How Disable Meridian Traitment on CEM25P
3 replies to this topic
#1 vincex256
vincex256
Posted 03 April 2020 - 02:34 PM
Hi all, anyone know if is possible to disable meridian treatment on Ioptron CEM25P?
Thanks to all
Inviato dal mio SM-G975F utilizzando Tapatalk
Edited by vincex256, 04 April 2020 - 02:47 AM.
#2 Chuckwagon
Chuckwagon
  • Loc: Orem, Utah, USA
Posted 04 April 2020 - 02:37 PM
What do you mean by disable?  Do you mean "turn off" so the mount can keep tracking until it collides?  That's not a good option, and the mount doesn't allow for that.  You have two choices, flip or stop tracking.
You can control the behavior in the Settings menu.  The manual gives the following;
"5.4.7. Meridian Treatment
This function tells the mount what to do when it tracks past the meridian. You can tell the mount if it
needs a meridian flip and when to do it.
     'Set Position Limit' will tell the mount when to stop tracking or to do a meridian flip. The limit
can be set at from 0° to 10° (40 minutes) pass meridian.
     'Set Behavior' will determine if the mount will stop tracking or perform a meridian flip at the set
position limit."
So it cannot be turned off (disabled) but you can control what it does.
  • vincex256 likes this
#3 vincex256
vincex256
Posted 04 April 2020 - 02:51 PM
Hi Chuckwagon, i have ask about, because asiair pro can control meridian flip, but to do this need that meridian treatment in mount, must be disabled.
Edited by vincex256, 04 April 2020 - 02:52 PM.
#4 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 04 April 2020 - 06:14 PM
No it doesn't.  You just need to set the ASIAIR to do it before the mount does.  In the ASIAIR, set it to do a meridian flip at, say 5 degrees past the meridian.  Then set the mount to stop tracking 8 degrees past the meridian.  The ASIAIR will now perform the flip before the mount hits its limit, and the mount will still stop tracking, saving your mount and pier, just in case the ASIAIR has a problem or crashes.
  • Chuckwagon and eros312 like this
