Hello everyone,
I came across this while trying to find some way to get something that would allow me to use APT with my Pentax K3 II. It looks like you guys have done a great job but I appear to be having a similar issue outlined by others. I get the same error when try to test my camera.
Here is what I am getting as far as logs and messages.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
ASCOM.NotConnectedException: Camera not connected ---> ASCOM.NotConnectedException: Camera not connected
at ASCOM.DSLR.Classes.CanonSdkCamera.ScanForCameras()
at ASCOM.DSLR.Classes.CanonSdkCamera.OpenSession()
at ASCOM.DSLR.Classes.CanonSdkCamera.ConnectCamera()
at ASCOM.DSLR.Camera.set_Connected(Boolean value)
--- End of inner exception stack trace ---
at ASCOM.DriverAccess.MemberFactory.CheckDotNetExceptions(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 560
at ASCOM.DriverAccess.MemberFactory.SetTargetInvocationExceptionHandler(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 648
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 315
at ASCOM.DriverAccess.AscomDriver.set_Connected(Boolean value) in C:\ASCOM Build\Export\ASCOM.DriverAccess\AscomDriver.cs:line 146
at ASCOM.DSLR.Form1.buttonConnect_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4180.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
ASCOM.DSLR.Test
Assembly Version: 6.2.0.0
Win32 Version: 6.2.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/Camera/ASCOM.DSLR.Camera/ASCOM.DSLR.Test.exe
Win32 Version: 4.8.4150.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
ASCOM.DriverAccess
Assembly Version: 6.0.0.0
Win32 Version: 6.4.1.2695
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/ASCOM.DriverAccess/6.0.0.0__565de7938946fba7/ASCOM.DriverAccess.dll
ASCOM.DeviceInterfaces
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/ASCOM.DeviceInterfaces/6.0.0.0__565de7938946fba7/ASCOM.DeviceInterfaces.dll
ASCOM.Utilities
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/ASCOM.Utilities/6.0.0.0__565de7938946fba7/ASCOM.Utilities.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
ASCOM.Exceptions
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/ASCOM.Exceptions/6.0.0.0__565de7938946fba7/ASCOM.Exceptions.dll
ASCOM.DSLR.Camera
Assembly Version: 0.5.77.0
Win32 Version: 0.5.77
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/Camera/ASCOM.DSLR.Camera/ASCOM.DSLR.Camera.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
EDSDKLib
Assembly Version: 1.1.1.0
Win32 Version: 1.1.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/Camera/ASCOM.DSLR.Camera/EDSDKLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
The ASCOM logs are in the attached zip file.
Please let me know if there is anything else I can provide to help you, help me.
Oh, as a side note, when I run the test, I can see it talking to the camera and it does "take a picture", but seems to timeout when trying to acquire it.
Thank you in advance.
