Fan speed control
7 replies to this topic
#1 epee
epee
  • Loc: Suh-van-nuh, Jaw-juh
Posted 25 May 2020 - 11:41 AM
Which potentiometer should I buy to control the speed of a 12v PWM case fan?
Links to specific models and order sites are greatly appreciated.
#2 Pinbout
Pinbout
Posted 25 May 2020 - 11:54 AM
https://www.youtube....&index=51&t=15s
pwm off amazon
Edited by Pinbout, 25 May 2020 - 11:59 AM.
  • epee and Lola Bruce like this
#3 skywolf856
skywolf856
  • Loc: SE Michigan
Posted 25 May 2020 - 12:24 PM
This is the one I bought.
https://www.amazon.c...90427437&sr=8-6
  • epee and Pinbout like this
#4 TG
TG
  • Loc: Latitude 47
Posted 26 May 2020 - 02:24 AM
Look for CPU fan control on Amazon. LED voltage controllers generally don’t work because they use switching.
  • epee likes this
#5 Bob4BVM
Bob4BVM
  • Loc: W. Oregon
Posted 26 May 2020 - 02:51 AM
Simplify !
While not as high tech and less efficient than PWM, you can certainly use a simple bare  potentiometer to control speed of a typical PC case fan, connected as a rheostat in series with the fan it will limit current & voltage to fan thereby controlling speed.
A good rating for the pot would be 200-300 ohms, 2 watts, which you should be able to get at any electronics supply place. These fans typically draw 100 - 150 mA at 12V, so a 2W pot can handle that kind of power.
If you want to take the next step in complexity, you can choose your speed with a 3-pin voltage regulator like an LM 7808 or 9.
My fans use that approach, where I switch in the 7808 for a pretty low speed when observing or switch it out of ckt for pre-cooling at the full 12V supply voltage.  Ckt consists of the regulator IC and one .1uF capacitor, plus a little DPDT switch.
Been using both those schemes for years, both work great at almost no cost, maybe a buck or two if you have no parts laying around, free to most who've been messing with electronics for a long enough to have a decent parts stash.
CS
Bob
  • epee likes this
#6 StevenYood
StevenYood
  • Loc: Suwanee, GA
Posted 26 May 2020 - 03:45 AM
I  a number of cheap option before I bit the bullet and bought a board from Dew Buster.
http://www.dewbuster...-c-fanctrl.html
These are costly, but they work flawlessly.  I now have three of them!
  • epee likes this
#7 epee
epee
Posted 26 May 2020 - 10:47 AM
On order!
Thanks folks!
  • Pinbout and pjmulka like this
#8 skywolf856
skywolf856
  • Loc: SE Michigan
Posted 26 May 2020 - 10:12 PM
Mine works no problem.
