Easy Refractor Carry Handle
26 replies to this topic
#1 eyespy
eyespy
  • Loc: BC Canada
Posted 22 March 2020 - 11:08 AM
While musing about an easy way to carry my Skywatcher Evostar 102mm F/9.8 refractor, I purchased a spare Dovetail Mounting Plate to match the one already installed on my refractor for tripod mounting purposes.
There are two convenient matching 1/4" x 20 tapped mounting holes for accessories etc on top of the tube rings of 'Synta' type refractors.  All that is required are two 3/4" long 1/4" x 20 bolts and two nylon 1/4" thick collars and install the second dovetail plate on the top of the tube rings.  The nylon spacers provide enough space to grip the plate when picking up or carrying your refactor.  I found that it was a safer hold if I attached the plate 'upsidedown' due to the edges of the plate.
These plates come in 8" and 13" lengths to match the plates already installed on your refractor so that you can use the existing spare drilled and tapped holes in the rings.
The new handle looks good and blends in and looks like it is a part of the telescope.  What handles have other refractor owners used or designed ?
Doug......
Edited by eyespy, 22 March 2020 - 11:29 AM.
  • payner, m9x18, ryanr256 and 1 other like this
#2 Rocket Ron
Rocket Ron
  • Loc: California
Posted 22 March 2020 - 11:21 AM
Here's what I came up with for my Astro Physics telescope:
https://www.cloudyni...ics-telescopes/
  • doctordub, payner, m9x18 and 3 others like this
#3 Cometeer
Cometeer
  • Loc: South Bay Area, California
Posted 22 March 2020 - 11:25 AM
I use the Vixen carry handle. It’s only secured with a single 1/4” bolt, so I wouldn’t trust it for large telescopes because if a telescope is tail heavy, it could swing itself loose from the handle.
The new William Optics handles look quite nice.
  • vkhastro1, m9x18, acommonsoul and 2 others like this
#4 junomike
junomike
  • Loc: Ontario
Posted 22 March 2020 - 11:26 AM
I use opposing Vixen Saddles as well.  ADM even offers a removable  Handle to attach to the Vixen Dovetail If desired. (Dual Vixen/Losmandy available also)
  • m9x18 and eros312 like this
#5 daquad
daquad
Posted 23 March 2020 - 06:38 PM
Well, I guess if your scope is small enough in length and weight it is OK to place the handle near the center of balance.  But for a longer, heavier scope the handle is better placed at the focuser end so that you can hold the scope by the handle in one hand and cradle the lens end in the other.  Of course, this requires an extra set of tube rings.
I also use a Vixen-style dovetail for a handle, but orient it right side up so that I can add accessories on the bar.
Dom Q.
#6 STE411
STE411
Posted 24 March 2020 - 06:33 AM
I made this from a drawer pull purchased at Lowe’s for about 5 dollars. It took a couple of hours not counting paint drying time. It works and I think looks pretty good.
steve
  • m9x18, MJB, clearwaterdave and 1 other like this
#7 imtl
imtl
  • Loc: Down in a hole
Posted 24 March 2020 - 04:52 PM
You should check ES cradle assembly
https://telescopes.n...-telescope.html
  • airbleeder likes this
#8 lionel
lionel
  • Loc: Delaware
Posted 24 March 2020 - 05:07 PM
The handle on my 130GTX is made of solid leather.  Leather trunk handles made in Maine are available from brettunsvillage.com. They come in different styles and thicknesses and are sold in pairs. I bought a heavy duty version, TH03...over 1/4” thick, 8 1/2” long with 1” long slots at each end. Total cost was $13 including shipping. They’re also available unslotted. I glued my pair back-to-back yielding a final thickness of 5/8”. This provided plenty of rigidity and stiffness to easily manipulate my 22 lb dressed ota.
Leather offers some advantages over metal bar handles. It makes a secure gripping surface for your hand and is comfortable to hold in cold weather.  I think it adds a touch of elegance as well.
The handle in the photo is ten years old and still looks like new. I originally installed it on my SV130EDT triplet and then transferred it to my new GTX two years ago.
Lionel
  • Heitman, m9x18, John Gauvreau and 4 others like this
#9 Doug Culbertson
Doug Culbertson
  • Loc: N. Florida
Posted 24 March 2020 - 05:21 PM
I actually replaced the tube rings and handle on my APM 140 with the cradle assembly for an ES 152 because the APM handle was too short and put the tube rings too close together. The ES assembly is great.
  • peleuba and imtl like this
#10 Kunama
Kunama
    Aussie at large
  • Loc: Canberra, Australia
Posted 24 March 2020 - 05:59 PM
I made a few handles for my scopes using aluminium bar stock and carbon fibre tubing, my TOA130NFB and TMB-LZOS152 handles pictured below:
  • peleuba, vkhastro1, 3 i Guy and 17 others like this
#11 Kunama
Kunama
    Aussie at large
Posted 24 March 2020 - 06:05 PM
and for some extra bling a silver version:
Edited by Kunama, 24 March 2020 - 06:08 PM.
  • peleuba, vkhastro1, 3 i Guy and 13 others like this
#12 gwlee
gwlee
  • Loc: 38N 120W
Posted 24 March 2020 - 09:36 PM
I find the tube itself makes an adequate handle for a 4-inch or smaller refractor, but perhaps my hands are larger than yours. I am right handed and carry the scope using two hands with my left hand wrapped around the tube’s balance point. My right hand is somewhere near the the scope’s objective end and both hands are pulling the scope in close to my body on my right front quarter with the focuser end of the scope pointing roughly in the direction of travel. If I need to open a door or move something out of the way, I use my right hand, and my left hand never leaves the balance point.
