Sketching with a lightpad: a test
2 replies to this topic
#1 Jef De Wit
Jef De Wit
  • Loc: Hove, Belgium
Posted 07 March 2020 - 09:16 AM
Most deepsky-sketchers work with a little red light. But to see all the stars on the paper I have to use more red light than good for my nightvision.
So, could there be an alternative? Using black paper is one alternative. But could a lightpad be a solution?
Of course the lightpad should be modified. I used a self adhesiv red filter and taped duct-tape on the rear end, the sides and some parts of the top.
Two problems occured: the light isn't evenly distributed (on the photo the left side is slightly brighter) and the structure of the paper is slightly visible.
The lightpad has three levels of brightest. I started with three layers of paper: one sketchingpaper and underlying two blanco papers. The test target was the open cluster NGC 2324 in Monoceros. The two problems mentioned above weren't a big issue at the telescope. Instead I had difficulty in seeing the sketched stars, so I took away one blanco paper. Now the stars were better visible, but the light started to ruin my nightvision...
CONCLUSION: sketching with a lightpad has the same problem than the 'classic' way of sketching deepsky. It isn't worse nor better. Here is the scanned sketch:
  • Uwe Pilz, steve t, niteskystargazer and 1 other like this
#2 eyeoftexas
eyeoftexas
Posted 07 March 2020 - 09:22 AM
The end result is still a very nice sketching.  Whatever method works for you, please keep sharing the sketches. waytogo.gif
#3 niteskystargazer
Posted 08 March 2020 - 01:56 PM
Jef,
Nice sketch of NGC 2324 smile.gif .
thanx.gif ,
