Gemini GTD E.Fric new mount or?
astrophotography equipment mount
117 replies to this topic
#101 Paul Garais
Paul Garais
  • Loc: Sendenhorst, Germany
Posted 30 August 2020 - 12:05 PM
attachicon.gifIMG-20200822-WA0006.jpgHi Paul, this is so far closest to your 6" APO, I hope the owner will soon share some info or guide graph!
András
Looks great :). Thank you again for caring about questions and giving every information interested people need!
Looking forward to guide graphs or infos. After that I only need to decide, if OnStep is fine and reliable or Pulsar 2 would be the better option.
#102 Gregory
Gregory
Posted 30 August 2020 - 12:13 PM
Hello Ajay,
From what I hear, the OnStep controller should be just fine.
However, unless GTD are offering another option, the supplied
counterweight shaft is made for 30mm bore counterweights,
not 1.25-inch.  (I wish there had been such an option when I
purchased mine, I would have chosen it.)
So, 1.25" bore counterweights will be slightly "sloppy" on
a 30mm shaft, but if there is enough travel in the locking
mechanism, it should be lockable, with a slight unbalancing
in weight.
A 20 pound payload should be a breeze for the E.fric.  :-)
Hopefully I will be able to conduct my intermediate focal-length
tests (~1570mm) soon.
Gregory
I chose to go with OnStep controller for E Fric. The counter weight shaft diameter is1.25", so I will use the Losmandy 22 pound CW.
I plan to use SV 110ED refractor and AT6RC as my OTAs. I have used SV110ED on my previous Losmandy mount. AT6RC needs to be collimated frown.gif
Both OTAs with imaging cameras,guidescope/OAG weigh close to 20 pounds. I plan to upgrade a long focal length scope later on once I get better at imaging/processing.
I hope the E Fric mount performs well even at longer FL (just as the OPs review)
Edited by Gregory, 30 August 2020 - 10:17 PM.
  • ajaymandke likes this
#103 mikefulb
mikefulb
Posted 30 August 2020 - 01:40 PM
I've been using OnStep 3.16 with a self built controller on my G11 for about 50 hours of automated imaging and the mount as been rock solid.  The community for OnStep is still active and in my experience responsive to questions and feedback.
There is not really a vendor, however, to rely upon so you do need to probably have some technical background in order to potentially troubleshoot to fix things.  I love doing things like building 3D printers so it is right in my wheelhouse, but for someone who prefers to call someone on the phone when something doesn't work I'm not sure OnStep would be the best choice.  Perhaps others can add some perspective on this angle.
NOTE: I normally use the PMC8 controller on the G11 as it works wonderfully and is well supported by ES, but I had a real desire to tinker being locked in the house all this time so thought the OnStep would be an interesting diversion.  :)
Edited by mikefulb, 30 August 2020 - 01:41 PM.
  • Paul Garais likes this
#104 ajaymandke
ajaymandke
  • Loc: Houston, TX
Posted 30 August 2020 - 07:47 PM
Hello Ajay,
in weight.
Gregory
Thanks Gregory for pointing out the CW shaft diameter(30mm vs 32 mm). I will have to check if the lock screw has enough travel through to lock on.
Where did you get the CW from?
Ajay
#105 Gregory
Gregory
Posted 30 August 2020 - 10:16 PM
Hello Ajay,
You recently posted:
The counterweights in the photograph are 3kg and 6kg
counterweights from 10Micron.  I got mine from O.P.T.
in California, USA:
https://optcorp.com/...-page?q=counter
but only because they are geographically close to me.
It still took nearly three months to get them, since they
had to be imported.
Another good option is Alpine Astro:
https://www.astromounts.com/
located in Idaho, USA.
Another maker of 30mm bore counterweights is Avalon
Instruments.
Geoptik, sold by Teleskop Express in Germany, also
manufactures them.
Gregory
Edited by Gregory, 30 August 2020 - 10:20 PM.
#106 Gregory
Gregory
Posted 01 September 2020 - 10:25 AM
Hello gentlemen,
The necessary counterweights arrived to balance the
Harmer-Wynne on the E.fric.  Unfortunately, the clouds
arrived also.  :-)  The E.fric seemed happy enough with
the payload weight (~24kg) and the counterweight (~26kg),
and slewed around (under the clouds) without difficulty.
Here are a couple of pictures of the Harmer-Wynne on
the E.fric.  The E.fric seemed to handle the weight well,
and I was able to connect the controller and slew around
easily.
