Cave Astrola 12.5" Model D
166 replies to this topic
#51 macdonjh
macdonjh
Posted 16 March 2020 - 02:40 PM
Ok, it’s time for the important stuff. Can somebody direct me to the proper method for cleaning the primary mirror. Mine seems to be really dirty. And it has a couple of pits or imperfections in it, is this normal?
The short version is: search the Reflectors forum here for "mirror cleaning" or something similar.  There will be hundreds...
Slightly longer:
  • Blow loose junk off with compressed air (blowing with your mouth, using one of those lens bulbs, "canned" air from the computer store)
  • Rinse less loose junk off with running water
  • Use a dilute soap solution to soak what ever is stuck, then use cotton balls to wipe the mirror surface (just push the cotton ball around, using the weight of the cotton with no extra pressure)
  • Rinse with running tap water
  • Rinse with distilled water
  • Place on the edge to drain and dry.  I also blow water drops off the edge, and/ or use the edge of a paper towel to wick the water drops off (touch the water drop with the paper and the water will wick into the paper)
At least, that's what I've done with mirrors I can remove from their OTAs.
#52 clamchip
clamchip
  • Loc: Seattle
Posted 16 March 2020 - 02:45 PM
Anybody know how this comes apart? 60mm Spotter Scope.
attachicon.gifspotter2.jpgattachicon.gifspotter4.jpgattachicon.gifspotter1.jpgattachicon.gifspotter3.jpg
The ends unscrew from the tube.
The objective end will have a tiny set screw locking it's movement you will need to
unscrew.
The eyepiece focuses by turning in/out.
Robert
Edited by clamchip, 16 March 2020 - 02:46 PM.
#53 RDFox
RDFox
  • Loc: Indiana
Posted 16 March 2020 - 10:30 PM
Slightly longer:
Thanks, adding some photos.
  • Bomber Bob and ANKry like this
#54 RDFox
RDFox
  • Loc: Indiana
Posted 16 March 2020 - 10:33 PM
unscrew.
Robert
Thanks, this helps. This way I can actually put a little force into it knowing they unscrew.
#55 RDFox
RDFox
  • Loc: Indiana
Posted 18 March 2020 - 07:05 AM
Yes, I used a strap wrench on both ends. Worked really well. Thanks
#56 macdonjh
macdonjh
Posted 18 March 2020 - 09:16 AM
Thanks for the photos, RDFox.  If that was my mirror, I'd start with the steps I outlined.  If is was still dirty the next day after it had dried thoroughly, I'd then step up to using to alcohol and cotton balls (same technique, only the weight of the cotton balls, no additional pressure) since maybe some of that schmutz is fungus.  Alcohol usually leaves streaks for me, so I'd follow the alcohol with acetone.
Once you get it at least mostly cleaned off, you can use the "look at a bright light through the mirror" technique to decide if the coatings are in good shape or not.  I've held a mirror such that the sun shone through it and then looked for bright spots in the mirror's shadow on the ground.
#57 RDFox
RDFox
  • Loc: Indiana
Posted 18 March 2020 - 01:13 PM
Thanks, this really helps!
#58 RDFox
RDFox
  • Loc: Indiana
Posted 19 March 2020 - 11:39 AM
The tubes were gelcoated, not painted, and it was done prior to forming on the mandrel.  Judging by the cracking I see on these, the shop that made these was thinning their gelcoat with acetone instead of styrene monomer.  Cheaper but doesn't allow full polymerization and excessive cracking and shrinkage is the result.
You will have to have an automotive paint shop color match the old gelcoat.  Modern whites are much brighter than they were 50 years ago.
Ok, think I’m going to try to put gelcoat on this Tube. Keeping it as close original as possible. I’ll keep you posted as to the progress. I’m still quite a ways from starting on the OTA. I’ve painted several Muscle cars and old Corvettes, but this scares me. I would hate to ruin the tube. And yes you can see the weave through the gelcoat now.
#59 Chuck Hards
Chuck Hards
Posted 19 March 2020 - 11:47 AM
You can't really screw up gelcoat, since you can sand-out any runs, drips, etc.  You will be buffing the entire tube and will probably lose the weave print-through.
If you want to preseve that print pattern, I suggest you just do local repairs, then a light priming and automotive paint for a final finish.  That pattern won't keep printing through successive gelcoat layers.
  • Mr Magoo and Augustus like this
#60 RDFox
RDFox
  • Loc: Indiana
Posted 20 March 2020 - 11:36 PM
Pier is done.