When mounting the scope, my left hand is still wrapped around the tube at the balance point, and my right hand comes off the tube and works the mount’s clamping mechanism. A bit of choreography is required to avoid awkward, what-do-I-do-now moments, but the scope feels secure and under control at all times once the sequence of moves is worked out. Nothing extra needs to be attached to the scope, keeping it as light and compact as possible for grab-and-go astronomy.
Edited by gwlee, 24 March 2020 - 10:39 PM.
#13 rustynpp
rustynpp
  • Loc: NYC
Posted 24 March 2020 - 09:45 PM
I think this is cheating since it came stock, but the handle was one of the reasons I chose the WO Zenithstar 103 over many other very nice 4" doublets, so I feel justified in posting it smile.gif Plus I believe you can buy the newer version of the handle direct from WO if you like.
  • peleuba, m9x18, eros312 and 4 others like this
#14 ryanr256
ryanr256
  • Loc: Southwest Ohio
Posted 24 March 2020 - 10:35 PM
I picked up one of these for my Stellarvue 102 Access:
https://www.teleskop...-Telescope.html
-Bob
#15 MJB
MJB
Posted 25 March 2020 - 11:29 AM
Made one from aluminum stock and a door pull handle from the hardware store ...
  • m9x18, daquad and STE411 like this
#16 Rick Duering
Rick Duering
  • Loc: South Texas
Posted 25 March 2020 - 12:42 PM
Posted 11 September 2019 - 02:04 PM
I’ve made a couple of these over time. The one inch steel strap and
handle comes from Home Depot. You will have to cut and paint the
strap to fit.  The handle come in either black or silver.
  • m9x18 and STE411 like this
#17 aa6ww
aa6ww
  • Loc: Sacramento, Calif.
Posted 26 March 2020 - 02:32 AM
My Skywatcher 120ED with a simple 4" wide handle from ebay for a few dollars. The rail is just a half in wide piece of aluminum from tube ring to tube ring.
I do this to every scope I have. Its simple and extremely effective.
...Ralph
  • vkhastro1, MJB and STE411 like this
#18 erraph
erraph
  • Loc: France
Posted 27 April 2021 - 03:14 AM
Hi everyone! Instead of opening a new thread on this topic, let me reply to this post even if it's a year old.
I wanted to share a solution to the "telescope handle problem", that is, a carry handle that costs much less than an eyepiece (otherwise I'd buy an eyepiece!), but doesn't look too crummy.
I use handles for amplifiers -- as amps can weigh quite a bit, these are sturdy enough for most telescope tubes, and are cheaply available for a large range of lengths / hole spacings (18cm, 20cm, ..).
The version I am using is a simple metal strip covered in rubber which costs around 2 dollars online. (Visually quite similar to the older Vixen handles!) Even if the rubber deteriorates one day, there will be the metal strip to avoid any accidents while lifting the tube.
  • BFaucett likes this
#19 aa6ww
aa6ww
Posted 27 April 2021 - 10:05 AM
I've bought the Astro-Tech handles for both my APM-152ED and AT-92. They are excellent. I also have one back ordered for my SW-120ED.
...Ralph
  • Gray likes this
#20 Don Taylor
Don Taylor
  • Loc: Broken Arrow (Tulsa Area) Oklahoma
Posted 27 April 2021 - 09:34 PM
I've posted this photo previously. It was "easy" but only because I had material and access to the machine tools in our prototype shop. The genesis was that I use the ADM "William" style dovetail bar which has discrete lateral slots - you can only attach rings at discrete locations - and I wanted a handle to match the ring spacing. So I made one. This handle also includes a mount to position the RDF further forward - and the handle tends to guide your eye to align with the finder.  I just polished this - but I should have it black anodized to match the other accessories on the 102F11ED. I made a similar, shorter handle for my 80mmF11 achro.
Handle for Starwave 102 F11 ED photo 1
Starwave 102 F11 ED Handle - Finished 1
Starwave 102 F11 ED Handle - Finished 2
Edited by Don Taylor, 27 April 2021 - 09:36 PM.
#21 ris242
ris242
  • Loc: Wellington, New Zealand
Posted 27 April 2021 - 09:52 PM
When I ordered one of these it was still the L shaped original but it came new and improved as in the picture.
https://www.bintel.c...?v=322b26af01d5
#22 clearwaterdave
clearwaterdave
  • Loc: Western Maine
Posted 27 April 2021 - 10:34 PM
#23 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 28 April 2021 - 12:44 PM
Would you happen to have a link to any online vendors for your amplifier handle? I couldn't spot anything as low as $2. Thanks.
#24 t.r.
t.r.
  • Loc: 1123,6536,5321
Posted 28 April 2021 - 02:05 PM
Leather strap (Dollar store belt cut to size) between the two rings...simple, easy, cheap yet adds a “classic” look.
  • tomwall and jeffmac like this
#25 sw196060
sw196060
Posted 28 April 2021 - 04:29 PM
Nice. For my Traveler I may just get a leather belt and make a strap by doubling it up. Should be strong enough and easy to hold in cold weather.
