C8 mounting question
10 replies to this topic
#1 Guest_**DONOTDELETE**_*
Posted 23 April 2004 - 04:56 PM
I recently bought a C8 SCT and a Vixen Polaris mount for it. I bought them both used from Astromart but the scope came with a dovetail plate that I found out will not work with the old Polaris mount. I think I need rings for it but I have not been able to find any big enough. If anybody knows where I can find something to attach my scope to the mount that would be great. Thanks! :foreheadslap:
#2 Don W
Don W
    demi-god
Posted 23 April 2004 - 05:16 PM
Celestron used to sell the C8 OTA on the Vixen mount. A dovetail bar was bolted to the Vixen mount and a female dovetail was attached to the OTA. If you contact Ken of Ken's rings and things, he can sell you a female dovetail set that attaches to the mount and the male portion that goes on the scope. That's backward from what I just described but it's similar to the modern system used by the Great Polaris and its clones.
http://www.kendauzat.net/
#3 Guest_**DONOTDELETE**_*
Posted 23 April 2004 - 05:33 PM
Thanks Don, I really appreciate it. I emailed Ken to see what he has and hopefully I'll be able to get my setup going.
#4 Don W
Don W
    demi-god
Posted 23 April 2004 - 05:38 PM
If he can't come through, I actually do have the original Celestron set up, but I've been sorta hanging on to it for another project.
#5 Victor Kennedy
Victor Kennedy
    Pooh-Bear
Posted 24 April 2004 - 01:55 AM
I have a C8 mounted on a Vixen GP-DX. I bought a set of rings from Ken’s rings, and I use a dovetail plate from Stellarvue. The dovetail was about 2 mm too wide, so I machined it down to fit.
#6 Guest_**DONOTDELETE**_*
Posted 24 April 2004 - 08:15 AM
Along those lines, have any of you tried mounting a C8 OTA on an Orion Skyview Pro mount? Can the mount handle the tube?
#7 Don W
Don W
    demi-god
Posted 24 April 2004 - 09:00 AM
Yes, it's basically a CG-5 clone which Celestron sells with their C8.
#8 Guest_**DONOTDELETE**_*
Posted 24 April 2004 - 09:14 AM
Thanks for all your replies. Ken is going to be able to make another plate for me so it should work after all.
#9 Guest_**DONOTDELETE**_*
Posted 04 May 2004 - 07:00 PM
Hey Don,
I can get the set up from Ken but he's wants $115 for it. I'm wondering if I can get what I need anywhere else cheaper and just wanted to see exactly what you had so I know what to look for. I have a losmandy plate and I think if I can find the correct vixen dovetail plate that it might work instead. I'm having a hard time figuring out exactly what I need and would appreciate any info you can give.
#10 jrcrilly
jrcrilly
    Refractor wienie no more
Posted 04 May 2004 - 07:04 PM
It'd help if you could describe or send a pic of the mounting arrangement on the mount. If it already has the Vixen dovetail saddle on it you are within $25 of being all done.
#11 Guest_**DONOTDELETE**_*
Posted 07 May 2004 - 12:14 PM
I'm going to assume that you have a Losmandy DC 8 dovetail. If so, you'll need Losmandy's G11 saddle (part #G-11 SP) and the Polaris adapter plate (part # APP). There both listed on Losmandy's website http://www.losmandy.com.
However, it'll cost ya but it's pretty solid.
This is a similiar setup that I used when I had my Super Polaris mount and an Ultima 9.25 OTA. It was way too shaky and I've upgraded the mount since.
Cheers!
Rolly