  • Joe Bergeron, tim53, L. Regira and 10 others like this
#61 Jeff B
Jeff B
Posted 21 March 2020 - 08:14 PM
I see the mirror has a center spot so hopefully the coatings are just filthy.  any luck with the cleaning.
Love the pier!
Jeff
#62 RDFox
RDFox
  • Loc: Indiana
Posted 21 March 2020 - 09:50 PM
Love the pier!
Jeff
Not much luck, it looks like I’m going to send it to get recoated. Put a light behind it and could see quite a bit of it shining through. Argh! But not the end of the world.
#63 Jeff B
Jeff B
Posted 22 March 2020 - 09:27 AM
Well, if you're applying fresh paint an grease, why not fresh coatings too!
Curious, many times a Newt OTA is stored pointed up, which may be why the primary is so dirty.  But that means the secondary mirror is pointed down and does not get nearly so dirty.  How is the coating on the secondary?  Any scribe marks/writing on the edge of the primary?
You are going to have one awesome scope when you're done.
Jeff
#64 RDFox
RDFox
  • Loc: Indiana
Posted 22 March 2020 - 06:49 PM
Jeff
I’ve always thought that the heavy end should be stored on the bottom, less chance of falling over. And I always had the top end covered, but as you can see it didn’t do much good. And yes the secondary mirror is cleaner. The primary has a lot of coating missing (light shines through from the bottom). And it does have the date and mirror number scribed on the side 9/24/1967. Another thing, I restore muscle cars and restoring this scope is right up there as being as complicated. And a lot more attention has to be paid to accuracy. You just can’t buff your way to mirror alignment. And this scope will last longer than any car.
  • L. Regira and Jeff B like this
#65 Chuck Hards
Chuck Hards
Posted 23 March 2020 - 07:40 AM
The convention is to store Newtonian tubes horizontally, so that the mirror surfaces are approximately vertical.  This keeps dust deposition to a miniumum.  The tube can usually be oriented so that the secondary is also vertical, or upside-down, which accomplishes the same thing.
#66 RDFox
RDFox
  • Loc: Indiana
Posted 23 March 2020 - 12:08 PM
Duh! I didn't think of that. See I'm more challenged than you thought. Thanks. It makes me wonder what other things I'm doing that's not too smart? :)
#67 RDFox
RDFox
  • Loc: Indiana
Posted 23 March 2020 - 09:50 PM
Updated photos
  • Joe Bergeron, tim53, Terra Nova and 1 other like this
#68 RDFox
RDFox
  • Loc: Indiana
Posted 23 March 2020 - 09:53 PM
Quiz Time! What are these?
#69 Chuck Hards
Chuck Hards
Posted 23 March 2020 - 10:08 PM
Is that foam?
  • TOM KIEHL likes this
#70 RDFox
RDFox
  • Loc: Indiana
Posted 23 March 2020 - 10:21 PM
Is that foam?
Yes it is, I figure I can friction fit them in and seal the ends while I refinish the tube. The plywood will add support for the 3/4” pipe running all the way through it. This way it will rotate and I won’t have to spray upside down, and be just plain easier. BTW the rotating rings were really hard to take off. I’m going to experiment with hot water to expand them and see if it they will slide over new paint, if not I’m going to have to Come up with a different plan.
#71 RDFox
RDFox
  • Loc: Indiana
Posted 24 March 2020 - 09:07 PM
Any idea how these small bearings come out? Pressed in? This is a photo of the Dec drive.
#72 RDFox
RDFox
  • Loc: Indiana
Posted 26 March 2020 - 11:20 AM
These little bearings are pressed in with great care. Ordered new ones (77R6). I’ll keep posting as I go. We’ll see how careful I can be.
#73 macdonjh
macdonjh
Posted 26 March 2020 - 11:31 AM
Duh! I didn't think of that. See I'm more challenged than you thought. Thanks. It makes me wonder what other things I'm doing that's not too smart? smile.gif
What you once lacked in storage knowledge you're making up for in restoration knowledge.  Your mount looks great so far.  You cheated, though: no photos of the head getting cleaned up and painted!  At least it looks like you've cleaned it and painted it, I can see part of it in your photos of your pier.
#74 RDFox
RDFox
  • Loc: Indiana
Posted 26 March 2020 - 04:20 PM
More pics
  • L. Regira, Mr Magoo, Jeff B and 3 others like this
#75 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 26 March 2020 - 07:54 PM
I heated the aluminum block up slightly with a heat gun and they fell right out.
  • tim53 and RDFox like this
