Celestron CFM and Firmware Update
Celestron mount equipment
6 replies to this topic
#1 Derry 571
Derry 571
Posted 06 April 2020 - 05:40 PM
I've been trying to download and use Celestron's CFM application to update and install the latest firmware in the Celestron NexStar+ hand controller that came with my Celestron CGX mount.
The CFM application is written in Java.
My current computer is running a 64bit Windows 10 Pro operating system. I use Google Chrome and sometimes Firefox as browsers.
I need to download and install Java so I can open and run CFM.
Google Chrome and Firefox no longer support NPAPi (required for Java applets).
I've tried changing security settings, paths, using Internet Explorer, no luck downloading and installing Java. Java says it's installed but it won't open CFM.
I've read a lot of suggestions and watched a lot of videos about how easy it is to download and run CFM but they're all old information and no longer work. Things change!
I need a solution that'll work now, 6 April, 2020. Hope someone has an easy fix. I'd appreciate it.
  • 5dave likes this
#2 houndsbourgh
houndsbourgh
  • Loc: Hailey, Idaho
Posted 06 April 2020 - 06:48 PM
I have had good luck with the jarfix runtime patch on my windows 10 machine.
  • 5dave and Derry 571 like this
#3 Derry 571
Derry 571
Posted 07 April 2020 - 12:08 AM
Jarfix seems to have worked!!! Thank you so much. I've been banging my head over this problem for three weeks. WHEW! If I were in a position of authority, I'd see to it that you got a little something extra in your paycheck this week. Unfortunately I'm not in a position of authority.
  • 5dave likes this
#4 greenstars3
greenstars3
  • Loc: Wind River valley
Posted 07 April 2020 - 01:33 AM
Derry 571
Welcome to Cloudy Nights
Glad you asked this question as I will be attempting the update process for my AVX
Houndsbourgh thanks for the answer.
Robert
#5 bella luna
bella luna
  • Loc: Covina ca
Posted 09 April 2020 - 10:45 PM
Derry 571   Thank you so much for starting this topic.  Also thank you all who contributed.
                    I have been trying for months and months to get CFM to work.  Now I finally did it and I'm up to date                       with everything.    Thank you again to all
#6 5dave
5dave
  • Loc: Arizona
Posted 02 May 2020 - 04:23 PM
houndsbourgh:
You nailed it. I have been trying to fix this issue for a week now, was about to give up when I read your Jarfix comment. After loading Jarfix CFM opens and works fine.  Thanks to Derry 571 for opening the question and you for your answer.  bow.gif waytogo.gif banjodance.gif bounce.gif
#7 lov2krz
lov2krz
  • Loc: Morgan Hill Central Northern California Boarder
Posted 12 May 2020 - 05:42 PM
Thanks for the Jarfix patch information.  I've updated my firmware several times using the CFM but for some reason Java Runtime Environment wouldn't recognize the jar file. Installing the patch got CFM to download the files for my StarSense HC/Camera and my CGEM  mount and I started the update.  Now the update is stuck on 2/6 at 4% for the last 15 minutes.  I'll need to contact the all-knowing discussion for updates using CFM and SS.
Here's the  link to the jarfix download  https://johann.loeff...rfix/index.html
Also tagged with one or more of these keywords: Celestron, mount, equipment
