Cave Astrola 12.5" Model D
#79
Posted 29 March 2020 - 08:41 PM
Good thing you have an inside space to paint. No way you could paint today in Indiana with a door open!
#80
Posted 29 March 2020 - 10:35 PM
You have that right! One thing about Indiana, if you don’t like the weather just wait a couple of hours, it’ll change. Anyway i’m very blessed to have a space to do this kind of thing. And right now living in rural Indiana is a good thing.
- Mr Magoo likes this
#81
Posted 29 March 2020 - 10:45 PM
I might add that the wrinkle paint takes a little effort to actually wrinkle. You need to heat up the primed piece with a blow dryer. Then put a couple of heavy coats on it. And then start using a blow dryer to speed up the drying process, it will take about 5 to 10 minutes for the desired wrinkling to occur. This stuff will not wrinkle worth a crap without blow drying it. Once the the desired texture is accomplished , let dry overnight.
BTW. The large parts are more difficult. It took me about 20 minutes of blow drying to finish a rotating ring.
#83
Posted 01 April 2020 - 08:54 AM
Impressive!
#84
Posted 01 April 2020 - 09:04 AM
I find that following the directions and putting two heavy coats on 5 minutes apart works very well, too. And for small parts, I stick them in an old toaster oven to cure for a couple hours at low heat. They can be handled after that.
-Tim.
#85
Posted 01 April 2020 - 10:01 AM
-Tim.
Thanks Tim, your tips are welcome. I will put them to good use. BTW, we'll see if I survive putting the parts in my wife's oven. LOL
- tim53 likes this
#86
Posted 01 April 2020 - 10:14 AM
May I suggest one of my favorites, Spam burgers for the wrinkle paint bake day or evening.
Fry the slices on the stove top, sear for a crisp brown and a little smoke.
Baking oil base wrinkle has a very similar smell to fried Spam.
Robert
Edited by clamchip, 01 April 2020 - 10:20 AM.
- dave brock and Terra Nova like this
#87
Posted 01 April 2020 - 10:33 AM
mmmmmmmmmm………...Spam Burgers!
- dave brock and clamchip like this
#88
Posted 02 April 2020 - 10:33 AM
Robert
Probably similar chemistry, too.
- davidmcgo, RDFox, dave brock and 1 other like this
#89
Posted 02 April 2020 - 11:16 AM
#92
Posted 06 April 2020 - 10:27 AM
These are a tight fit. I removed the rings by tapping very gently with a rubber hammer, no problem. But I can see that once I refinish the tube these are going to be a PIA to slip back on. Anybody have an idea? I'm thinking about dipping the rings in boiling water and see if that helps, or just refinish the tube around the rings.
Edited by RDFox, 06 April 2020 - 10:27 AM.
#93
Posted 06 April 2020 - 01:39 PM
Heating is probably your best bet. These are large and relatively thin, so should expand quite a bit.
I've got a set of rotating rings with my 10" DK (yes, I know that Casses don't need rot rings), and they came with sections of thick cardboard tubing that fit under them and makes it possible to put the rings on over the riveted end rings.
-Tim.
#94
Posted 07 April 2020 - 10:25 PM
Ok, I’m really glad I tried to fit the rings on before I painted the tube. Dodged a bullet, there is no way to get these on without completely destroying the finish. I’m putting the rings on and then paint the tube. I really don’t like doing it this way, but I see no other way. (I’ve tried heating the rings in boiling water to expand them, but very little help).
#95
Posted 07 April 2020 - 10:38 PM
The fiberglass tube may shrink quite a bit if placed in a near freezing environment.
It always surprises me how much plastic shrinks and grows due to temperature.
Robert
#96
Posted 08 April 2020 - 07:52 AM
Robert
IKR, I remember that from putting vinyl siding on my house. Two months ago this could have worked, but now it's in the mid 70's and my freezer isn't large enough. Anyway I'm fairly satisfied with the way I'm going to do it. (No Choice!). ARGH!
#97
Posted 08 April 2020 - 07:54 AM
BTW, my workshop is a mess!!!!!
#98
Posted 08 April 2020 - 01:02 PM
Positive proof you have a project...
#100
Posted 08 April 2020 - 10:42 PM
After about another hour of tedious masking, I primed the tube. About in the middle of everything a severe storm came through blew several trees down none hit me or anything else, Whew! (Our house sits in the middle of the woods) Bed time!
- tim53, L. Regira, Mr Magoo and 3 others like this
