ES92 12mm & 17mm - good at f/5.4?
5 replies to this topic
#1 Blueox4
Blueox4
  • Loc: Upstate New York
Posted 22 May 2020 - 07:28 PM
I’ve got a Beautiful 13mm Ethos I have tried to like in my NP101 but have been underwhelmed. I wanted to like it as much as the 12mm ES92 I had but just haven’t been able to. In my 12” Dob the ES92’s were great. I’ve never tried them in my NP101 as I didn’t have it when I had them prior and Im wondering how they would perform?  I’m not sure if it’s the Ethos is a 1.25” eyepiece and the ES92 is 2” but I think I prefer the ES92’s. I’ve got a f/4 16” Dob coming in a couple months and I’d like to go back to the ES92’s but Only if they will perform well between f/4 In the Dob and f/5.4 In the NP101?
  • 25585 likes this
#2 Spikey131
Spikey131
Posted 22 May 2020 - 08:15 PM
1.  The 1.25” and 2” difference is meaningless.  The ES 92 12mm has a field stop smaller than 1.25”.  They could have made it a 1.25” EP, they just didn’t.
2.  I have a 13mm Ethos and an NP101.  I see a well corrected 100* 42x flat field.  The Pleiades and the Beehive look fabulous.  So does Orion’s sword.  What underwhelms you?
3.  I also have an ES92 17mm.  I like it, with the big eye lens and long ER, and I think that it is well corrected at f/5.4.  The downsides for me is the long eye relief and short eyecup, which allows stray light in.  It also does not take a Dioptrix, so I need to wear glasses to correct astigmatism.  Finally, the ES92 EPs weigh a ton and make the Ethos 13 mm seem light.
#3 CrazyPanda
CrazyPanda
Posted 23 May 2020 - 12:55 AM
For what it's worth, with a coma corrector in my F/4.5 dob (bringing it to F/5.175‬), my 17 ES92 is tack sharp right to the field stop. You'll most definitely need a coma corrector in your F/4 dob if you want to care about edge of field sharpness, so if you get a Paracorr, that makes it F/4.6, and I'm willing to bet that the ES92s work very well in a coma corrected F/4.6 light cone.
Before I got my coma corrector, the only aberrations I saw at the edge of the field in my ES92 was coma. If there was any astigmatism present at the raw F/4.5 light cone, it was considerably smaller than the coma produced by the mirror.
There will be no issue in the F/5.4 light cone of the NP101.
Edited by CrazyPanda, 23 May 2020 - 12:56 AM.
#4 Tank
Tank
  • Loc: Stoney Creek, Ontario, CANADA
Posted 23 May 2020 - 05:11 AM
At F4 and f5 I don't see problems with the ES92s
  • 25585 likes this
#5 25585
25585
Posted 23 May 2020 - 06:00 AM
Ditto.
The 12mm needs to be 2" very definitely to provide the housing for its large lenses, that give the great views & easy eye relief.
  • Ihtegla Sar likes this
#6 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 23 May 2020 - 05:40 PM
When the eyepiece is that large and heavy, it just is more secure to make it 2 inches for support in the focuser.
True, it could be 1.25", but I wouldn't want to put that mass into a 1.25" hole and have all that weight as leverage.
  • 25585 likes this
