It's the bolts, not the straps.
I've been working away at a solution using draw latches. Will post when complete.
Posted 15 April 2020 - 09:16 AM
Posted 16 April 2020 - 03:43 PM
The straps are definitely the weak link on this scope. Or at least they were!
I made up some brackets which I mounted to the stand after drilling and tapping some screw holes. Then I added draw latches.
Posted 16 April 2020 - 08:11 PM
Your latches are great , and going to a larger size a wise move .. with locking pins no less you shouldnt worry about losing the scope now ..
Your tube looks as if it's the next project ... mine was mush , the water stains aren't that bad and could be painted over if you want to go that route . The tube itself is a thick fiberboard , much thicker then sonotube as I found out .
Since I'm a fabricator by trade it was easy for me to lay up a new tube in fiberglass using a sonotube as a base .
After a few days of setup, a once over with sandpaper, a layer of silk glass then paint .
The drilling of the holes , and placement was a simple swap .. however collimate the primary, secondary, focuser was at first a nightmare , but with a laser collimate and patience I was able to get near perfect ..
That first night out, after a long cooldown is when I realized my efforts paid off ..
The Meade 10 Starfinder is a great classic well worth the referb .
Stevegeo
Posted 17 April 2020 - 06:56 AM
Thanks, I'm real happy with how it turned out.
Yes the tube is next. I'm looking for a new focuser currently to replace the plastic one. Once I have that ready to swap I'll break the whole thing down and refinish it. I was planning on light sanding, fill any areas that need it, prime and paint.
What is the weight of the fiberglass tube compared to the fiberboard? I'd be interested in hearing that process and how you get the new tube off the old one.
Posted 17 April 2020 - 07:32 AM
Edited by Sheridan, 17 April 2020 - 07:34 AM.
Posted 17 April 2020 - 12:29 PM
Congrats on your find! That was also my first scope and I still have it. You're going to enjoy it a lot.
You might want to replace the standard focuser with a 2 in.
I'm looking into that now, but its hard to know what to get. I don't want to spend a fortune but definitely want a better focuser.
I'll refinish the tube at the same time.
Posted 18 April 2020 - 08:25 PM
Great looking scope!
Posted 18 April 2020 - 09:19 PM
Plugged in my lx200 after 13 years in the Box climate controlled main board fried. Plugged in starfinder 10 works like a champ. This covid-19 stuff leaves me too much time at home. At least I still have a scope to use
Edited by Sheridan, 18 April 2020 - 09:19 PM.
Posted 18 April 2020 - 09:20 PM
Beautiful scope
Great scope!
My buddy turned his into a Dobsonian about 20 years ago.
Great mirror! Lots of light and resolution.
It's hard to beat a good ten inch.
Posted 20 April 2020 - 06:51 AM
Got out last night for a while. Was trying to find some of the DSOs around Ursa Major but no luck. Light pollution here really washes out the sky.
Attempted Star hopping for the first time. Didn’t have as much luck eyeballing it as I’d hoped. I’m thinking of picking up a proper star atlas and drawing up some FOV rings to help.
Any recommendations for DSOs that I should be able to find in these Bortle 8 skies?
Posted 25 April 2020 - 08:01 AM
Moving on, time to clean up the tube! Picked up the supplies yesterday and got everything stripped down. Only bummer was that I had planned to roll on the appliance paint, but spray cans were the only thing available. I bought enough to redo the freezer while I'm at it.
I'm going to sand it down and fit the new focuser today. The paper on the inside is peeling slightly at the seams so am going to thin down the Titebond III and seal that up. I grabbed some bondo but think the high-build primer will be sufficient to smooth out the exterior.
More to come!
Posted 26 April 2020 - 08:19 AM
Great day yesterday. I grabbed this for $120 on clearance! Always wanted one and am excited to finally learn how to use it.
Back to the scope! I painted the inside with a flat black. I was going to add peel-and-stick felt, but I couldn't get any from Michaels in time.
And finally, after sanding down the filler, hit the outside with a hi-build primer.
Posted 26 April 2020 - 07:25 PM
Painted and (mostly) reassembled!
I like the appliance enamel and will definitely use it again. Probably could have got it a bit smoother, but it seems like it will be very durable.
Posted 27 April 2020 - 06:39 AM
Posted 27 April 2020 - 06:23 PM
Tube came out good.
