I know of quite a few machine shops in the area, none of which use casting as a regular part of their process. In the 19th century, almost any manufacturing shop could create molds and send them off for casting at a relatively local foundry. It was the easiest way to get complex shapes, and was cost effective even for very small runs of parts. Today, with CNC machines, it is simpler to start with standard stock, and remove material, especially for short runs. Casting, now, is typically reserved for larger runs, where the higher setup cost can be amortized.
But that does lead to a different style of design. Who, for example, would program a CNC mill to generate raised lettering, rather than engraved lettering, on a part? When making a mold, it's easy and low in cost to raise the lettering. When milling, it means taking a whole surface down to a lower level around the letters.
I was saying that I have an appreciation for these differences in the many small-run parts that one sees in antique mounts that were built from castings that often incorporated aesthetics that appealed to the maker.
Chip W.
