So, I took the 60mm Carton out 2 evenings ago along with my AT102ED, peeking through sucker holes in the beginning of the evening (see photo). I first observed Venus at ~100x in each scope I did notice approximately the same amount of CA in both scopes. Then waited until around 1:00 a.m. for the Moon to rise. Both scopes performed similarly up until about 100x then the larger aperture of the 102mm showed more contrast due to more light being captured (I assume), but the 60mm performed very well up to 200x where I stopped magnifying, the seeing was very good. All in all, the 60mm Carton f/16.7 performed very well as a lunar scope and it weighs much less than the AT102ED, so the mounting requirements would be much less, especially for a Grab-n-Go outfit.
But as I re-read this thread, the OP seems interested in the more modern 60mm f/6 ED scopes from AstroTech, William Optics and Apertura. I have an older 66mm WO f/5.9 refractor (similar to the 60mm F/6 scopes), and I have tried it on the Moon and other targets, but unfortunately with it's short focal length 388mm, vs 1000mm in the Carton f/16.7, the magnification of the short focal length scope was lacking. I find the short focal length scopes better for wide field sweeping, a step up from binoculars. I currently use the WO66SD for wide field imaging. I think you would be more satisfied lunar observing with the Mak or Refractors mentioned in your signature then with a short focal length refractor, it's just not the right tool for the job... Don't get me wrong it can be done, just like everything in this hobby there are trade-offs, it's just not optimal IMHO. In order to get a 200x magnification in the 60mm f/6 scopes, I'd need a 1.8 mm eyepiece. I have been longingly looking at these scopes, bit not for lunar or planetary observing...
Eyepieces used for Lunar observing: 21 XL, 14 XW, 10.5 XL, 7 XW, 5 XW. Yielding mags of 34x, 51x, 68x, 102x, and 143x in the AT102ED and 48x, 71x, 95x, 143x, and 200x in the 60mm Carton, respectively. I considered comparing some Abbe Orthos too, but it was late and cold...
Edited by Jaimo!, 12 April 2020 - 02:53 PM.