Posted 27 April 2020 - 08:54 PM
Tube came out great! It looks even better after curing for a full day.
regarding the straps, I think it was already fatigued. The draw latches work so much better though so I’m happy that I did it.
Posted 28 April 2020 - 02:36 AM
Posted 28 April 2020 - 06:27 AM
Posted 30 April 2020 - 07:56 AM
And the final touch is on! I decided to update the decal design and am glad I did.
The balance was waaay off with the new hardware installed and I didn't feel like I ever got it dialed in. The drive needs the scope to be perfectly balanced to track properly so I'll need to work on that. I'm going to take some time to just enjoy it now but plan to take a look inside the motor eventually and clean it up. And while the straps are working much better I'm going to build plywood rings later, both to secure the scope better to the mount and to avoid them springing all over the place when taking the scope out.
Posted 18 June 2020 - 10:52 PM
I picked up an 8" Starfinder a week ago and am looking to refurbish it much in the same way as you did. The mirror, secondary and tube, whilst all are grungy, seem salvageable. Only the cheesy focuser am i ready to replace. Even the 8x30 straight-thru finder has hope. Picked mine up for $80. The pier seems to be in good working order, but i am missing one of the 3 legs. might you have a lead as to where i could pick one up? I will post pics of mine in a couple of days.
Posted 19 June 2020 - 08:20 AM
lowroller21,
Thanks for posting your project, it's been fun to follow.
I agree with CHASLX200, there are several reasons for getting mushy images at high magnification. Some you can control, some you can't. The biggest is seeing (the steadiness of the sky), can't control that. Observing objects over a building roof, not allowing your scope to reach thermal equilibrium, poor collimation, badly made optics are all causes of soft images.
I was going to suggest posting some photos of your old focuser as I have fixed junk rack and pinion focusers before, but you said you were going to replace it. Then I was going to suggest the GSO Crayford, but you'd already bought it.
I live in the same part of the country you do and am rarely able to use magnification above 300x.
There are plenty of good eye pieces not made by Tele Vue. Explore Scientific gets high marks on Cloudy Nights. Baader, the Paradigms, Meade HD60 and others all have supporters, too. One thing to think about is how wide a field you actually need for the observing you do. Plossls are relatively inexpensive, can be of very good quality, but have a 50o apparent field of view. Plenty if you're observing Jupiter or a double star. Plenty if you use a mount which tracks. Not so good if you want to sweep the Milky Way, or are letting objects drift because your mount doesn't track. At home, I use Plossls exclusively to observe the moon and planets. Also, as CHASLX200 says, there's the used market...
If you're patient, you might be able to find a Paracorr I used. Explore Scientific and Baader also make coma correctors. You may find you don't need one, though. I almost didn't buy one for my 10" f/4. For high power viewing I really don't need it since I'm only using the central part of the field anyway. Since your Star Finder mount tracks you may find you spend most of your time looking at the center of the field rather than letting an object drift across the field. If that's the case, you might not notice whatever coma your scope has.
Perhaps some wheels for your mount? And some jacking bolts to keep it in your observing spot and polar aligned?
I hope you enjoy your scope, your restoration work looks great.
Posted 27 June 2020 - 12:42 PM
That's a very nice restoration job! Giving me food for thought: I also have a Meade SF 10 I bought in '93. I'm very fond of it but I've never had any luck tracking anything - the motor works, I can hear it going, but it doesn't turn the scope in RA at all so everything drifts. Funny thing is, when balancing I can move the counterweight almost anywhere on it's rod and the scope seems to remain balanced. Could it be the clutch is too tight, or maybe the whole thing needs stripping and cleaning?
Posted 27 June 2020 - 01:42 PM
Seems like the other way 'round: the clutch is too loose allowing the motor to run without turning the worm wheel.
Posted 27 June 2020 - 01:47 PM
$80 for a complete kit? You did great. I paid $100 for my 826 OTA.
I put a Lumicon helical focuser on mine, with the coarse focus sliding tube:
There are probably folks on this Forum with spare feet for your pedestal. My short one is a mix: Meade SF mount & pedestal, but with much older Edmund cast iron feet.
On most objects, my 826 performs like a 5" or 6" APO -- can seriously challenge my 2017 APM 152ED.
Edited by Bomber Bob, 27 June 2020 - 01:56 PM.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
