Super ligthweight widefield autoguider setup
4 replies to this topic
#1 calypsob
calypsob
Posted 26 May 2020 - 12:03 PM
I recently put together an autoguiding setup for use with camera lenses 135mm and wider using the normal ASI290mm as a guide camera.
The goal was to keep weight to a minimum and to keep components to a minimum. Aside from the guide camera, this kit is only 3 pieces.
I typically use a ballhead mounted to a dovetail plate when I dslr image so this setup breaks down to a very small easy and fast to setup package.
First I acquired a small 1/4' threaded ballhead which mounts onto a threaded hotshoe adapter
https://www.ebay.com...iUAAOSwcXVZ7s-x
https://www.ebay.com...oid183912799663
Since the asi290 is threaded for 1/4-20, it just screws onto the ballhead. The ballhead will swivel and pivot unless locked down which makes it easy to square up. This ballheads payload is not listed but you can tell that the weight of the camera and lens is easily locked solid into place when operating the lock mechanism.
The guiding lens is a Fujian 50mm F1.4.  It comes with a hood and spacers. the ASI290 comes with a cmount adapter.
the lens makes focusing on stars super easy and you can use the aperture to reduce light and sharpen up stars instead of using camera gain to get longer guide exposures.
You can use this calculator to determine if this setup will work for you https://astronomy.to...ope_suitability
Here is the lens https://www.ebay.com...5?ul_noapp=true
Its a pretty nice setup for around $50, super light and lets me do long 10 minute exposures without worry of elongated stars. Polar alignment in sharpcap seems to have worked well also, there is no noticeable drift after 4 hours, only artifacts at the edges from dithering.
  • Starman27, xbunnyraptorx and Astrolog like this
#2 xbunnyraptorx
xbunnyraptorx
  • Loc: Bangor, ME
Posted 26 May 2020 - 12:20 PM
That is a neat setup, might be interested in checking that out for widefield.
#3 Alen K
Alen K
Posted 26 May 2020 - 12:34 PM
$50 not counting the guide camera.
Edited by Alen K, 26 May 2020 - 12:35 PM.
#4 calypsob
calypsob
Posted 26 May 2020 - 12:42 PM
Correct. This is just a setup for widefield guiding. You need an autoguider for any sort of autoguiding. The asi 290mm is $370
#5 dayglow
dayglow
Posted 30 May 2020 - 12:07 AM
Here's my light weight auto-guide setup
camera, mounting plate, guide scope, and guide camera
I put a red dot finder in the shoe to aim at the target then replace it with the guide camera & scope combination when imaging.
The piece of metal is 1/4 inch thick aluminum though something thinner could also work.
I've had some bad experiences with ball mounts allowing gradual slippage with results in star elongation so now I avoid that method of mounting either cameras or guiders.
The scope is 30mm f/4.3 from QHY and the camera is QHY5L-II-M
Edited by dayglow, 30 May 2020 - 12:10 AM.
