Starlock PEC Tool
10 replies to this topic
#1 Lindhard
Lindhard
  • Loc: N 55° 30' -- E 8° 26'
Posted 19 May 2020 - 04:49 PM
I found the program "Starlock PEC Tool" on the Meade webpage and tried to use it on my LX600, but it can not find the com port, it seems.
I use the right com port as the Autostar updater program can make contact with the telescope through the same port and cable without problems, but Starlock PEC reports "run timeout error 8020".
Has anyone else seen this?
I use a laptop with Windows 10.
#2 MZsarko
MZsarko
  • Loc: Jamul, CA
Posted 26 May 2020 - 03:38 PM
Isn't your mount a fork mount?
#3 Lindhard
Lindhard
Posted 26 May 2020 - 04:03 PM
Yes it is
#4 MZsarko
MZsarko
  • Loc: Jamul, CA
Posted 27 May 2020 - 11:31 AM
I don't know if they use PEC.
#5 OzAndrewJ
OzAndrewJ
Posted 27 May 2020 - 03:20 PM
Gday Lars
IIRC, the Starlock tool only works on the LX850s ( ie RA / polar )
My latest PEC editor can also read out the PEC data for the LX600s
but im not sure if the one on my site works properly with the LX600 any more
as meade have changed the format of the data several times recently.
What are you trying to do????
( as there are lots of bugs in the LX600 PEC, based on how you do it. )
#6 AF7JQ
AF7JQ
  • Loc: Concho Valley, Arizona 6500Ft ASL
Posted 27 May 2020 - 07:05 PM
Andrew
Can you expand on the "lots of bugs in the LX600 PEC". What should I be looking out for??
John
#7 OzAndrewJ
OzAndrewJ
Posted 27 May 2020 - 07:16 PM
Gday John
Most of the bugs are involved in the Non StarLock generated PEC data, esp when doing updates
( I dont have much re altaz PEC in LX600s via Starlock, but not many do that )
For StarLock generated data in Polar the process appears to work OK, but i am currently working with a user
of an LX850, who has used the PEC tool, and at times it has corrupted his data badly.
The LX600/850 share the same PEC "storage" mechanism, so using it to update data may result in grief.
We havent properly defined whats doing it yet.
#8 AF7JQ
AF7JQ
Posted 27 May 2020 - 08:26 PM
When I first got my scope wedge mounted I did the whole PEC with multiple update thing. I found watching my image HFR history I could see a cyclic increase and decrease pretty regularly. It seemed the PEC and Starlock were fighting, so I disabled it. Lately I had the opportunity to fine tune my Polar align using Sharpcap's drift align. It showed even after the Starlock Drift align the mount was over 2 MIN in RA and 1.5MIN out of Polar align. I got the mount tuned to just a couple seconds of error now. After also fine tuning my balance I decided to reset and run the PEC with several updates again. I took several long series of images both with and without PEC on...works much better now with PEC on, and no more of the cyclic changes. I haven't used the PEC tool to try smoothing the curves yet...any benefit to doing that? I would like to Meade give us the choice of allowing additional fine tuning of the Starlock Drift align. It's a shame it just stops and says it's good enough.
John
#9 OzAndrewJ
OzAndrewJ
Posted 27 May 2020 - 08:58 PM
Gday John
What i always suggest in a case like this is to use something like PHD2 or PEMPro as a "second opinion".
Do whatever you want to do with Starlock re training the PEC.
Now turn Starlock off and Turn PEC off.
Select a star somewhere near the meridien and between DEC = 0 and your zenith.
( closer ot DEC = 0 is probably better )
Start the "logging" App and collect say 6 turns of the worm.
Now, whilst still logging, simply turn PEC ON and let it run for another 6 turns.
The first part of the run will show the native PE in the gearbox and worm
The second part of the plot will show how well the model has corrected it.
IMHO its a toy that you really have no control over.
I only ever use my app to read and smooth the curves, and i dont do Meade based "updates"
as with the non starlock mode, you have no idea if a bad update corrupts a good model.
I prefer to do several clean trains and then deal with them myself externally,
as i can see each run overlaid over the prev runs, so can easily see when things go off the rails
and exclude bad data if i want.
Just for info, i have attached a plot from an LX850 user who was doing trains and updates
then "played" with PECTool
Very interesting how corrupt it can become :-)
There was another dataset that introduced massive drift as the final model wasnt normalised properly.
No idea why tho.
I also wouldnt bother with Starlock if drifting, i just use a webcam on the main OTA
set it square to the DEC axle best i can and watch a star on the screen ( relative to a XHair ).
If it drifts, i know my align is off.
If you also log it over time ( say with PEMPro or PHD2 ), you can see the real drift angles "live"
and watch live the effects of tweaking the mount controls.
This plot shows the result of a "StarLock" based train and multi update ( dark blue traces )
All the others show what ended up getting backloaded as they played with PEC tool
#10 AF7JQ
AF7JQ
Posted 30 May 2020 - 02:03 AM
Well I confirmed my alignment is now spot on, no troubles there. I compared the tracking with and with out the PEC with starlock off. Most of the gear revolution was better with the PEC on, but there is a section that it's totally off. Running with PEC off there are some trouble spots. Next clear night I think I will erase the PEC, do a fresh software align and try a single PEC train to see if it is better. The model I'm working with now had 4 updates. After seeing the graph you posted I agree some of the updates cause more error than they correct. It's always something with this hobby, but we learn as we go I guess. Thanks
John
#11 OzAndrewJ
OzAndrewJ
Posted 30 May 2020 - 02:18 AM
Gday John
Not so sure there.
The train and updates ( if done by StarLock ) all appeared to be very consistent.
The woofy data appeared when using PECTool to tweak the data.
What i would suggest is you use a third party app like PEMPro or PHD2
to grab an unguided PEC OFF data grab so you can see what your basic tracking is like.
You can then compare that to the PEC model created by Starlock.
