Celestron firstscope 80
108 replies to this topic
#76 ericb760
ericb760
  • Loc: Palm Springs, CA
Posted 28 May 2024 - 08:44 PM
Here’s a pic of the one I mean:
I have owned the 90mm Firstscope on that same mount. The 80 and 90 share the same sized OTA. Truthfully, that EQ-2 mount (or its equivalent) is vastly underpowered for this size OTA. It shakes in the slightest breeze and takes forever to settle down after the smallest bump. I still have the Japanese made C80 but I use it alternatively on a Vixen Polaris mount on a wooden tripod or a Celestron/Meade AZ-3 mount on the aluminum one. I like the aluminum tripods for their weight and transportability. When paired with a decent mount they work fine. If you do buy this one I highly recommend upgrading to a more robust mount. here is a pic of a Meade 80mm on the AZ mount.
Meade 310
  • Terra Nova, Bomber Bob, LU1AR and 1 other like this
#77 Look at the sky 101
Look at the sky 101
  • Loc: Citizen of the earth .
Posted 28 May 2024 - 08:50 PM
ah how I would love to have another one, it was my first telscope.
very good for starting out in astronomy.
  • Bomber Bob likes this
#78 GeneDiG
GeneDiG
Posted 30 May 2024 - 08:44 AM
That's the Synta made version. While I do not own a Vixen model, I like my Synta made 80EQ. The EQ2 mount does OK, it could be better. Mine is on wooden legs which I think helps.
  • sneeds and Bomber Bob like this
#79 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 30 May 2024 - 11:27 AM
Yes, it is.  I started this insanity at age 8 - too young for a C80.  But by 13, I was responsible enough for one - I babied my Sears 60 F15 EQ.  An SP-C80 would've set me up for at least a decade - maybe two.
  • GeneDiG, photiost, Look at the sky 101 and 1 other like this
#80 LU1AR
LU1AR
Posted 30 May 2024 - 01:38 PM
A simple, economical and easily reversible solution; It would be to hang a thick chain inside the pier.
The nature of the chain -together with its weight- makes it accommodate vibrations and puts them out of phase. At the same time; the friction between the links, exhausted it.
Those of us who enjoyed those long Japanese refractors in the 60's; We know that hanging a chain from the front, was the solution to those weak mounts.
Hope this can help you.
Edgardo
  • sneeds likes this
#81 sneeds
sneeds
  • Loc: Canada
Posted 31 May 2024 - 10:31 AM
I can also run my eq-2 in alt-az mode which tends to help as well.
So Synta Firstscope 80 optics are generally good?
Edited by sneeds, 31 May 2024 - 10:33 AM.
  • Princess Leah likes this
#82 Princess Leah
Princess Leah
Posted 02 June 2024 - 05:13 AM
Edgardo
Good idea.
Inside the pier?
Where is the pier in an EQ2 mount?
#83 Princess Leah
Princess Leah
Posted 02 June 2024 - 07:32 AM
What is the outer diameter of your Japanese C80? It's usually quoted as 9cm, but I always think it looks bigger than the Meade which is also 9cm. Some sort of optical illusion?
#84 ericb760
ericb760
Posted 02 June 2024 - 07:46 AM
I use the same set of 90mm rings on both the Meade and the Celestron OTA's.
  • Bomber Bob and Princess Leah like this
#85 Princess Leah
Princess Leah
Posted 02 June 2024 - 11:51 AM
This is also 9cm (the blue Omcon), looks as slim as your Meade. But the C80 looks more chunky to me. Perhaps it's a shorter tube, with a longer rack and pinion?
  • ericb760, Bomber Bob and LU1AR like this
#86 Princess Leah
Princess Leah
Posted 02 June 2024 - 12:29 PM
Some kind soul, could perhaps salve my unusual curiosity in such matters. One could sacrifice a small percentage of their day, and place a small wooden stick, with equidistant units, portrayed by numbers (also known as a ruler). That said wooden stick, would then reveal to a degree of precision, that would undoubtedly be of goodly satisfaction, the lateral distance involved, from one side of a C80 (Vixen) to the other.
