1899 4" f/16 Cooke Photovisual Apo refractor
329 replies to this topic
#301 deSitter
deSitter
    Still in Old School
Posted 12 February 2024 - 11:22 AM
Hi gang, it's been a while since I worked on the Cooke, but it's finally back together again!
It's not finished yet, but I wanted to get it together, it's been in pieces too long...
My plan is to continue working on it, bit by bit until it's all done. In the mean time I'll be able to observe with it once I make a custom dolly that allows the scope to be rolled out the doorway.
Here's a mangled by compression image of it's current state:
Peter, why does the latitude yoke seem backward to me? Is it possible for the clock drive to operate with the position reversed? The pivot is centered on the pier so it would not affect CG considerations. But the clearance of the RA circle would be improved at high latitude.
-drl
  • col likes this
#302 Peter Ceravolo
Peter Ceravolo
Posted 12 February 2024 - 01:57 PM
-drl
I thought you were joking... but then I noticed there was no smiley face... :-)
Clearly the yoke was designed to work backwards!
  • deSitter, col, mdowns and 7 others like this
#303 Terra Nova
Terra Nova
Posted 12 February 2024 - 02:45 PM
Peter, it’s an absolutely beautiful telescope and a Wonderful restoration! Bravo!! waytogo.gif waytogo.gif
#304 oldmanastro
oldmanastro
  • Loc: San Juan, Puerto Rico-US
Posted 12 February 2024 - 03:44 PM
Superb restoration! What a nice precision instrument from earlier times. If you ever take some images with this beauty please post them.
#305 deSitter
deSitter
    Still in Old School
Posted 14 February 2024 - 06:06 AM
Hi gang, it's been a while!
I've not had the opportunity to continue restoration of the 4" Cooke Photo-Visual telescope, but I prepared a talk on the -
"Opto-Mechanical Analysis of a 1899 4" Taylor Photo-Visual Objective"
for last years Antique Telescope Society virtual convention. You can find mine as well as a host of other talks at this link:
https://vimeo.com/user161970464
Peter
This was a fascinating lecture. I thoroughly enjoyed that!
-drl
  • mikemarotta likes this
#306 mikemarotta
mikemarotta
  • Loc: Hays County, Texas
Posted 14 February 2024 - 06:24 AM
Fascinating. The work and workmanship are impressive, even humbling.
I archived the discussion here and captured a link to the ATS video of this and thie others on that Vimeo page.
Congratulations.
Mike M.
#307 Peter Ceravolo
Peter Ceravolo
Posted 15 February 2024 - 02:31 PM
I recently acquired spectral line filters of the wavelengths typically used to design refractor objectives:
(in nm) 436 (g), 486 (F), 546 (e), 588 (d) and 656 ( C ). That is; violet, blue, green, yellow and red respectively.
You can learn more about the emission lines used in optical design here:
https://www.telescop...t/chromatic.htm
These filters allow one to see the focus shift of the different colors and quantify an objective's residual chromatic aberration. They are small filters, so I simply rested them on thin double sided tape to hold them in place behind the Ronchi grating. The f/15ish beam made looking into the setup easy and the filters could be quickly swapped out. I rigged a dial indicator to my Foucault/Ronchi tester to measure any focus shift. In this set up the source and grating move together. The testing was done under autocollimation so it's quite sensitive. The objective was bolted to a gimbal type lab mount for easy alignment to the 16" flat.
  • col, TG, Lagrange and 3 others like this
#308 Peter Ceravolo
Peter Ceravolo
Posted 15 February 2024 - 02:40 PM
Testing with filters was interesting and quite colorful!
Note that the wavelength imaged and grating position is in the file name.
One of the first thing I noticed is that the objective was mildly undercorrected in the blue. The longer wave lengths were ideal though.
Edited by Peter Ceravolo, 16 February 2024 - 01:34 PM.
