Analysis of the Astrophysics 105 Traveller EDF F5.8
65 replies to this topic
#51 Tyson M
Tyson M
  • Loc: Canada
Posted 27 March 2020 - 11:38 PM
Had a quick grab and go session, hoping to catch the moon and venus before conditions took a narly turn for the worse. Clear skies, transparency was poor and seeing poor (2/5).
I left the house at quarter after nine.
I packed up the car in about 5 mins, got changed 5 mins.  Drove out to another spot in the light polluted city, about 5 mins.  Set up, 5 mins.
All I had was my 31N, 17ES92, and a 5xpowermate.  So I put in the ES and surfed around.
The moon was waxing crescent, only 9% illumination!   The ES92 actually frames it very well, and its Earthshine was very apparent.
Transparency was bad here so I moved along.  I found M36, M37, M38.  I saw venus, but I was getting bad flaring off of it.
M45 right by it looked not bad, although being fairly close to Venus and some faint transparency issues.
I surfed up Cr69, Cr70.  NGC 1981 was a nice cluster Sigma Orionis looked good, you can see 6 star around it, but the star itself only showed 3 of the 4 members.
M42 quite muted in the poor sky, but still obvious despite the conditions.
Sirius in Canis Major was surprising.  Even with the conditions, the pup wanted to come out.  I could see it at times, but it wasnt jumping completely out of the glare, a bit more closer to the primary than last session of average seeing.  I would not call a split but man this scope wants to make short work from it.
I marvelled at the mechanics of this scope again, the course focuser knob and its precision machining.  Racked in the focuser and packed up as it looked like the session was going to be hamstrung and getting worse by the hour.
I packed up at 10:05, a solid 30mins out only...weak session.  Guess I was just stir crazy and wanted some fresh air.  Next time I will bring my leica zoom.
  • rustynpp, Scott in NC, m9x18 and 6 others like this
#52 manusfisch
manusfisch
Posted 30 March 2020 - 07:35 PM
anybody familiar with the Traveler I would like to ask about the dovetail on top of the traveler which is an AP style dovetail and likely similar to the old Zeiss dovetail.  Smaller than the Vixen size 43-44 mm depending on the maker, larger than the Orion guide scope dovetail. (31mm approx).  As far as I can tell the diameter is about 38mm.   Anyone know a dovetail that imitates the Zeiss/AP narrow dovetail commercially available and fits this small dovetail on the top of the traveler.  Tom. Fischer, indy
#53 Doug D.
Doug D.
  • Loc: Virginia
Posted 31 March 2020 - 06:24 AM
Discmounts now seems to make a short A-P compatible sliding bar:
http://www.discmount...7_dovetail.html
In fact, A-P still has some 7” sliding bars in stock but no plans to make more as I understand it:
https://www.astro-physics.com/sb0800
Here is a link to some great information on the A-P site that includes not only dimensions but hole spacings and comparisons to the Vixen standard. Didn’t realize that the A-P sliding rails were manufactured in 2 widths, I’ve only used the SBO800, which is indeed 1.5” (38mm). The Discmount version mentioned above is wider at 1.9” like the no longer available A-P 15” sliding bar:
https://www.astro-ph...0800-sb1000.pdf
Edited by Doug D., 31 March 2020 - 06:48 AM.
  • Paul G and gozer like this
#54 Tyson M
Tyson M
  • Loc: Canada
Posted 31 March 2020 - 10:37 PM
I set up again tonight, hoping to catch a break in the poor transparency to observe the first quarter moon, one of my fav lunar phases.
Instead, I got only the briefest of views in between gaps in the thin clouds before being completely skunked out, but I could tell I am really going to like observing the moon with this scope using a 32 brandon and especially the leica zoom.
Anyways, I did another round of temperature testing to observe cooldown times for this oil-spaced triplet.
I brought the scope out from the basement of the warm house at 1945 and starting measuring at 1947 to 1950.
As always, I take measurements from various places of the ota- the lens, the middle of the tube, and the focuser end.
Temperature was listed as minus 14C but it was falling to -18C, and at times felt like -20C.  The folding camping table the scope was sitting on in the snow/grass was metal and measured at approx -26C
Lens
OTA
Focuser end
Now, after waiting 20 mins (I should have measured after 10mins as it cooled down fast), local time 20:07- 20:10
Lens
OTA
Focuser end
As you can see, the outside middle of the ota which was sitting on table was still the coldest.  The tube currents coming out of the metal focuser end/visual back is now colder than the lens and it's coming up on the temperatures at the middle of the OTA.
Now, after an additional 16-18mins, local time 20:26 - 20:28
Lens
OTA
DELETED by mistake off my phone, I think it said -22C
Focuser end
Here the scope's  oil-spaced triplet lens was only 1 degree C off with the outside temps at approx 45 mins, and basically at equilibrium on the focuser end of the scope. I figured it would fall further while being on the metal table which was colder than the air, so I took the scope off the table and put it on the mount.
I wanted to take a final measurement at 20:45 (1hr)to post here to display equilibrium but I had technical difficulties with the digital laser thermometer.  Low power likely would have been good after the first set of measurements, after the second, mid to high.  And after an hour, really high magnifications likely possible.
