Help w/ older Vixen ED scope rear fittings
11 replies to this topic
#1 Littlegreenman
Littlegreenman
  • Loc: Southern California
Posted 21 May 2020 - 06:03 PM
I have made by Vixen Orion branded 102 ED scope. It looks the same size as the f/6.5 Vixen sold in the late 1990's early 2000.
The metal draw tube is 62mm external diameter. On it is a black metal ring that accepts a male 43mm thread. Or is it a 42mm thread?
The black metal ring in on really tight. Does anyone know if it is removable and is just stuck, or not removable?
If not, how do I put eyepieces on this? I read one reference on A-mart that Vixen made a 43 mm to 1.25" eyepiece adapter, but cannot find one. Currently Vixen sells a 42mm to 1.25" accessory, but it appears it has a female 42mm thread.
Thanks.
Edited by Littlegreenman, 21 May 2020 - 06:04 PM.
  • 25585 likes this
#2 Blueox4
Blueox4
  • Loc: Upstate New York
Posted 21 May 2020 - 06:13 PM
If it’s like my two FL70’s you could use this adapter to open the door to anything T2. There’s a thread too. I’ll find it and post with more info but it’s adapter is what you could use.
https://agenaastro.c...22-1508037.html
Edited by Blueox4, 21 May 2020 - 06:13 PM.
#3 GOLGO13
GOLGO13
  • Loc: West Virginia
Posted 21 May 2020 - 06:18 PM
You're adapter looks different than mine. And mine does come off (for being able to screw other attachments in). Now, mine came off a 130mm Vixen SS refractor.
It appears yours is setup for a camera or something.
Mine is not in use so let me know. Mine seemed to measure 6 centimetres across (the drawtube that is...not the black part).
#4 GOLGO13
GOLGO13
Posted 21 May 2020 - 06:22 PM
vixen focuser
#5 GOLGO13
GOLGO13
Posted 21 May 2020 - 06:24 PM
Personally, I think you should try to screw that one off and see if your drawtube is 6 centimeters acrossish. You'd want to use a part like I have for a 2 inch focuser.
#6 GOLGO13
GOLGO13
Posted 21 May 2020 - 06:36 PM
This is what it looks like threaded on:
vixen focuser2
#7 Blueox4
Blueox4
Posted 21 May 2020 - 06:47 PM
https://www.cloudyni...e/#entry9636879
#8 Littlegreenman
Littlegreenman
Posted 21 May 2020 - 06:57 PM
(I really need to get a better caliper.) The outside diameter of my drawtube in 62 or 65mm, depending on which measurement. And my caliper doesn't really fit.
Note: I will be gone from computers for several hours, but get back to you.
SL
#9 GOLGO13
GOLGO13
It would be very interesting if he could unscrew it to see if he has the double sided deal.
#10 GOLGO13
GOLGO13
Posted 21 May 2020 - 07:00 PM
See post #2 from Blueox4's link. It looks like you may just have to unscrew it and turn it around to use with a diagonal. You'd probably have to get a set screw replacement, but easy at a department store.
#11 Simon B
Simon B
  • Loc: Vancouver, BC
Posted 21 May 2020 - 07:24 PM
The black metal ring is an M60 x 0.75 to M43 x 0.75 adapter - the drawtube itself has female M60 x 0.75 threads
The best way would be to just replace the black metal ring with a Vixen eyepiece adapter; Vixen US have a set-screw version and a compression ring version:
https://www.vixenopt...-SX-p/37293.htm
https://www.vixenopt...pter-p/5971.htm
Or Baader makes a clicklock:
https://agenaastro.c...ad-2956260.html
Edited by Simon B, 21 May 2020 - 07:26 PM.
  • Littlegreenman likes this
#12 Littlegreenman
Littlegreenman
Posted 21 May 2020 - 08:16 PM
Update:
I remembered I had a plumbers "rubber strap" wrench and was able to remove the black end ring. So now I have another 60mm Vixen drawtube with a female 60mm thread.
I'm a bit embarrassed. But I was of afraid of damaging something.   Especially when my first thought involved a pair of channel lock pliers. shameonyou.gif
Sorry to lead people astray. Thank you for all the advice, some of which I'm thinking about.
I bought this scope recently through a Goodwill auction. It came with a straight through set up and a 1.8x extender, so it was likely used and set up of for photography.
The ring I have is not reversible; no threads the opposite side.
I do have another Vixen refractor, 114mm ED SS f/5.4, and I just bought a Baader Click Lock for Vixen for that and now this scope.
For those who sent me a PM I will get back to you.
  • eros312, Blueox4 and Simon B like this
