Antlia NB 3.5nm filter with faster optics
23 replies to this topic
#1 LYAstro
LYAstro
    Vendor - Antlia Filters
  • Loc: China
Posted 09 May 2020 - 01:57 AM
 In the faster optics, the wavelength of the narrow-band filter is shifted toward the short-wave direction and the transmittance is attenuated. It still has very good performance. Most of our test photos are used under the 150mm f2.8 and C11 rasa f2 systems. The photo details are very good.
 Antlia Ha 3.5nm filter with C11HD RASA F2
total 5h cropping of different parts
by Wuzhen(China)
 by Wuzhen(China)
#2 LYAstro
LYAstro
  • Loc: China
Posted 09 May 2020 - 02:06 AM
 Qhyccd QHY600, iOptron CEM120
 Frames : 20min*48(Ha)
 Photo by Wuzhen(China)
  • Stelios, leviathan, Lead_Weight and 3 others like this
#3 LYAstro
LYAstro
  • Loc: China
Posted 09 May 2020 - 02:08 AM
 20min*21 total 7h
#4 LYAstro
LYAstro
  • Loc: China
Posted 09 May 2020 - 02:10 AM
Antlia Ha 3.5nm,QHY600,C11 RASA,CEM120
 Ha 20min*72 total 24h
#5 Jetstarz99
Jetstarz99
Posted 09 May 2020 - 02:39 AM
Curious why the first Horeshead is backwards.
Second Horsehead is mindblowing.  Incredible detail.
Cheers
Edited by Jetstarz99, 09 May 2020 - 02:42 AM.
#6 LYAstro
LYAstro
  • Loc: China
Posted 09 May 2020 - 05:03 AM
Cheers
 This is the imaging feature of rasa, which can be adjusted later
#7 buckeyestargazer
buckeyestargazer
    Vendor - Buckeyestargazer.net
  • Loc: IN, USA
Posted 09 May 2020 - 08:16 AM
Where can I buy these?  The USA dealer does not have stock.  Can I order directly?
#8 LYAstro
LYAstro
  • Loc: China
Posted 09 May 2020 - 09:54 AM
 agena is our US agent, you can buy from him:
 https://agenaastro.c...YNUOYkzIQ5IVWNY
  • gozer likes this
#9 yzhzhang
yzhzhang
  • Loc: San Diego, CA
Posted 09 May 2020 - 05:21 PM
Looks awesome!
Gotta ask: any love for us QSI users? Don't see 31mm unmounted options in Agena's webpage...
#10 LYAstro
LYAstro
  • Loc: China
Posted 09 May 2020 - 09:49 PM
Looks awesome!
 Thank you very much.
31mm is compatible with 1.25 inches most of the time, so we mainly used 1.25 inches in the early stage, only a small amount of 31mm, there is not much inventory, so most agents do not
#11 yzhzhang
yzhzhang
Posted 10 May 2020 - 02:12 PM
Gotcha.
The problem is for QSI filterwheel, 31mm unmounted filter requires the washer to hold the filter in place, while 1.25 mounted filters just screw in, and cannot be used with the washer. One washer is shared between the adjancent filters, and I already have 31mm LRGB, so I cannot keep them and add a set of 1.25" mounted NB filters...
#12 LYAstro
LYAstro
  • Loc: China
Posted 10 May 2020 - 08:34 PM
Gotcha.
 Ok, understand, if you are in the United States, you can consult agena, there should be 31mm NB filter
#13 Aaron_tragle
Aaron_tragle
  • Loc: Richmond, Virginia
Posted 11 May 2020 - 03:57 AM
by Wuzhen(China)
by Wuzhen(China)
Wow these are some incredible images, the ones posted all seem to be with the RASA however. Please post some pictures with the 150mm F2.8 whenever you get the chance. I’m looking at getting myself a set of these.
#14 LYAstro
LYAstro
  • Loc: China
Posted 11 May 2020 - 07:38 AM
 ok, we also have a test chart of 150mm f2.8, which will be released later
 thank you
  • Aaron_tragle and OrionNebula32 like this
#15 mrpugh55
mrpugh55
    Vendor - Astrophotography by Martin Pugh
Posted 14 May 2020 - 04:23 AM
Hi.
I have a 36cm F2 RASA, so I am interested in these filters.
When do you expect to have a Ha/SII/OIII 50mm unmounted round filter set to be available?
I am in Australia..do you have dealers here?  I also purchase from Cyclops Optics in Hong Kong.
thanks
Martin
#16 LYAstro
LYAstro
  • Loc: China
Posted 14 May 2020 - 05:06 AM
Hi.
thanks
Martin
thank you,you can send an email to sales@antliafilter.com, it will be more efficient.
#17 Jeff Morgan
Jeff Morgan
  • Loc: Prescott, AZ
Posted 15 May 2020 - 12:18 PM
Impressive.
Are these filters still ok with optics slower than f/2.8?
#18 LYAstro
LYAstro
  • Loc: China
Posted 16 May 2020 - 02:56 AM
Impressive.
 The optical system lower than f2.8 will still have losses, but because of the large amount of incoming light, the effect is still very good.
We have f2.2 (RASA) and f2.8 (sharpstar 15028HNT 150mm f2.8) tested.
 This is the test chart of antlia filter with f2.8: https://www.cloudyni...-faster-optics/
#19 OrionNebula32
OrionNebula32
Posted 29 September 2020 - 06:07 PM
Here is a master light from 15 x 240s ANTLIA  36mm Ha on NGC 281. (yes i know i need to redo my flats, i keep having issues obtaining proper flats)
Taken with a STELLARVUE SVX70 and ASI183MM PRO combo.
  • LYAstro likes this
#20 OrionNebula32
OrionNebula32
no processing except the autostretch and there is a ton of lossy compression
Edited by OrionNebula32, 29 September 2020 - 06:07 PM.
#21 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 03 October 2020 - 07:25 AM
Do you make a wider (e.g. 7nm) OIII filter? I'm curious as my other (non Antlia) narrowband filters are 7nm.
#22 DuaneS
DuaneS
  • Loc: Sedona, Arizona
Posted 03 October 2020 - 10:48 PM
I have the RASA36 and am waiting for the 50mm version of the filters. Incredible images!! That horsehead is insane!
#23 LYAstro
LYAstro
  • Loc: China
Posted 08 October 2020 - 09:59 PM
 You can also mix and use 3.5nm, currently we have no plans to launch a 7nm narrowband filter
#24 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 12 October 2020 - 09:06 PM
Thanks. I am probably going to end up mixing, as OIII seems to be one that needs the narrowest bandwidth.
