Filters causing really bad star halos, any advice?
8 replies to this topic
#1 stefannebula
stefannebula
  • Loc: Melbourne Australia
Posted 22 May 2020 - 11:38 PM
Hello,
I am experiencing really nasty halos around some stars that I'm sure is coming from my narrowband filters.
These halos are noticeable in single subs, and are very pronounced when stacked. It's happening for stars that aren't even that bright!
Is this to be expected with the filters that I'm using or is there something that I can optimize to reduce these?
Any advice appreciated...
Equipment
SharpStar 150HNT (F2.8, 420mm focal length hyperbolic newtonian)
Optolong 6.5nm Ha, Oiii and Sii filters
ZWO ASI183MM-Pro
The following is an Oiii master stack of 50*300s subframes (gain 100, offset 10, -20C)
FULL IMAGE:
#2 stefannebula
stefannebula
Posted 22 May 2020 - 11:42 PM
I'll add that this is an image of NGC6357, and the brightest star in the image (HD 157486) is only Magnitude 6.17
#3 SoDaKAstroNut
SoDaKAstroNut
  • Loc: Black Hills, South Dakota
Posted 23 May 2020 - 04:51 PM
Those are some unusual refraction spikes...never seen dashed ones.
#4 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 23 May 2020 - 05:16 PM
Are those mounted or unmounted filters?  If unmounted, have a try at reversing them.  Many filters have AR coating only on one side, and that side has to face the sensor....
  • SoDaKAstroNut likes this
#5 stefannebula
stefannebula
Posted 23 May 2020 - 08:49 PM
I'm no expert but I believe this is to be expected with a monochromatic filter. As I understand, the light diffracts into a spectrum and because the filter is monochromatic it only selects for only that color (blue in this case). When I combine the narrow band filters into a color image you can start seeing the rainbow.
It may be especially pronounced in my case because my secondary spider veins are very thick (2.5 mm) and I think that geometry has an affect on the amount of diffraction. Again, I'm no expert so I may be very wrong on that :p
  • Der_Pit likes this
#6 stefannebula
stefannebula
Posted 23 May 2020 - 08:50 PM
Thanks for the suggestion. My filters are unmounted, I inserted them the way the manufacturer specified but I will try reversing them just in case.
#7 PhotonHunter1
PhotonHunter1
  • Loc: Northwest Suburbs of Chicago
Posted 23 May 2020 - 09:02 PM
My current ASI camera and ASI filters create some nasty halos. Here a link to my latest image and the lovely multiple halos created by Alnitak. https://www.cloudyni...ad-and-friends/
While a new set of filters will solve some of my problem, the clear lens in front of my sensor can also be a contributing factor. Not sure but it may be a factor for you as well??
#8 stefannebula
stefannebula
Posted 23 May 2020 - 09:08 PM
Thanks for sharing, and yeah looks similar, I've heard that the old ZWO filters are re-branded optolong filters (may be incorrect) so it may just be an issue with these filters. Looks like there is some microlense diffraction around Alnitak as well, which shouldn't be an issue in my case as I'm using an ASI183 not ASI1600.
Love your image though, so much signal!
#9 guanzz
guanzz
Posted 10 November 2020 - 06:38 AM
The optical axis is adjusted very well, and the four-point star points have no obvious distortion visible to the naked eye. I don't know how to adjust the optical axis, and what is the actual back intercept, thank you.
