Marco,
John is right, with the helical mod - you should be good to set and forget.
But in the spirit of discussion, yes, it probably is possible with the original sled focuser.
It will require some fabrication / ingenuity to make it work. I remember seeing a post on here, where a user adapted an older Celestron / JMI Motofocus unit (from a C8 SCT) on to his Comet Catcher. It wasn't very detailed about how he made it work, since that wasn't the main thread. I can dig around and see if can be located in the archives here, and if so - I'll edit in a link.
Now, that is something that I have also been slowly working on, for one of my Comet Catchers. I already had the JMI Motofocus unit from my Celestron C8, and I also had a few spare adapters (for the knob attachment) and other parts.
This is only been something I have tested a few times, so it is not a proven setup. You will also need to make a bracket to mount the Focus Motor to the tube, aligned with the focus knob on the scope - I made a simple bracket out of thin aluminum that worked, but I scrapped it. Something better could be made.
Here is a picture of how I adapted the Motofocus bushing/adapter to the Comet Catcher knob:
I used a section of PVC (grey) electrical Conduit, sized to fit over the Motofocus adapter (which is plastic) and epoxied the two of them together. The Larger PVC fits over the Comet Catcher Focus Knob, and is secured with three small allen/hex set screws. This required drilling and threading the grey section for the set screws. This adapter doesn't interfere with operation of the focuser, and just barely clears the Sled assembly. It was kind of a prototype thing with parts I had, and surprisingly it worked pretty well.
The motofocus I used was an older vintage unit - that hasn't been sold in years. It has a mini jack (1/8" headphone style plug.) and for testing, I used a Rigel Systems NFocus designed for those older steppers. It wasn't wireless, but it worked. I imagine with some work, a wireless version could be made or adapted to work.
I haven't had the motor on that scope finished yet, since I was working on fixing other problems with the tube itself (repairing holes - it's a topic on here) and dealing with other issues. I hope to fabricate a better bracket this winter (perhaps removable) so the motor can be added/ removed more easily.
So yes, doable - wired. Wireless? possibly.
Temp
