Captured just before (or actually into) astronomical dawn under red/orange zone light pollution on April 16, 2020 using a Celestron C6 and an uncooled QHY5III-178C camera (gain 30, offset 8, in SharpCap). This was taken at the end of a full night of imaging and I just wanted to take a "quick" shot to see how the Ring Nebula looked as dawn began. I was using unguided imaging on a Mach1GTO mount with a base exposure of 5 seconds and thus this is a stack of 180 frames producing 15 minutes of total integration time (180 x 5s = 900s = 15 minutes).
This just goes to show how bright of an object the Ring Nebula is even at f/10. I was also pleased with the resolution and I must have had pretty good seeing conditions because I was able to capture the Ring Nebula's double-double star that is below the nebula at about the seven o'clock position. I've also included a 1X scale crop showing those four stars with the faintest pair having a separation that may be only 1.3 arc seconds. This is only the second time that I've been able to clearly resolve the faintest pair and on my previous success I was using a 9.25" EdgeHD with a cooled, monochrome ASI178MM camera.
For more information on the double-double you can reference this post on CN that I made a few years ago (with more images):
https://www.cloudyni...dpost&p=9429723
Interestingly enough, the FWHM on this image is kind of "crazy" at a measured 1.27 arc seconds, but I've checked the measurement several time using both PI's FWHMEccentricity script and PI's DynamicPSF tools (depending upon the model and the sensitivity I get measurements that remain consistent with that value). I'm pretty sure this is a record for me when using a one-shot-color camera (for a DSO), but note that the original image scale is just 0.3 arc seconds per pixel (plate solved, with the 2.4um pixels on the 178C). The larger image below is cropped and reduced in size to conform to the CN posting guidelines.
Image capture with SharpCap, image processing with PixInsight and Photoshop CC2019.
C&C welcomed as well as any previous references to the Ring Nebula's double-double star (have you ever resolved this feature?).
Edited by james7ca, 18 April 2020 - 02:47 AM.
