Issue with DEC Axis at the Skywatcher EQ-5
2 replies to this topic
#1 xthomas81x
xthomas81x
  • Loc: Schwerin, Germany
Posted 04 April 2020 - 09:55 AM
Hello,
i have an issue with my EQ-5. Ich will show you 2 pictures of the guiding graph in PHD2:
here for a longer time and you can see the failure:
https://image.jimcdn...55365/image.jpg
and here a shorter guiding time, between the failure the mount works fine:
https://image.jimcdn...55395/image.jpg
Hope anyone have an idea or solution what i can do.
#2 sg6
sg6
  • Loc: Norfolk, UK.
Posted 04 April 2020 - 10:23 AM
Without knowing a great deal of the graphs the usual answer is: Strip, clean and rebuild. Dec axis on the HEQ6 and EQ6 and I expect the EQ5 is kind of well known to be weak.
Many will replace the bearings, certainly the stuff Skywatcher call grease.
Be careful of the small weird cone at the end, that takes some setting up correctly.
Took me 3 attempts, the first 2 were working out what was going on. Getting the grub screws in was "entertaining" to say the least.
Search out "astro baby" and see if she has a guide for the EQ5. Half suspect not as Mel did the HEQ5 and EQ6.
Might find the UK SGL forum has greater experience, knowledge as the miount has been around the UK for some years and is popular.
But Dec axis and Skywatcher are not a great combination. Especially that goo.
#3 xthomas81x
xthomas81x
Posted 05 April 2020 - 05:12 AM
Thank you,
i can fix the drift when i change the setting in DEC to guide in one direction.