Gregory
  • mikefulb, ajaymandke and Paul Garais like this
#107 Gregory
Gregory
Posted 01 September 2020 - 10:28 AM
And another image of the Harmer-Wynne on the E.fric.
Gregory
  • mikefulb and ajaymandke like this
#108 Paul Garais
Paul Garais
Posted 01 September 2020 - 11:02 AM
It is not important, because our hobby takes place in darkness, but I have to say, that is a beautiful combination of scope/mount/tripod.
So where do you live and do you have a guard dog?
  • Gregory and alphatripleplus like this
#109 GeminiGTD-Italy
GeminiGTD-Italy
    Vendor - GeminiGTD-Italy
Posted 01 September 2020 - 12:30 PM
Wow, looks really cool!
András
#110 Gregory
Gregory
Posted 05 September 2020 - 09:53 PM
Hello all,
Attached are two guide graphs taken with the E.fric,
the Pulsar2 (at sidereal rate of course) using relays
directly from the guide camera, and PHD2 as the
guide program.
The OTA was a 314mm f/5 Harmer-Wynne truss
Cassegrain, which means a focal length of about
1570mm.  The OTA and associated camera train
weigh about 24kg, and the concomitant counterweight
was about 26 kg, well-balanced.  (See previous postings
in this thread for photos of the setup.)
Since guiding was done with an on-axis guider,
the entire focal length of the main instrument was
used for guiding.  Both RA and Dec aggressiveness
were set to 70.  The guide camera has a pixel size
of 6.45um, which means a pixel scale of 0.847
arcsec/pixel.  According to the Pulsar2 manufacturer,
the guide rate was set to 0.5 sidereal (setting 5).
The target was in the M29 region, which means that
the OTA (at my geographical location) was pointed
near the zenith for these tests, at approximately +38.5
degrees declination.  The wind was very low, I estimate
~3kph to completely calm.
One example guide graph was taken with a guide interval
of 2.5 seconds, and the other with a guide interval of 6.0
seconds.
Unfortunately, this test was done rather hurriedly,
since clouds threatened the sky.  That means that the
polar alignment was probably not as good as it could
have been, since I went through only one iteration of the
alignment procedure, which skews the test somewhat.
However, the seeing was fairly good, although
transparency left something to be desired.
The interesting thing to me is that the excursions
around the midpoint were generally within +/- one
second of arc for both the 2.5-second and 6-second
intervals.  I suspect that longer intervals (say,
10 seconds) would have about the same performance,
which means that the mount performance is steady
and stable.  The slight upward Dec trend in the 6-
second interval graph probably indicates a non-optimal
polar alignment.
The polar alignment was certainly not good enough for
an unguided test.  I will be re-conducting these tests
as soon as sky conditions allow with 1) better polar
alignment, 2) guiding in a different, more challenging
part of the sky, and 3) longer guide intervals, including
an unguided test.  I will also take more care with the
optics (focusing, etc.) so that I can also post some
accompanying images.  The images I have now would
not be exactly a fair representation of what the mount
can do, although they are quite as good as anything
I have experienced with my previous mount.
I will also soon post further impressions of the mount
operation, now that I have a little bit of experience
with it.
What I *can* say is that the performance under these
conditions seems to be at least as good as my previous
mount, although I am hoping for better performance.
Certainly the Dec behavior is much steadier and more
predictable than with my previous mount.
Gregory
Edited by Gregory, 05 September 2020 - 10:36 PM.
  • ajaymandke and Paul Garais like this
#111 GeminiGTD-Italy
GeminiGTD-Italy
Posted 06 September 2020 - 01:32 AM
Thank you Gregory, very nice and detailed info!
I have one remark re  guide speed. In short, it is too high. Below I explain why.
Sidereal speed is approximately 15"/sec
Guide impulses in theory can be even in the range on 1/100 sec (this is the smallest accepted pulse guide correction with Pulsar2) but to modulate them precisely, considering all the "guys" in the train, I prefer to keep the impulses in the range of 1/10 sec.
In your setup a 1/10 sec impulse is nearly one full pixel (0,75"), obviously too much.
At your pixel scale (0,8") I would use 2 or 3 (0,2 or 0,3x sidereal) as guide speed.
It would be interesting to see how reducing the guide speed impacts on RMS (the same night naturally). Remember to recalibrate PHD2 as with a cable it has no way to know about the change. The ASCOM driver does pass over the guide speed to PHD2 but I do not know if PHD will poll it before each guide session or just before calibration.
