Using the BYEOS option in the camera chooser:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
ASCOM.DriverException: Timeout waiting for setup exposure ---> ASCOM.DriverException: Timeout waiting for setup exposure
at ASCOM.DSLR.Classes.CameraModelDetector.GetCameraModel(IDslrCamera camera, String storePath)
at ASCOM.DSLR.Classes.BaseCamera.GetCameraModel(String cameraDescription)
at ASCOM.DSLR.Classes.CanonSdkCamera.ScanCameras()
at ASCOM.DSLR.Classes.CanonSdkCamera.get_MainCamera()
at ASCOM.DSLR.Classes.CanonSdkCamera.OpenSession()
at ASCOM.DSLR.Classes.CanonSdkCamera.ConnectCamera()
at ASCOM.DSLR.Camera.set_Connected(Boolean value)
--- End of inner exception stack trace ---
at ASCOM.DriverAccess.MemberFactory.CheckDotNetExceptions(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 614
at ASCOM.DriverAccess.MemberFactory.SetTargetInvocationExceptionHandler(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 648
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 315
at ASCOM.DriverAccess.AscomDriver.set_Connected(Boolean value) in C:\ASCOM Build\Export\ASCOM.DriverAccess\AscomDriver.cs:line 146
at ASCOM.DSLR.Form1.buttonConnect_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4180.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
ASCOM.DSLR.Test
Assembly Version: 6.2.0.0
Win32 Version: 6.2.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/Camera/ASCOM.DSLR.Camera/ASCOM.DSLR.Test.exe
Win32 Version: 4.8.4150.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
ASCOM.DriverAccess
Assembly Version: 6.0.0.0
Win32 Version: 6.4.1.2695
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.DriverAccess/6.0.0.0__565de7938946fba7/ASCOM.DriverAccess.dll
ASCOM.DeviceInterfaces
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.DeviceInterfaces/6.0.0.0__565de7938946fba7/ASCOM.DeviceInterfaces.dll
ASCOM.Exceptions
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Exceptions/6.0.0.0__565de7938946fba7/ASCOM.Exceptions.dll
ASCOM.Utilities
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Utilities/6.0.0.0__565de7938946fba7/ASCOM.Utilities.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
ASCOM.DSLR.Camera
Assembly Version: 0.5.77.0
Win32 Version: 0.5.77
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/Camera/ASCOM.DSLR.Camera/ASCOM.DSLR.Camera.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
EDSDKLib
Assembly Version: 1.1.1.0
Win32 Version: 1.1.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/Camera/ASCOM.DSLR.Camera/EDSDKLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
__________________________________________________________
When using the Canon SDK option in the camera chooser. I initially get the timeout error:
than this error.
Details:
ASCOM.DriverException: CheckDotNetExceptions ASCOM.DSLR.Camera ConnectedSet System.InvalidOperationException: Sequence contains no elements
at System.Linq.Enumerable.First[TSource](IEnumerable`1 source)
at ASCOM.DSLR.Classes.CanonSdkCamera.GetSelectedIsoValue()
at ASCOM.DSLR.Classes.CanonSdkCamera.InitSettings()
at ASCOM.DSLR.Classes.CanonSdkCamera.StartExposure(Double Duration, Boolean Light)
at ASCOM.DSLR.Camera.set_Connected(Boolean value) (See Inner Exception for details) ---> System.InvalidOperationException: Sequence contains no elements
at ASCOM.DriverAccess.MemberFactory.CheckDotNetExceptions(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 630
mscorlib
ASCOM.DSLR.Test
System
System.Drawing
System.Core
System.Xml
Accessibility
ASCOM.DriverAccess
ASCOM.Utilities
ASCOM.Exceptions
ASCOM.DSLR.Camera
EDSDKLib
enabled.
For example:
<configuration>
</configuration>
I guess the question for me is to streamline the testing. Which option should we choose. The BYEOS option or the Canon SDK option?
