ED Doublet LRGB
5 replies to this topic
#1 Douglas729
Douglas729
  • Loc: Clarksville Mo.
Posted 23 May 2020 - 06:42 AM
I have an APM 140 ED refractor I purchased because it is excellent for visual observation but not being a triplet it is not ideal for CCD color images.
Does a CCD mono camera with an LRGB filter wheel negate that deficiency and create images that capture the color spectrum accurately like a good triplet refractor?
#2 sg6
sg6
  • Loc: Norfolk, UK.
Posted 23 May 2020 - 07:24 AM
Should do a good job as you are in effect working with narrower bits of the spectrum, so CA on the RGB items should be not applicable. There is no R and B to form a purple halo around the G objects.
Might be slight refocus between R and G and B. Green likely being a fraction longer. But it is a "fraction", as in a really tiny fraction.
The L is the question, since that is still all the colors = white in effect. Shouldn't cause anything but unsure. Not enough experience I am afraid.
#3 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 23 May 2020 - 11:53 AM
Moving this to B&II for a potentially better fit.
#4 Madratter
Madratter
Posted 23 May 2020 - 12:44 PM
Not entirely. Many ED doublets perform acceptably well. However, even with a good ED doublet, you are likely to find spot sizes in some of the colors better than others. How much different they are will depend a lot on the glass used. To generalize (always a bit dangerous), the slower the f-ratio, the more likely you are to get away with the doublet but then you are looking at longer integration times.
#5 ks__observer
ks__observer
  • Loc: Long Island, New York
Posted 23 May 2020 - 01:10 PM
Would perform fine for narrowband.
#6 Stelios
Stelios
  • Loc: West Hills, CA
Posted 23 May 2020 - 01:40 PM
Unless you are a very advanced imager, you would find the APM plenty good enough for astrophotography, even with a DSLR or OSC camera. You would have slightly more bloated stars perhaps than with a triplet, but you would probably do better by sinking money into mount and OAG and autofocus before worrying about the doublet vs. triplet difference. You are *not* going to have color aberrations.
Not trying to talk you out of mono LRGB imaging--that's the way to go for many reasons. But don't go that way because you worry about the scope.