Thanks for reading and clear skies!
Edited by Tyson M, 01 April 2020 - 12:44 PM.
  • peleuba, Scott in NC, R Botero and 2 others like this
#55 25585
25585
Posted 01 April 2020 - 05:29 AM
-2.5C last night here, that was enough!
#56 Tyson M
Tyson M
  • Loc: Canada
Posted 01 April 2020 - 12:26 PM
In Canada, if you want to observe, you learn to layer up haha, taking any conditions you can get.
I typically throw in the towel after -20C though(although I have gone out with binoculars at times).  It was certainly close last night but I got some good viewing in.
I brought my GF out and she caught some stable air with no transparency issues and was floored with the razor sharp detail of the leica zoom at approx 14-17.8 settings.
I caught some of this amazing detail too several times.  There was certain shadows and craters I was observing but not enough time to delve into a report over.
Edited by Tyson M, 01 April 2020 - 12:29 PM.
  • Scott in NC and gozer like this
#57 GroupJ
GroupJ
Posted 12 April 2020 - 09:06 PM
I'm enjoying this thread.  My first and only scope is a WO LZOS 102mm f6.5.  I love the scope but the focuser is not deserving of the objective lens.  I am in the process of installing a Clement Bellerophon III focuser and upgrading my mount.  I use mine almost exclusively for planetary observing  with binoviewers and was sorry I missed the total sun eclipse with the scope.
I like the idea of taking the scope on a plane and I have everything in pelican cases for short notice takeoff BUT I have never gotten on the plane with the kit.
That said I am curious about how this scope fits your needs compared to the Mewlon.  I have been thinking about a Mewlon as a planet hunter as I have read that they may be the best out there.  Can you please compare the views through the two scopes and which is the better planet hunter?
Also what made you sell the Mewlon?
thanks
Al
#58 stevew
stevew
    Now I've done it
  • Loc: British Columbia Canada
Posted 21 April 2020 - 07:46 PM
So can we assume that the end result of your analysis is that a top tier Japanese refractor with 15mm more aperture is a better scope...lol.gif
  • Scott in NC, m9x18, Tyson M and 1 other like this
#59 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 21 April 2020 - 08:30 PM
Apparently the jury is still out on this one.
  • stevew and m9x18 like this
#60 m9x18
m9x18
  • Loc: Abilene, Texas USA
Posted 21 April 2020 - 11:31 PM
Yes, they are all out under the stars. Or perhaps, banging away on their keyboards.  ; )
#61 Tyson M
Tyson M
  • Loc: Canada
Posted 22 April 2020 - 12:30 AM
thanks
Al
My seeing conditions mostly.  With a scope with such a large focal length, 3000mm, I could only use a 48 brandon and sometimes a 32mm most nights.  Rare nights allowed for a 24 brandon and 20X.
My TSA102S was putting up better planetary views many nights and I was all around enjoying it more.  More versitile.  The Mewlon was huge, although relatively lighter than it looks with an easy carrying handle which was the finder stalk.  Was a beast in my car, no case for it just a massive box.
I had a night of good seeing and on the moon it was outstanding.  The main issue is large aperture and long focal length needs good seeing and a tracking mount which is aligned well.  Best for an observatory.
YMMV
#62 Tyson M
Tyson M
  • Loc: Canada
Posted 22 April 2020 - 12:32 AM
The result was selling it to choose a scope that may fit my needs better.  My analysis was not 100% thorough on this scope but it will be on the TSA120.  I had enough sessions to know what I was getting into with the AP Traveller with deep sky and solar viewing.
  • gozer and 25585 like this
#63 25585
25585
Posted 22 April 2020 - 07:03 AM
That extra 20mm, and in so fine a triplet, is not insignifigant.
My TSA120 compared to FC100DL, both perfect scopes for their apertures, is better. Neither has any CA visible on Venus. For double/multiple stars, the fainter ones are more apparent & easier to split. More DSOs are better visible & in greater detail. Open clusters present a more immersive view, Orion nebula & the Pleiades nebulosity is more apparent & shows better lit by the bright stars in them.
My 120 has a more spacewalk feel in use than the DL. Milky Way views are incredible. Dream Tak is the TOA 150 of course, but a S-W Esprit 150 is more realistic financially.
  • gozer likes this
#64 peleuba
peleuba
  • Loc: North of Baltimore, MD
Posted 30 April 2020 - 02:06 PM
Tyson - looks like your Traveler is for sale on AM.
Edited by peleuba, 30 April 2020 - 02:06 PM.
#65 Tyson M
Tyson M
  • Loc: Canada
Posted 30 April 2020 - 02:10 PM
Surprised to see him sell it so quickly, perhaps he needed funds for the new Stowaway. Who knows.
Shouldn't last long...
Edited by Tyson M, 30 April 2020 - 02:16 PM.
  • peleuba likes this
#66 peleuba
peleuba
Posted 01 May 2020 - 02:13 PM
Yes - and I don't recall the seeing the large scratch that's now on the OTA.  Too bad as the black  "pebbled" paint is very difficult to touch-up.  The white A-P pebbled paint is easier to fix then the black.
Edited by peleuba, 01 May 2020 - 02:15 PM.
  • Paul G likes this
