Finder scopes with exchangeable EPs
54 replies to this topic
#51 Sky_LO
Sky_LO
  • Loc: Oregon USA
Posted 24 April 2020 - 11:27 PM
Sounds like folks have presented good options
I put an ETX -60 MM Meade refractor piggyback onto my Dob.
Used a triple shoe mounting bracket.
1) GLP to get you close.  (GLP is out of view - mounted on the back side)
2)  9 x 50 raci - for exact centering and for a five degree FOV
3) and the 60 x 300 Meade for a 2+ degree FOV  -( the 60MM  FOV can be changed as you can change EP )
The 60 MM was just under 3 pounds.
It did require about 7-8 pounds of counterweight to balance the DOB
Nice to have a wide FOV option for every object, with the ability to change EP.
-Lauren
  • Eliserpens likes this
#52 Eliserpens
Eliserpens
  • Loc: Corwhin, Ontario (13km SE of Guelph)
Posted 26 April 2020 - 02:20 AM
What EP do you find you favour in the 60X300?
#53 Sky_LO
Sky_LO
  • Loc: Oregon USA
Posted 26 April 2020 - 03:20 AM
15 mm for a 2+ Degree FOV
#54 Pogo007
Pogo007
Posted 09 June 2020 - 10:42 PM
The link to Agena appears to be not working so hopefully this works.
https://www.amazon.c...t/dp/B006IJECSI
Cheers, Chris.
Hi Elise
One issue people report with the Rigel Quik Finder has to do with its non-traditional base which does not fit in a traditional dovetail finder holder like the one on you scope.  However if you have access to a 3D printer I can provide you with an stl file that would allow you to print a base for the Quik Finder which fits a standard dovetail holder.
Cheers
Paul
Edited by Pogo007, 09 June 2020 - 11:02 PM.
#55 Eliserpens
Eliserpens
Posted 10 June 2020 - 06:15 AM
Hi Elise
Cheers
Paul
Thats a great service!  However, I bought a different brand that fits right in.  Thanks for the thought.