  • TG, RichA, Terra Nova and 2 others like this
#309 Peter Ceravolo
Peter Ceravolo
Posted 15 February 2024 - 02:43 PM
Here are the focus shift measurements:
wave length / focus shift
656nm / -0.015" (inside focus)
588nm / 0.000
546nm 0.000
486nm 0.000
436nm +0.030"
It was difficult to distinguish any focus shift for the central three colors. This testing technique is sensitive and crude at the same time, but it gives one a good idea of what's happening.
Here again are the details of the objectives construction:
Edited by Peter Ceravolo, 15 February 2024 - 02:47 PM.
  • deSitter, Lagrange, R Botero and 2 others like this
#310 deSitter
deSitter
    Still in Old School
Posted 15 February 2024 - 05:00 PM
Nice - it would be very interesting to rotate the elements relative to each other and retest. The most interesting part of your lecture was how you showed that the elements are all hand-matched by making the easy to make surfaces compensate for the hard to make ones.
-drl
#311 Peter Ceravolo
Peter Ceravolo
Posted 16 February 2024 - 12:56 AM
This is a chromatic aberration test, rotating the lens elements will have no effect on the results.
When I first started this thread I heard from Roland Christen who mentioned that his early triplet objectives are direct descendants of the Taylor triplets like this particular one. Interestingly though, Roland does not consider these Taylor triplets, or his earlier objectives, to be apochromats given the dispersion in the violet. They are semi-apos I suspect.
I have not looked through the telescope in a long time, but in past sessions looking at Venus I did not notice significant color. I'm looking forward to doing more critical observing when I can get the instrument out doors.
One of the things I'll be looking for is spurious reflections caused by the air spaced surfaces with nearly identical radii. These surfaces are notorious for producing problematic ghost images. I investigated a Brashear objective for ghosting effect here:
https://www.cloudyni...oley-telescope/
The Taylor objective has two sets of potentially problematic air spaced surfaces of near equal radii. The second set of surfaces are not likely to be a problem, mainly because the 5th surface was severely aspherized to compensate for surface figure errors in the previous surfaces. The ghost from this set might just be dispersed enough by the aspheric surface to be invisible.
All this investigation is for fun of course, the warranty on this 120 year old objective has expired I think...
Edited by Peter Ceravolo, 16 February 2024 - 01:02 AM.
#312 col
col
  • Loc: Jervis Bay, Australia
Posted 21 February 2024 - 07:40 AM
Hi Peter,
The scope looks fantastic, especially considering it's previous condition. Very well done.
Regarding the mount and its yoke, this picture of the "Equatorial Mounting Class B' from the1908 catalogue could be yours or a later version of it?
Regarding the naming of the Photo-Visual Objective, in both catalogues they are referred to as "Cooke's Patent Photo-Visual Objectives. For Astronomical Purposes. (H. D. Taylor's Patents.)".
Regards, Col Shepherd
  • Terra Nova likes this
#313 Peter Ceravolo
Peter Ceravolo
Posted 21 February 2024 - 01:26 PM
Hi Peter,
attachicon.gif Cooke Equatorial Mounting Class B-1908 catalogue - resize.jpg
Hi Col,
There are similarities for sure, but the mount in the catalog is still quite different from the unit I have. The polar pivot area in my unit is canted, the catalog drawing shows that mount head being vertical.
I've tried to find similar mounts to mine on this web site of T Cooke & Sons images without success:
https://dlib.york.ac...5914&ref=detail
Interestingly there are a few mounts pictured that were made for Dr. Hugh Walsham, the original owner of my scope.
  • col likes this
#314 Peter Ceravolo
Peter Ceravolo
Posted 22 February 2024 - 02:08 AM
One of the great things about this antique telescope is that it's a complete example, there are few missing parts of any significance.
But that doesn't mean there are no mysteries.
Case in point is the flip up cover the slips into the dew shield. It's a spring loaded device, I assumed that because there were springs in the package, but I could not understand how it functioned.
There was no obvious way to attach the now separate springs that either kept the cover open or closed. And I thought the springs kept the cover open.
  • tim53, col, R Botero and 1 other like this
#315 Peter Ceravolo
Peter Ceravolo
Posted 22 February 2024 - 02:21 AM
After discussion with fellow Antique Telescope Society members it was determined that the springs kept the cover closed.
