Can you control a Skywatcher EQ6 R Pro from the Asiair Pro? The EQ6 mount takes between 2.5 and 4 amps depending on the voltage? I'm thinking not? So that would mean I would have to have 3 separate power supplies. One for the mount, one for the air (with the ZWO ASI294 cooled camera and a 120 mini camera) and one for the dew heater controller. If this is really so, can I get a 20 amp regulated power supply and split it into three separate output cables and control everything with that one supply? Is that feasible without causing unwanted interference? It would be a 120v supply to DC as I would be at home. I'm not interested in 12v battery control. What does others do and how do you set things up?
