ASCOM.DSLR - ASCOM driver for dslr cameras (Canon, Nikon, Pentax, Sony)
astrophotography CMOS ccd dslr
869 replies to this topic
#1 FearL0rd
FearL0rd
  • Loc: Houston, TX Area
Posted 15 May 2020 - 10:43 PM
Hello,
           me and @tjay pickup the project from the previous developer and we are modernizing the driver using the lasted drivers and including Pentax support also.
           I believe it is causing confusion with the old code created by the previous developer making people download the old files.
Objective: Create a fully functional ASCOM driver for DLSR cameras
Open Source Project Location: https://github.com/FearL0rd/ASCOM.DSLR
Installer: https://github.com/F...amera Setup.exe
Included the camera tester @ C:\Program Files (x86)\Common Files\ASCOM\Camera\ASCOM.DSLR.Camera\ASCOM.DSLR.Test.exe
Please use the camera test first to set the variables
To connect in astro software please use standart ASCOM camera selection dialog - select there "ASCOM Camera Driver for DSLR"
1. Set camera mode to B or M (depends on camera model)
2. Connect via USB cable
Settings description:
Connection method - way how to connect to camera
3. Use the camera test first C:\Program Files (x86)\Common Files\ASCOM\Camera\ASCOM.DSLR.Camera\ASCOM.DSLR.Test.exe
Image mode - format in which image is returned
1. RGGB - raw data are transferred to ASCOM
2. Color16 - debayered 16 bit tiff - usefull for software which doesn't support debayerization
3. ColorJPG - jpeg for quick preview (i used it for plate solving)
Enable binning - enables software binning up to 4*4
Save photos to - path where store files. Original RAW files will be stored there. Filename contains exposure, ISO, sensor temperature (for canon), time
ISO  - iso value. contains all possible values. When camera doesn't support selected - nearest will be choosen
Please let us know about any issues: describe used software, camera, steps to reproduce and send log file
Logs are written there C:\Users\<USER_NAME>\Documents\ASCOM\Logs <DATE_TIME>
Edited by FearL0rd, 16 May 2020 - 11:48 AM.
  • tjay, Toups, Yoddha and 13 others like this
#2 mwr
mwr
Posted 16 May 2020 - 03:02 AM
Nice and very useful project! Do you plan to include support for Fujifilm cameras as well in the near future? I'm using a Fujifilm X-A1 for astrophotography and spectroscopy and I'm quite pleased with its extended H alpha sensitivity https://www.cloudyni...-200-or-300-mm/
  • LarsMalmgren likes this
#3 scottmm2012
scottmm2012
Posted 16 May 2020 - 08:14 AM
So, just recently, I've been getting an error when trying to connect my Canon T3i in SharpCap (SC), latest version.  It worked fine with the previous edition until last week.  I only used this latest version when the problem persisted.  I did resort to the previous version but the errors are still showing up.  It is either the NotConnectedException Error or the InvalidOperationException Error, depending on the camera setting selection (see below).  Unfortunately, it is not writing a logfile.
I have the mode set to M on the camera, bulb for exposure.  Connect via USB3, power on camera, and open SC and select Ascom Camera Driver for DSLR.  Immediately the mirror flips and the view screen shows the exposure timer.  The only way to get it to stop is turning the camera off, or selecting the Camera Controls, Options - Show button which will take it to the ASCOM driver settings dialog window after a slight freeze and the mirror drops back down (I'm assuming it is disconnected at this point).  The settings dialog window appears and previous settings aren't saved, I normally had selected the BYEOS setting, instead of the Canon SDK setting, but it always resorts back to the Canon SDK setting (not sure if this is relevant).  If I select the BYEOS setting it hangs for a few seconds and redisplays the settings dialog window, with BYEOS still chosen but when I press OK again it gives the NotConnectedException.  If I select the Canon SDK setting and press ok, after a few seconds it will show the InvalidOperationException error.
All other software, BYEOS, APT, connects just fine with the camera and they function normally.  I use SC specifically for polar alignment through my DSLR.
Not sure if the SC error logs would help.  If interested let me know and I will upload.
#4 asl547
asl547
  • Loc: New York
Posted 16 May 2020 - 08:20 AM
Do you have to complete the steps shown under “ASCOM Driver for DSLR Cameras Development environment preparation,” or is it sufficient merely to run the installer?
#5 FearL0rd
FearL0rd
Posted 16 May 2020 - 09:32 AM
the installer should do all the registration steps necessary for the ascom.
Sent from my SM-G975U using Tapatalk
#6 FearL0rd
FearL0rd
Posted 16 May 2020 - 09:33 AM
yes but I will need to research a little about Fujo cameras.
  • jimmydigital00, tkottary and mwr like this
#7 FearL0rd
FearL0rd
Posted 16 May 2020 - 09:37 AM
could you please remove the driver using the control panel, reinstall the latest drivers, test again and send the logs located at C:&#092;Users&#092;<USER_NAME>&#092;Documents&#092;ASCOM&#092;Logs <DATE_TIME>?
#8 scottmm2012
scottmm2012
Posted 16 May 2020 - 10:28 AM
Done and done.
