Old C90 needs a kick
5 replies to this topic
#1 boyd
boyd
  • Loc: Florida
Posted 26 March 2020 - 10:15 AM
I’m studying the back on my c90. It seems there is a screw in spacer that either holds the scope together or stops down the exit to .965. Can this piece be removed and replaced with something that accepts 1.25”?
#2 Jeff Lee
Jeff Lee
Posted 26 March 2020 - 10:49 AM
Yes, It's called a Large Accessory Ring. The one that fits the ETX (I think) also fits the C90. On Amazon: https://www.amazon.c...d/dp/B000EINJRO
#3 G-Tower
G-Tower
Posted 26 March 2020 - 10:53 AM
I've tried removing one before to no avail....
#4 MCJ2087
MCJ2087
Posted 26 March 2020 - 11:19 AM
You may be referring to the backcell connection?  Try looking at this link:
https://www.cloudyni...nge-c90/page-14
That whole thread was interesting reading.
Edited by MCJ2087, 26 March 2020 - 01:35 PM.
#5 houndsbourgh
houndsbourgh
  • Loc: Hailey, Idaho
Posted 26 March 2020 - 12:53 PM
No. The eyepiece holder helps support the reflector assembly in the back of the OTA. They were threaded into place and set with epoxy.Very hard to get out. Best bet as mentioned above is a Large Accessory Ring (LAR) and visual back. Here is the Celestron, 3D printed ABS and Meade ETX rings with the Celestron93653-A visual back. Also available is a direct .965 to 1.25" eyepiece adapter. Very simple to use but I takes away a lot of your back focus.
Edited by houndsbourgh, 26 March 2020 - 12:58 PM.
#6 houndsbourgh
houndsbourgh
Posted 26 March 2020 - 01:08 PM
Oh forgot to mention the .965 to 1.25" eyepiece adapter also constricts the view over the LAR and visual back combo. Some users have run into problems on wider field 1.25" eyepieces.
