Share your images taken with LZOS 115/805 (or any LZOS)
39 replies to this topic
#26 HydrogenAlpha
HydrogenAlpha
  • Loc: Singapore
Posted 09 May 2020 - 01:14 PM
Here's an edge-of-field test with a 0.75x reducer/flattener and the large-ish KAF-16200 chip:
The stars are not as perfectly round as you would expect with an FSQ, but it's good enough for me. If you want perfect stars, use a non-reducing flattener and/or a smaller chip. It's very easy to get round stars to the edges on a 4/3rd sensor and a non-reducing flattener.
  • midnightlightning likes this
#27 fate187
fate187
  • Loc: Saxony, Germany
Posted 09 May 2020 - 01:24 PM
My existing Esprit 80 is brilliant, never had an issue with it - had to fine tune the spacing with aluminium rings once when I added a new EFW but really happy with it. I had it tuned when I bought it and it came out at 0.945 strehl (with no tweaking the settings to get that figure).
Not sure I understand your comment about the 132, are you saying that is an APM scope produced by WO? Do WO use Chinese lenses? I'm interested in them as its on my shortlist of 4 scopes.
I meant, that the 132 is not an LZOS, just as written. There is no LZOS lens with a diameter of 132mm. I don't know were WO sources those 132 lenses.
Wow!
I notice that a lot of people use piers for larger telescopes - I cant do that due to location. Will a 130mm be ok on a decent tripod - EQ6R class. Which may need a short "pier" extension to stop the FW crashing the legs?
I used to use an AZ-Eq6 with the 123. The 130 being a little heavier the EQ6 might be a little to less a mount. The AZ is known to carry a little more and I found the 123 on the AZ being the limit, especially if you use the standard tripod. I got a Losmandy HD tripod and with that thats a whole different story and more sturdy.
#28 midnightlightning
midnightlightning
Posted 10 May 2020 - 05:30 AM
Go to buckeyestargazer.com and look at Joel's work. That is one excellent scope. The only drawback, besides the weight which makes it not really grab and go, is the old CNC focuser. Built like a tank, but not easy to put a focus motor on. Now, any LZOS with a feathertouch? Fine scope!!!
Stunning images but unless I have missed them I don't see any LZOS scopes, he seems to use mainly CFF?
#29 midnightlightning
midnightlightning
Posted 10 May 2020 - 05:39 AM
Some shots taken over the last few months with my LZOS 130 f/6
Very nice Ivan, and very helpful thanks for sharing those - this scope is currently top of my list.
Couple of questions, I've been told the 130 can be difficult to use with a reducer so would be interested to know how you get on if you use one?
I was also told focus can be sensitive to temperature - I autofocus every 1C change and every filter change so I cant see it being an issue but would be interested in your thoughts?
#30 midnightlightning
midnightlightning
Posted 10 May 2020 - 05:43 AM
The non-roundness at the edge of field is not due to the LZOS optics. It's almost always due to tilt in the imaging train, or due to the reducer/flattener (or corresponding spacing issues).
For stars at the centre of the FOV, any non-roundness is going to be due to guiding error.
If any of these were caused by the lens, then it is a defective unit.
 So, with a good reducer, I am looking at the Riccardi x0.75, it should be possible to adjust out any non-guiding related poor star shapes - that's good to know. The LZOS package comes with a tilt adjuster though I have never used one - hope I can find a way of doing it during daylight at this time of year :)
#31 midnightlightning
midnightlightning
Posted 10 May 2020 - 05:47 AM
Thanks Ivan, that's really useful to know. I hadn't considered there being a difference in quality between a reducer and a flattener but I guess a reducer has more to do so is presumably more difficult to make.
#32 Carl N
Carl N
  • Loc: San Diego, CA
Posted 10 May 2020 - 07:03 AM
Dig around, he has TMB LZOS 115 pics in there, I ended up buying the scope from him.
Reach out to him on CN, he is very helpful and a good guy.
Edited by Carl N, 10 May 2020 - 07:04 AM.
#33 Wildetelescope
Wildetelescope
  • Loc: Maryland
Posted 10 May 2020 - 08:53 AM
Ideally you want to get a reducer/flattener designed specifically for the optics of your telescope.  Ie a TV reducer for your TV scope, AP for AP scopes or the Ricardi for some of the APM LZOS scopes, etc.....   For example, I have a not so cheap GSO sourced 2 inch reducer that works fine with my mirrored scopes, but absolutely introduces color with my refractors.   Spacing of the fr relative to The sensor is critical.  I believe skywatcher has a specific flattener/reducer for the esprit line as well.
jmd
#34 HydrogenAlpha
HydrogenAlpha
  • Loc: Singapore
Posted 10 May 2020 - 09:00 AM
 So, with a good reducer, I am looking at the Riccardi x0.75, it should be possible to adjust out any non-guiding related poor star shapes - that's good to know. The LZOS package comes with a tilt adjuster though I have never used one - hope I can find a way of doing it during daylight at this time of year smile.gif
Yeah I have the tilt adjuster too, but didn't have the need to use it...ended up just becoming a slightly expensive spacer lol.gif
I wouldn't say it's a difference in quality, but it's more of the fact that it makes underlying issues more obvious. It's similar to the effect of having a large sensor.
#35 Carl N
Carl N
Posted 10 May 2020 - 06:51 PM
I have the Riccardi 0.75 reducer/flattener I used for the 115 and use now on my 152. I also have the 1.0 flattener for full frame. They work really well.
And if everything is orthogonal, I havent needed the tilt adjuster cause my Starlight Xpress camera has one built in.
Edited by Carl N, 10 May 2020 - 06:53 PM.
  • mclewis1 and midnightlightning like this
#36 midnightlightning
midnightlightning
Posted 20 September 2020 - 03:30 AM
Thanks for all the responses
#37 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 21 September 2020 - 11:08 AM
... and thanks for the thread. I don't think these wonderful scopes get enough love and visibility.
#38 billhinge
billhinge
Posted 15 October 2020 - 02:49 PM
I have a 2001 APM TMB LZOS 115mm with the stock 2" FT focuser, I plan to change that next year for the 3" or even 3.5". I recently bought the x1 Riccardi and I thought that was big but the 0.75x 82mm Riccardi is huge and heavy. How safe is to hang those things off the back of a stock kuppex tube with focuser held on by 3 screws when you add a camera? I have a set of tubes based  on the APM diag https://www.apm-tele...rdiAdaption.pdf
Did you have any weight concerns?
(I plan to retube next year with an upgraded focuser so just thinking about a stop gap solution)
#39 noisejammer
noisejammer
    Fish Slapper
  • Loc: The Uncanny Valley
Posted 15 October 2020 - 03:39 PM
Can you actually get the LZOS 115/805 now? I was under the impression that mine (delivered in Feb 2016) was one of the last made. edit - just checked - there's a new batch!
In any case, mine has a 3035 focuser with a 72mm Tak thread. It accepts the TOA130R reducer and can operate at f/5.3. I used it in Wyoming for this polarogram ...
Polarisation V5
  • mclewis1 and Esso2112 like this
#40 billhinge
billhinge
Posted 15 October 2020 - 04:51 PM
Mine is secondhand one from 2001, I believe they still make them but maybe  not like the old versions.
https://www.apm-tele...-cnc-lw-ii.html
  • mclewis1 likes this