Some more guiding hints are found here: http://www.geminitel...dTechniques.pdf
András
#112 herman2017
herman2017
Posted 10 September 2020 - 05:56 PM
Gregory,
Glad to see you got the mount.  Looks like all is going smoothly.  Can you provide any experiences in using the altitude and elevation adjustments for polar-aligning?  Is there backlash?  Does a star jump a bit when locking back down after making adjustments?
Jeff
#113 Gregory
Gregory
Posted 14 September 2020 - 01:20 AM
Hello all,
András (GeminiGTD-Italy) recently posted:
I have one remark re  guide speed. In short, it is too high....
At your pixel scale (0,8") I would use 2 or 3 (0,2 or 0,3x sidereal) as guide speed....
It looks as if András gave some fine directions, as usual!  :-)
Here is another, more "fair" test, done with careful polar alignment,
and with the guide speed reduced to 0.3x sidereal.  The conditions were
the same as before, except that transparency was poorer (not all of the
particulates from the widespread fires are out of the atmosphere yet).
We are still near the zenith, in the area of M29:
The partially-hidden total RMS number is 0.45 pixels (@6.45u), and at
this pixel scale (0.847 arcsec/pixel), that is a total RMS of 0.38 arc-seconds.
For me, these are impressive numbers, especially for a mobile setup, and
with a payload of 24kg.  My current (and soon-to-be former ;-) ) mount
cannot deliver quite this level of performance, even under the best
circumstances.
Just for fun, I include here a detail from a 300-second image (red-filtered)
taken under these very poor-transparency conditions, while the guiding graph
above was being taken.  This is only a fraction of the image, since I wanted
to maintain the full resolution for pixel-peeping:
Trust me on this, any oddness in star shapes is the optics, not the mount...
the mount is now allowing me to see that I have to make some
collimation adjustments.  :-)
Gregory
Edited by Gregory, 14 September 2020 - 03:36 PM.
#114 Gregory
Gregory
Posted 14 September 2020 - 01:34 AM
Hi there Jeff,
...Can you provide any experiences in using the altitude and elevation adjustments for polar-aligning?
The alt-az adjustments are one of the things I am enjoying
most about the E.fric -- they are quite smooth, although
mechanically simple, and make polar alignment much easier
than with my current mount.  No jumping or backlash that I
can see, but I did take care to provide a solid azimuth pin,
and a smooth surface for rotation of the mount on the pier
plate.
I will make some other remarks about the mechanics soon,
however -- there are some negative aspects in dealing with
the mount that keep me from making a completely unqualified
recommendation.
I will also have further remarks on the Pulsar2, now that I have
made some (INDI) driver changes that allow me to use it more
fully under Linux.
Greg
Edited by Gregory, 14 September 2020 - 03:33 PM.
#115 vdb
vdb
Posted 17 September 2020 - 12:44 AM
So I have finally put the mount to work.
One thing I needed to figure out was automatic meridian flip,
I found the solution and asked Andras for a new FW all is well now, what a great mount.
Read more at:
https://www.cloudyni...e-capabilities/
/Yves
#116 jalonso_fast2002
jalonso_fast2002
Posted 18 September 2020 - 06:37 AM
Hi Yves,
I also have an E.fric mount and I had the same problem with automatic meridian flip in SGPRO and OnStep controller (I made my own controller).
There is a change to be done in the OnStep code to make automatic meridian flip work.
In Globals.h "PreferredPierSide preferredPierSide = PPS_WEST;" must be changed to "PreferredPierSide preferredPierSide = PPS_EAST;". Then recompile and upload the firmware.
If you want to setup in SGPRO 2 degrees past meridian, you have to setup a higher value in OnStep config, lets say 4 degrees. This way SGPRO will send the Goto command before the 4 degress limit is reached. The Goto command will flip the mount.
I am not using SGPRO anymore. I'm currently testing/using Voyager and settings are different, but eventually the automatic meridian flip works the same way.
Julian
#117 vdb
vdb
Posted 20 September 2020 - 04:35 PM
Hi Yves,
Julian
Thanks! I had found this solution on the Onstep forum as well and indeed it works as you say, so now Andras know's too and all of us using Onstep know how to tackle this issue going forward.
/Yves
#118 mikefulb
mikefulb
Posted 20 September 2020 - 05:52 PM
It is really refreshing to have a mount solution that doesn't rely on proprietary controllers and command languages.
Also tagged with one or more of these keywords: astrophotography, equipment, mount
