smeared background
8 replies to this topic
#1 tloebl
tloebl
Posted 23 May 2020 - 03:10 PM
the image is a calibrated image with only histogram transform over applied so it becomes visible. I am aware there is a bit of drift due to flexure. I can get rid of the smeary background but I wonder if someone can give me a clue as to what it might be caused by. I thought it might be an older dark frame with uneven hot/cold pixels causing it but I just tried a brand new series of darks and the problem is still there. Is there any parameter in light calibration or image integration in PI that could cause this pattern rather than a random background?
#2 tloebl
tloebl
Posted 23 May 2020 - 03:12 PM
Sorry for the double post...
#3 Tapio
Tapio
  • Loc: Tampere, Finland
Looks like lack of dithering?
#4 Stelios
Stelios
  • Loc: West Hills, CA
Posted 23 May 2020 - 03:17 PM
Agree--looks like FPN (fixed pattern noise) which dithering removes.
  • rockstarbill and xiando like this
#5 xiando
xiando
  • Loc: Cloudy NEOhio
Posted 23 May 2020 - 03:20 PM
 What they said above.
See
https://www.cloudyni...-in-processing/
https://skyandtelesc...oduction-noise/
https://astrobackyar...trophotography/
https://skyandtelesc...r-astro-images/
#6 tloebl
tloebl
Posted 23 May 2020 - 03:28 PM
Thanks for the links. I am aware of dithering though I have never used it in 15 years of imaging. This issue only started recently. My stacked images in the past never showed this pattern.
  • xiando likes this
#7 tloebl
tloebl
Posted 23 May 2020 - 04:36 PM
The attached is with a different camera, a 1600mm, using the same telescope/mount/tracking, etc., with similar processing and no dithering. I don't see the same effect. Does this happen sometimes, but not every time, w/o dithering?
#8 xiando
xiando
Posted 23 May 2020 - 05:43 PM
Understood. Just wanted to share them in case you "weren't aware and wanted to learn (I'm too lazy to write an article on it in a forum post... much lazier cough easier to drop a few links ;)
Best wishes.
#9 tloebl
tloebl
Posted 23 May 2020 - 06:12 PM
No problem, I appreciate any information...
  • xiando likes this