The above mock assembly shows the springs intended position. You can even see the wear marks on the cover from the tips of the long spring arms.
But why did they get separated from the cover? There is no obvious signs of disassembly. And how did they survive once separated from the telescope?
One knowledgeable ATS member suggested that there was a tall post in the center that guided a string tied to the loop at one side of the cover that ran all the way to the observer. The operator, at the eyepiece, would pull on the string and open the cover. But the there is no obvious way to tie off the string by the focuser. One would think that there would be something obvious to tie off the string given the finesse of the cover design.
  • tim53, col, R Botero and 2 others like this
#316 deSitter
deSitter
    Still in Old School
Posted 22 February 2024 - 05:38 AM
Would be helpful to photography. Just open the shutter then pull the string slowly.
-drl
#317 Jumblesayle
Jumblesayle
  • Loc: Devizes Wiltshire uk
Posted 29 April 2024 - 03:57 AM
this is from my 5inch 1890,s cooke which suggests the arm with the hole in the end is missing from yours.
this arm allows a cord to pass through the eye and onto the sprung lid allowing you to pull the lid open and time the exposure etc.
  • tim53, col, R Botero and 4 others like this
#318 Peter Ceravolo
Peter Ceravolo
Posted 30 April 2024 - 12:41 AM
Very interesting, thanks for posting Jumblesayle.
One can see the same type of arm used in the telescope catalog drawing in Col's post above (post #312).
Examining the dew shield and flip cover on my 4" PV, I don't see the mounting holes that would accommodate such an arm. But there are holes in the center of my flip cover that I assume accommodate some kind of post arrangement that might have the same function, but I've not seen any such thing in catalogs or telescope examples... Curious...
  • col, R Botero and Ben Bajorek like this
#319 col
col
Posted 16 May 2024 - 09:25 PM
 Hi Peter,
I suspect that the shutter had a cantilever arm which was attached via the two holes and which was slightly cranked upward where it extended past the edge of the cap. A cord running down to the eyepiece from the end of the arm would operate against the spring tension to open the shutter?
I'll try attaching an image from the 1908 catalogue in another reply. It shows a more complex shutter but the arm where the cord presumably attaches is shown.
Re the topic of your mount, I tried a search for Dr Hugh Walsham and his mount on the original York Digital library site but without success.
#320 col
col
Posted 16 May 2024 - 09:44 PM
Cooke photo shutter.jpg Cooke Telescope from catalogue drawing showing objective shutter.jpg
 Hi Peter,
  • LU1AR likes this
#321 Peter Ceravolo
Peter Ceravolo
Posted 17 May 2024 - 03:12 AM
Hi Col,
The Cooke archives have changed, the Walsham referenced mount is no longer pictured.
I did find a number of similar flip covers, but detail is lacking....
  • tim53, col, Bomber Bob and 3 others like this
#322 col
col
Posted 26 May 2024 - 05:19 AM
Hi Col,
Peter,
I came across this image of a Cooke similar to yours in an earlier CN post.
It doesn't help with the flip cover question but does show there is at least another out there with your mount.
Col
https://www.cloudyni...d-45-refractor/
  • Josef1968, mdowns, Bomber Bob and 2 others like this
#323 Peter Ceravolo
Peter Ceravolo
Posted 26 May 2024 - 11:42 PM
Peter,
Col
Thanks Col!
That's the first image of a mount that resembles the unit I have. I'll have to contact Kunama for more info.
Peter
#324 col
col
Posted 27 May 2024 - 04:26 AM
Thanks Col!
Peter
Going on the backdrop, I think it might be at the old Mount Stromlo Visitor's Centre. According to the website it is currently closed. I went a there few years ago and don't recall seeing that scope. I'll be interested to learn what you find out.
Col
#325 mikef0924
mikef0924
  • Loc: Northern, NM
Posted 16 October 2024 - 11:36 PM
This is very enjoyable thread. Thanks for sharing!
Curious where you obtained the spectral line filters? Also what is their bandwidth ?