Attached File  ASCOM.DSLR.1125.143260.txt   47bytes   1098 downloads
Attached File  ASCOM.DSLR.1124.480160.txt   47bytes   373 downloads
#9 FearL0rd
FearL0rd
Posted 16 May 2020 - 11:44 AM
Hello, I found few bug in the routine to save the image and I have updated the application. also included a camera test application at  C:\Program Files (x86)\Common Files\ASCOM\Camera\ASCOM.DSLR.Camera\ASCOM.DSLR.Test.exe
#10 FearL0rd
FearL0rd
Posted 16 May 2020 - 11:45 AM
Could you please try to install the version that I just published and execute the camera test application included.
Application location:
  • scottmm2012 likes this
#11 lmclouth
lmclouth
  • Loc: Davison, MI
Posted 16 May 2020 - 12:50 PM
I tried the ASCOM.DSLR.Test.exe from the package downloaded and installed around 1:45pm EDT.
I received an unhandled exception and the attached text file is the detailed error.
Attached File  Error from ASCOM.DSLR.Test.txt   6.91KB   328 downloads
Edited by lmclouth, 16 May 2020 - 12:51 PM.
#12 scottmm2012
scottmm2012
Posted 16 May 2020 - 01:00 PM
attachicon.gifError from ASCOM.DSLR.Test.txt
I got the same.  Please see attached.  I have to give kudos to FearLord for his time and effort.
Attached File  ASCOM.DSLR Test Error.txt   7.12KB   152 downloads
#13 FearL0rd
FearL0rd
Posted 16 May 2020 - 01:04 PM
I think I found the issue. for old cameras like " 1000D", " 40D", " 450D", " 50D", " 400D", " 500D", "Rebel XSi", "Rebel XTi",
                "Rebel XS", "Rebel T1i", "1Ds Mark III" the driver should work.  for the newer cameras the driver has to work a little different. Im close to a solution. unfortunately don't have newer camera to Debub the code on-the-fly
  • scottmm2012 and AstroBeginner0 like this
#14 scottmm2012
scottmm2012
Posted 16 May 2020 - 01:41 PM
Definitely appreciate your time and effort, FearLord!!!
  • akagai1960 likes this
#15 tjay
tjay
  • Loc: just outside of Toronto
Posted 17 May 2020 - 12:26 AM
Thanks for the log. It's in the exact area I am trying to get better logging so we can debug problems better. I think fearl0rd has found some problem as well and may have a fix soon.
Sent from my SM-T713 using Tapatalk
#16 tjay
tjay
Posted 17 May 2020 - 12:27 AM
attachicon.gifASCOM.DSLR Test Error.txt
Thanks forvtge log. It's definitely a similar issue. The code needs some work to make debugging these sorts of errors easier. Trying to work on it but life gets in the way sometimes
#17 scottmm2012
scottmm2012
Posted 17 May 2020 - 06:43 AM
Thanks for your time and effort as well Tom!!
  • tjay and akagai1960 like this
#18 tjay
tjay
Posted 17 May 2020 - 08:14 AM
Fearl0rd is doing the bulk of the work by far but you are welcome!
#19 Alex McConahay
Alex McConahay
  • Loc: Moreno Valley, CA
Posted 17 May 2020 - 07:31 PM
Thanks for the effort.
Unfortunately, after downloading the new stuff, I still could not connect with either my 6D or 450.....Both had the same message:
The details of the error are:
Camera exposure failed, msg. 'Camera Error.'
Sharpcap itself did not crash, or freeze.
Alex
#20 tjay
tjay
Posted 17 May 2020 - 11:43 PM
Alex
Alex,
I'm trying to do a proper revamp of the logging, but I'll create a specific build tomorrow with some logging that may help us narrow down the problem you are having.
I guess Sharpcap not crashing or freezing is sort of an improvement...
Edited by tjay, 17 May 2020 - 11:44 PM.
#21 FearL0rd
FearL0rd
Posted 18 May 2020 - 05:25 PM
Alex
Alex,
Good Afternoon,
I believe I found some of the issues with the driver. Could you please test in your cameras?
Also please use the ASCOM.DSLR.Test.exe if it doesn't work on your photograph applications.
#22 lmclouth
lmclouth
  • Loc: Davison, MI
Posted 18 May 2020 - 06:09 PM
With my Canon EOS 7D Mark II, I get the attached error window in SharpCap after I select "ASCOM Camera Driver for DSLR".
The shutter will click twice, then the DSLR Setup window will appear.  I click on the OK button and the shutter clicks again and the "error in SharpCap.jpg" window appears.
Then with SharpCap closed and the power cycled on the camera, I run the ASCOM.DSLR.Test.exe and click the "Choose" button to make the "ASCOM Camera Chooser" window appear.  "ASCOM Camera Driver for DSLR" is already selected so I click the OK button.  Then I click the "Connect" button in the Test program and the shutter clicks and an unhandled exception window appears.  The detailed text is in the attached file.
#23 FearL0rd
FearL0rd
Posted 18 May 2020 - 06:12 PM
Does the second click happens after the exposure time? or a very quick click click
Edited by FearL0rd, 18 May 2020 - 06:20 PM.
#24 tjay
tjay
Posted 18 May 2020 - 06:20 PM
I'll send you a private message.  I've built version of the driver with some low level logging that may help us debug this, but it definitely won't fix the issue, so I don't want to distributed too far.
Thanks for the error report!  Hopefully we can get it fixed soon!
  • FearL0rd likes this
#25 lmclouth
lmclouth
  • Loc: Davison, MI
Posted 18 May 2020 - 06:31 PM
A very close together click click.
Also tagged with one or more of these keywords: astrophotography, CMOS, ccd, dslr
