USB3 that I can terminate?
3 replies to this topic
#1 Cfreerksen
Cfreerksen
  • Loc: Tooele, Ut
Posted 26 March 2020 - 09:57 PM
I would like to run a USB3 cable through the CEM60 mount that I have but the hole in the saddle is small and the end will not fit. Is there a solution to a USB3 that I can run and then terminate the end myself?
TIA
Chris
  • OldManSky likes this
#2 Cometeer
Cometeer
  • Loc: SF Bay Area, California or Illinois
Posted 26 March 2020 - 10:00 PM
Use USB-C and then add a USC-C to USB-3 converter. USB C is slimmer than USB 3.
  • jdupton, Cfreerksen and OldManSky like this
#3 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 26 March 2020 - 10:10 PM
I just ran a USB 3 cable up through my CEM60 today :)
The simple solution is to remove the saddle and the existing port board on the back of the saddle (it’s not hard), feed the cable through, then put it back together. I didn’t run mine there, since I mount with Losmandy plates I just run it on top of the saddle in the Vixen plate slot, where there’s plenty of room.
If you haven’t watched this, I suggest you do :)https://m.youtube.co...h?v=Oy8ilrOm3vA
#4 Cfreerksen
Cfreerksen
  • Loc: Tooele, Ut
Posted 26 March 2020 - 10:39 PM
If you haven’t watched this, I suggest you do smile.gifhttps://m.youtube.co...h?v=Oy8ilrOm3vA
Thanks for the video.
Chris
