Lunt LS60F filter different from LS60F DS filter?
3 replies to this topic
#1 cimar
cimar
Posted 02 April 2020 - 01:42 AM
is the Lunt LS60F filter that you attach to a night time scope in combination with a blocking filter different from a LS60F double stack filter that you add to a dedicated Ha scope?
Thanks.
#2 dhkaiser
dhkaiser
Posted 02 April 2020 - 08:00 AM
Don't believe so.  Read down the page...
https://luntsolarsys...h-alpha-filter/
#3 sunnyday
sunnyday
  • Loc: Ottawa,Canada
Posted 02 April 2020 - 08:32 AM
I think you should call faye at lunt's.
I doubt that many of these telescopes are already sold and that anyone can summarize.
#4 Volvonium
Volvonium
  • Loc: Long Beach, CA
Posted 02 April 2020 - 11:29 PM
LS60FHA, when used with a Lunt blocking filter and appropriate adapter can be used to mount on the front objective of any telescope for h-alpha viewing.   The same part is also used as a front double stack on Lunt 60mm tilt tune and pressure tune scopes.
It's the same part.
The LS60FHA is very pricy because it's a huge 60mm front placed etalon.  The prebuilt 60mm h-alpha scopes from Lunt use a smaller 35mm internal etalon that cost less than piecing together an h-alpha scope out of a ls60fha, while having relatively similar performance.
