televue ranger coarse focus draw tube detached - is it repairable?
refractor
9 replies to this topic
#1 gerards
gerards
Posted 25 May 2020 - 01:08 PM
The coarse focus draw tube has separated from the main tube.  The draw tube is secured to the main tube by a pin in the main tube that goes into a slot in the course focus draw tube.  Unfortunately the pin has disintegrated, and so the tube can come out of the main tube.
Please see photos.  One shows the draw tube and the slot.  The other is the main tube, and the pin should be above where you can see the words "Ranger", a short distance in the tube and on the bottom of the tube.   It should lie where you can see a light coloured bit.  The pin is secured by a screw underneath it.
DSCN1746
DSCN1734
Grateful for any help and ideas.  Unless I can fix this, I will probably need a new telescope.
Gerard
Edited by gerards, 25 May 2020 - 01:09 PM.
#2 Auburn80
Auburn80
Posted 25 May 2020 - 01:42 PM
Check with Tele Vue tomorrow. They may be able to repair.
#3 alnitak22
alnitak22
Posted 25 May 2020 - 01:44 PM
Yes, they could repair it but unfortunately are closed due to Covid. Maybe later in the summer.
#4 Spikey131
Spikey131
Posted 25 May 2020 - 03:16 PM
I think they are taking calls for technical support. They are very helpful on the phone, and have often helped me solve the problem myself.
  • alnitak22 likes this
#5 Bill Jensen
Bill Jensen
  • Loc: Springfield VA
Posted 25 May 2020 - 03:22 PM
Perhaps you can get a slightly  longer screw of the same thread size for a temp fix? in other words, remove the existing screw, and use a longer one to fit into the slot ?
#6 gerards
gerards
Posted 26 May 2020 - 08:33 AM
Getting a longer screw won't help as the screw width is wider than the slot on the drawtube. The screw supports whatever goes into the slot.  I guess that I will have to talk to Televue once they are open again.
#7 davidmcgo
davidmcgo
  • Loc: San Diego, CA
Posted 26 May 2020 - 08:37 AM
TV should be able to provide a new pin since the TV60 uses the same design.  Otherwise find a local machine shop and see if they can make a new one,
Alternately, just leave it set at correct distance for your eyepieces and don’t loosen the top thumb screw.  It will still work as long as you don’t pull it out too far.
Dave
#8 Thomas Marshall
Thomas Marshall
  • Loc: Spring Valley AZ.
Posted 26 May 2020 - 04:57 PM
Just grind down the end off the screw so the end portion will fit the slot?
#9 gerards
gerards
Posted 30 June 2020 - 03:10 AM
Good news.   I spoke to Televue in the USA (from the UK) and they sent me the appropriate screw with the bit on it that goes into the slot of the drawtube. Televue only charged for the mail.  I now have a working Ranger telescope and I have also repaired my panoramic mount. I also regreased the focuser so that is working well (I found out that I mustn't tighten the grub screws too much).  So very happy.
  • davidmcgo, beanerds, alnitak22 and 2 others like this
#10 plyscope
plyscope
  • Loc: Perth, West Australia
Posted 30 June 2020 - 03:28 AM
Glad you were able to get the telescope repaired.
Here is an online article about re-greasing the helical focuser.
http://scopeviews.co...oFixTVFocus.htm
Also tagged with one or more of these keywords: refractor