#87 ericb760
ericb760
Posted 02 June 2024 - 07:39 PM
Diameter
  • Bomber Bob, jcruse64, LU1AR and 1 other like this
#88 Princess Leah
Princess Leah
Posted 03 June 2024 - 03:02 AM
Very kind of you Eric. Thanks
#89 Princess Leah
Princess Leah
Posted 03 June 2024 - 03:05 AM
Is that the Meade. Or Celestron C80 in blue?
#90 ericb760
ericb760
Posted 03 June 2024 - 03:23 AM
That is the Vixen/Celestron C80, but my Meade #310 is the exact same diameter.
#91 Princess Leah
Princess Leah
Posted 03 June 2024 - 04:54 AM
Thanks Eric. I've never seen a blue Celestron C80 before. My friend has a black Celestron C90 vixen/firstscope and the tube measures 100mm in width.
Seems to be some variation, as others have reported the C90 firstscope using the same tube as the C80.
The black Celestron tubes of the 80s always look like 100mm wide OTAs to me in pictures.
#92 Princess Leah
Princess Leah
Posted 04 June 2024 - 04:33 AM
I have just measured a black C80 'premium' Vixen made. It also measures 9cm. However it looks wider to me. Some kind of optical illusion.  I would have thought black would have made it look slimmer.
#93 Kasmos
Kasmos
  • Loc: So Cal
Posted 04 June 2024 - 02:13 PM
None of the Celestron C80s were Blue. It's the lighting and or the camera making you think it is.
#94 jacklee
jacklee
Posted 16 December 2024 - 11:15 PM
Hello everybody,
    I just joined this group ( Cloudy night ) &  I saw this forum " Firstscope 80 Celestron ). Yesterday I bought a used 80 AZ, with black wooden AZ tripod for $40 at Craigslist. I am cleaning the dirty objective lens now. I have it out, but I saw 3 small white spacer inside the lens edges.DSCN0227.JPG Maybe this objective lens got 2 elements. Got dust inside. Any advice will be highly appreciated. Thanks.
#95 grif 678
grif 678
  • Loc: NC
Posted 17 December 2024 - 02:12 PM
The spacers need to be there. If you have to take apart, put pencil marks on the edge of the lenses where the spacers go, also put arrow marks on the edge of each lens, so you will have each lens turned the right way when you put it back. There are posts somewhere here on CN, with photos showing how to mark the lenses before you take them apart. I would find that before I would attempt to take them apart, because if you turn one of the lenses the wrong way, you have a mess. If you can not find that photo, just make a post here on Classics, asking someone to show a picture or photo of how to mark your lens.
  • jacklee likes this
#96 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 17 December 2024 - 03:58 PM
I was looking at a celestron firstscope 80 from what I found on the web was I believe model 21075 on the label it said made for celestron in Japan I’m trying to find more specific is it worth getting
there is an old cometron on facebook.
#97 Princess Leah
Princess Leah
Posted 22 December 2024 - 07:01 AM
I've just recently acquired a Celestron C80 that is made in China. It has better coatings/light throughput than my Japanese C80.
Optically it seems somewhat better than the Japanese version which suprises me.
The tube is 9cm wide, but is somewhat lighter than the Japanese equivalent.
Anyone else have an early Chinese C80 to compare?
#98 deSitter
deSitter
    Still in Old School
Posted 22 December 2024 - 11:47 AM
Automatically generating nice achromats has become easy it seems. But check the smoothness - the Vixen is probably still much better there. You may just be seeing a brighter image from modern coatings. Which is important after all!
-drl
#99 jacklee
jacklee
Posted 22 December 2024 - 12:14 PM
Hi grif 678,
           I will follow your suggestion. Thanks for replying and also thanks for that tips.
#100 Princess Leah
Princess Leah
Posted 22 December 2024 - 01:21 PM
-drl
Smoothness? You mean the focuser?
I compared it also with an uncoated Prinz 76mm F16. I rate this scope highly.
However the Chinese refractor gave a much sharper image - it was pretty obvious.
Perhaps it was just luck - will try again another night.
