat blind in sticking it on the triangle.
I thought of the solution below, you just need to measure the pad diameter and draw yourself an outline with a compass, using a punched center mark.
Hope this may be of some help to folks using stick-on pads...
CS
Bob
Edited by Bob4BVM, 15 March 2020 - 02:29 PM.
#36 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 12 June 2020 - 11:34 AM
UPDATE: 6/12/2020
Remounted the mirror on the cell using the same technique and advice/materials from Dennis Steele (DobStuff). While the edges no longer look like a walnut there is obvious astigmatism when the star gets near to pinpoint.
I think the next step is to test the mirror and secondary to find out where it's coming from.
Will keep this thread updated as new info surfaces.
  • paul, PrestonE and Pinbout like this
#37 Don W
Don W
    Founding Member
  • Loc: Wisconsin, USA
Posted 12 June 2020 - 11:47 AM
I bought a used Oddysey 1 in the late 80s. Huge, cumbersome and images were awful. I tossed everything but the primary and built a very nice dob around it. Images were no better. The mirror had severe astigmatism. Sold the the mirror to a friend who had it refigured into something usable. I took the dob mount and using longer truss tubes I put in a Galaxy 18" f/5.5 mirror into it. The images were amazing, some of the best views I've ever had in a dob.
  • Jon Isaacs likes this
#38 Greg Campbell
Greg Campbell
  • Loc: Southern Aridzona
Posted 12 June 2020 - 12:03 PM
UPDATE: 6/12/2020
If not too difficult, try rotating the secondary and see of the astigmatism axis follows.
#39 pierce
pierce
  • Loc: Santa Cruz, CA
Posted 12 June 2020 - 01:06 PM
My Obsession Classic 20 f/5 has a Galaxy mirror, from the early/mid 90s, and is superb.
  • Don W likes this
#40 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 12 June 2020 - 01:34 PM
Hmm, not sure how I'd rotate the secondary but as there are three threaded posts for the cell to sit in the rocker box I could rotate the primary.
I'll give that a try if I don't have the primary checked before I have a chance to do it.
#41 Pinbout
Pinbout
Posted 12 June 2020 - 01:39 PM
ke or ronchi test thru focus on a star... see if there's clocking.
#42 pierce
pierce
Posted 12 June 2020 - 01:50 PM
how do you rotate an elliptical secondary on a newtonian??
  • Don W likes this
#43 mark cowan
mark cowan
    Vendor (Veritas Optics)
  • Loc: salem, OR
Posted 12 June 2020 - 03:54 PM
I think he meant rotate the primary. :lol:
#44 tomb18
tomb18
Posted 13 June 2020 - 12:07 AM
When I was a young teen, I drooled over the ads for the coulter mirrors.  I finally saved up for one and it took another year to save for a mount.  By was I disappointed.  Never could see much on Jupiter for example. 35 years later I ground my first mirror.  A 10" f 6.6. I tested it at 1/11th wave on the wave front.  Won first prize small optics at Stellaphane. I decided to test the Coulter after this.  1 wave.  Garbage.  I think it cost me decades of not bothering with astronomy.
  • LarsMalmgren and Pinbout like this
#45 pastorgalactico
pastorgalactico
  • Loc: SPAIN
Posted 13 June 2020 - 10:03 AM
Hello;
What works best and is easiest to put is to put nylon screws with cap nuts or cap nuts at each vertex of the triangle as support points.
That is fantastic.
Never glue the mirror to the triangles.
Regards.
#46 Pinbout
Pinbout
Posted 13 June 2020 - 10:34 AM
Hello;
That is fantastic.
Regards.
You mean nylon cap screw heads, nutz on the bottom heads on the top
Edited by Pinbout, 13 June 2020 - 10:38 AM.
#47 pastorgalactico
pastorgalactico
  • Loc: SPAIN
Posted 13 June 2020 - 11:46 AM
Hello;
I mean the walnut-shaped blind nuts.
Pardon my English translated from Spanish.
Regards.
#48 Pinbout
Pinbout
Posted 13 June 2020 - 12:09 PM
Hello;
Regards.
pictures are worth more than a 1,000  languages
#49 pastorgalactico
pastorgalactico
  • Loc: SPAIN
Posted 13 June 2020 - 12:16 PM
  • LarsMalmgren likes this
#50 Pinbout
Pinbout
Posted 13 June 2020 - 12:20 PM
  • stubeeef likes this
