Meade LXD75 Autostar
8 replies to this topic
#1 MarkPav
MarkPav
Posted 07 April 2020 - 02:09 PM
Hi. Not sure if this is the right forum. I recently bought a used LXD75 with autostar. The curly cable running from the handcontroller was wrapped around the tripod and pulled apart. Where would I get another cable or find a pinout chart so I can get one made. I thought it was just an 8pin xover but when I bought one there is no power running to the handset, (the screen doesn't light up).
Edited by MarkPav, 07 April 2020 - 02:10 PM.
#2 sg6
sg6
  • Loc: Norfolk, UK.
Posted 07 April 2020 - 02:26 PM
Rather simply try an astronomy retailer.
It will be safer to get a Meade one.
Could suggest a retailer but are you UK, EU, US, Canada, Aus, S America? Where ???
The question "Where can I get" is rather related to "This is where I am".
You I hope know where you are, we have no idea. Especially on a first post.
#3 fishonkevin
fishonkevin
  • Loc: Michigan
Posted 07 April 2020 - 02:38 PM
How about here?  http://www.scopestuff.com/ss_l5hc.htm
#4 ks skyhawk
ks skyhawk
Posted 07 April 2020 - 02:54 PM
Here's a link to the old Michael Weasner website with wiring information http://www.weasner.c.../as_cable3.html
There's a lot of info on the LXD models and Autostar there http://www.weasner.c...ostar_info.html
#5 richorn
richorn
  • Loc: Rancho Palos Verdes. CA
Posted 07 April 2020 - 03:43 PM
Be careful using a "random" cable.  Incorrect wiring can in many cases damage internal components.
#6 OzAndrewJ
OzAndrewJ
Posted 07 April 2020 - 04:04 PM
Gday Mark
The 497/Audiostar curly cable is pinned 1-8.. 8-1
ref
http://web.archive.o...rg/pinouts.html
The outer 2 conductors are +12V and ground.
If you used a 1-1..8-8 type cable ( like an RJ45 patch cable ),
you may have reversed the polarity.
#7 MarkPav
MarkPav
Posted 07 April 2020 - 05:44 PM
Thanks everyone for the good advise.  I'm from Western Canada so I will research out a proper Meade Curly Cord.
Assuming the cord I used was incorrect,  would there be damage done to mother board etc. ?
Is there an electronics repair ship anyone would recommend if needed.
#8 OzAndrewJ
OzAndrewJ
Posted 07 April 2020 - 05:58 PM
Gday Mark
Dont know, as normally, people put reverse polarity into the power socket
and this blows traces on the power switch panel.
Not sure what putting reverse polarity into the handbox would do.
With luck, it may just blow a noise filtering inductor, buit you will need to check.
All you can do is try powering it up and see if it works.
#9 MarkPav
MarkPav
Posted 07 April 2020 - 07:35 PM
Thank you Andrew
